    [Plugin] ClothWorks v1.8.0 - 28 Apr 2024
    699 Posts 161 Posters 644.3k Views 161 Watching
      Anton_S
      Hello Ahmed,
      I will address the 2nd and 3rd issues in the next release. Thanks for including the keyword "distance", which stimulated an idea of how to fix it.
      About the licensing CCleaner issue, I refereed to SketchUcation guys, and they said the circumstances that cause it are unclear at the moment, but it is being looked into.
      Thanks,
      Anton
        Anton_S
        @slodka said:
        I want to reset all my seats,but I can't use PM,so I leave a message here.
        Hi, I reset your seats. Please refer to page 4, Known Issue section in the Licencing Manual, for resetting on your side.
        Also, consider updating to latest SketchUcationTools v3.1.5, which potentially, addresses the licensing issues on Mac OS X: https://sketchucation.com/pluginstore?pln=SketchUcationTools
          Ahmed0007
          and also Thanks for This Great Plugin.
            Ahmed0007
            gizmo also gets big when i select the custom made big pin.
            • U Offline
              Unexpectediteminbaggingarea
              I have the latest version, 1.1.1 for Mac but the license still keeps deactivating every time I re-start SketchUp.
              Is there a fix for this yet?
              Thank you.
                Anton_S
                @unexpectediteminbaggingarea said:
                Thank you.
                Hello,
                Are you using the latest SketchUcationTools, version 3.1.5? If not, please upgrade as it could fix the issue.
                Plugin Store Download | SketchUcation
                Extending SketchUp has never been easier with a suite of tools that make installing and disabling plugins and extensions a one click operation.
                (sketchucation.com)
                Anton
                • MALAISEM Offline
                  MALAISE
                  Awsome effects Cheers Anton. (I bought the license today )
                  Idea: Set viscosity of collider in order to "simulate" drops moving on surface.
                  Very useful for geological deformations explanations.
                  Pierre
                    rl.amorato
                    Hi Guys, I was wondering if clothworks would be able to wrap around an object, instead of draping over something. Kinda like the reference image attached. Thanks!
                      Anton_S
                      I have tried putting something like this together and it seems like it can be done, well, specifically, with a newer version of ClothWorks, which is still under development.
                      I have attached an image and a link to SKP file listing and displaying the key steps.
                      https://drive.google.com/open?id=1X-39luoZWwYqP9O-j6zSt4GrTtC3YVAZ
                      Anton
                        rl.amorato
                        https://sketchucation.com/forums/images/smilies/1f635.png Nice! Very nice! I'm looking forward to the new release. Thank you so much for this plugin! You're a godsend!
                          trenton.gauthier
                          Good morning, this is probably not an issue specific to your plugin but I'm missing the right click / aka context menu which is preventing me from using the newly purchased plugin. I've taken the steps of reinstalling the plugin both through the sketchucation store and manually. I'm using a fresh install of Sketchup Pro 2017 ver. 17.2.2555 64 Bit on Windows 10 Pro ver. 1803 with an i7-6700k and GTX 1080 Ti Hybrid. I've also sent you an email.
                          Screenshot
                          Extensions
                            @trenton.gauthier said:
                            ...but I'm missing the right click / aka context menu which is preventing me from using the newly purchased plugin.
                            The Context menu is just that. The menu items in it depend upon the context you are clicking on. You are right clicking on loose geometry. To get Clothworks to show, you need to right click on a component or group.
                            When all else fails, read the manual.
                              king1997
                              when I click to (Menu) Extensions → ClothWorks → License ...
                              SFC License dialog box <<<<<< this never show up what to do help i have already paid 😢 😢
                                Anton_S
                                Did you install SketchUcationTools, specifically version 3.1.5? https://sketchucation.com/resources/plugin-store-download
                                • Gus RG Offline
                                  Gus R
                                  Howdy,
                                  LTNS. Great plugin.
                                  Having problems licensing this. I submitted the license several times now and followed instructions to delete the three files per page 5 of 5.
                                  When I restart Sketchup it's not licensed again.
                                  So I tried again.
                                  I exceeded seats and have requested a restart and will try again.
                                  Had the latest Sketchucation tool installed but installed the latest version just in case. Didn't seem to make a difference.
                                  License is located in C:\Users\Asus P8P67 Deluxe\AppData\Local\SCF Licenses.
                                  www.instagram.com/gusrobatto/
                                  www.facebook.com/gusrobatto
                                    Anton_S
                                    Gus,
                                    I reset your licence. Please refer to Licencing Manual, Known Issue section, starting at number 2 for further instructions: https://drive.google.com/open?id=1QLzrBm5Qy7ZQh56HNqRl_LjqxNhgd9dO
                                    Anton
                                    • Gus RG Offline
                                      Gus R
                                      Anton,
                                      Thanks. Looks like it took this time around but I killed one seat after deleting the following:
                                      Those three files returned and I let them remain and it's still licensed after restart.
                                      This is from page 5 of the install instructions.
                                      @anton_s said:
                                      Gus,
                                      Anton
                                        Anton_S
                                        Gus,
                                        I can see the seats went back up to two. If seats fill up again, send me a private message for an alternative solution.
                                        Anton
                                        • StinkieS Offline
                                          Stinkie
                                          I'm interested in buying ClothWorks. My modeling and rendering machine isn't connected to the internet, though. Is that a problem?
                                          • Gus RG Offline
                                            Gus R
                                            Anton,
                                            Well, believe it or not it lost the license again. Was practicing with it last night and this morning and I just went back and it's not licensed again. Didn't touch anything so to speak and didn't run anything like CCleaner.
                                            I did however clear my temp directory.
                                            I went back and restored what I deleted from the temp file and the license came back.
                                            License should be reliant on what's in the temp directory. Let me see if I can localize the file in the temp directory.
                                            @anton_s said:
                                            Gus,
                                            Anton
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 30 / 35
