    SU solid (easy prep for 3D printing)
    9 Posts 6 Posters 1.2k Views 6 Watching
    • soloS Offline
      Anyone seen this or used this yet?
      SuSolid
      (www.susolid.com)
        I have it ages. Wonderful tool.
        • soloS Offline
          Just stumbled on it, would work better if I had a 3D printer however.
            Great for cleaning up models too.
            Removes all sorts of crud.
            • aarondietzenA Offline
              aarondietzen
              Poof!
              "Imagination is more important than knowledge..."
              - Albert Einstein
                It also attracts other amazing people...see above
                  jonorman
                  Ive been using this plugin since it came out and it is one of my "must have" plugins. it is with out a doubt one of the best way to check your model for flaws and errors.
                  Just to check the whole model and have it show`n what is solid and not, stray edges, coplanar faces and so on is amazing..
                  collision check, weight of components and group and the whole structure you`r working is just amazing.
                  There are plugins, and great plugins around doing similar stuff, but to have it in one bundle and easy to use is just great.
                  Engineers and architects would benefit a lot of this plugin...
                  Please give it a go, I bet you will enjoy it..
                  πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘
                    andreactro
                    Hi! I bought this today and it hasn't arrived, anyone had the same problem?
                      What hasn't arrived? Did you download it from the site? I would expect an e-mail with the license info but you should check your spam folder. If you didn't get an e-mail, you should contact them directly through their website.
                      Did you try it before sending money? From the website it appears this extension hasn't been updated for versions newer than SU2014. It might not work correctly in newer SketchUp versions.
