    Girls Best Friend - New Images
    13 Posts 9 Posters 4.1k Views 9 Watching
    • HornOxxH
      HornOxx
      "...Enjoy" - yes I do, very much πŸ‘ πŸ˜„
      the little stones sparkle and reflect like real ones - and the detailing of the black cap is well done also! An impressive work & thanks for sharing
      never trust a skinny cook
        Great, Agreed on the glass tube rather than the brass one.
        • kimi kimiK
          kimi kimi
          Looks too artificial too me, but I can't tell exactly what's the reason. Maybe try to move that black away from absolute black, I think that's messing up the light. Also, some depth of field effect might be nice, since it's a small object. If you're really into experimenting, try some bump and dirt maps for the bottle and ground.
          • tuna1957T
            tuna1957
            Really appreciate the comments and critiques. In that spirit posting two new images. Made some very minor adjustments to the bump maps of some of the textures. Biggest change was adding a noise map for the glass tube, strength of that map set very low. First image has the same hdri setup as the originals. Second image I rotated the hdri around 160 degrees . If any ones interested the hdri is out of the sketchUcation studio pack #001. It's a multi light setup. Experiments showed the diamonds render best under multiple lights. Forgot to mention all renders done in Twilight. Original images post pro in Gimp. Second set of images very minor post pro in Affinity ( just downloaded it last night ). Second set of images any better...... darned if I know.
              Much clearer images, brilliant.
              • tuna1957T
                tuna1957
                Thanks Mike.
                • Bryan KB
                  Well done!
                  • tuna1957T
                    tuna1957
                    Thanks Bryan.
                    • G
                      garystan
                      tuna1957 :
                      I like the way the diamonds are rendered. garystan
                      • duanekempD
                        duanekemp
                        Very nice to see. And the second set of images really are good. Bravo.
                        Duane Kemp
                        Kemp Productions
                        Puidoux, Switzerland
                        Gallery:
                        https://duanekemp.artstation.com/
                        • marked001M
                          marked001
                          πŸ‘ πŸ‘ πŸ‘
                          http://www.revision21vis.com
                          instagram: revi21on
                          • Bob JamesB
                            Bob James
                            The final one is "picture perfect" πŸ‘
