    [Plugin][$] TopoShaper - v2.7a - 01 Apr 24
    455 Posts 144 Posters 694.1k Views 143 Watching
    • fredo6F Offline
      @edarchm2 said:
      where ccan i download it?#
      You can download the RBZ at https://sketchucation.com/pluginstore?pln=TopoShaper
      Note that you need to install also the companion library LibFredo6.
      Otherwise, the best is to install the Sketchucation ExtensionStore plugin and then auto-install TopoShaper and any of the 800 plugins in the store in one click.
        rv1974
        Hi Fredo,
        *) How do I solve 'needle eye' obstacle (see attached)? Plugin get stuck at this stage forever.
        *) Second very primitive mesh crashes on generating. Could you take a look at this example?
        P.S. I always had scruples to ask, What is purpose of this 2nd 'zoomed' mesh in beige square?
        Untitled.skp
        • fredo6F Offline
          @rv1974 said:
          Hi Fredo,
          Your models seems 'unprepared' for TopoShaper. I don't see contour lines, but instead lot of edges with intersections and different altitudes.
          The blocking on Needle Eye is actually just a Ruby error due to the convoluted configuration of contours, but even if I fixed it, I don't see how you can generate a terrain from your input data.
            rv1974
            RTFM helped as usual, many thanks
            • PixeroP Offline
              Pixero
              I was wondering if there is a limit to how detailed a ISO lines terrain can be to work with Toposhaper?
              As you can see in the attached image only a part of the terrain is created. If I try with a less dense contour file of the same area it works but I need the detail as high as possible.
              • fredo6F Offline
                [attachment=0:2s5end60]<!-- ia0 -->screenshot.jpg<!-- ia0 -->[/attachment:2s5end60]
                The typical usage of TopoShaper is to smooth out the terrain, using isocontours as guides for altitude. The precision of the contours is not necessary (i.e. does not need closely spaced contours, nor many points in the contour curves), and anyway in relation with the resolution of the mesh.
                All this being said, I am impressed by the large model you have.
                  clement duvoux
                  Bonjour Fredo,
                  Après installation de la dernière version de Toposhaper (2.3b) et de LibFredo6 v8.1h, Toposhaper ne s'execute pas à l'ouverture de Sketchup, renvoyant un message d'erreur qui est le suivant : "you must install LibFredo6 to run Toposhaper
                  Open the download page of LibFredo6 at https....".
                  Après vérification dans l'extension manager, LibFredo est pourtant bien installé. Une idée sur l'origine du bug ?
                  • fredo6F Offline
                    @clement duvoux said:
                    Bonjour Fredo,
                    Il faut verifier que LibFredo6 est bien chargé. Est ce qu'il y a un menu Window > LibFredo6 Settings.... ?
                      gio
                      [attachment=0:1bzib748]<!-- ia0 -->screenshot.jpg<!-- ia0 -->[/attachment:1bzib748]
                      Maybe you can make just smaller portions and join them in the end?
                      Gio
                        dlannetts
                        Hello,
                        Great plugin, however I am having an issue, after generating the terrain from guide points, using the toolbar, and clicking off elsewhere, the toolbar disappears and I can't seem to get it back to modify the terrain. How can I get the toolbar back after it has disappeared?
                        David.
                        • fredo6F Offline
                          @dlannetts said:
                          Hello,
                          David.
                          Can you open the Ruby console, as there may be an error.
                          Did the terrain generate correctly by the way?
                            simonhaufe
                            I just try TopoShaper with a point cloud with more than 130.000 points out of a ASCII-File. How I can import it in SU and make any kind of terrain model?
                            Any ideas and suggestions are most welcome!! 😎 ☀
                            Best Regards Simon
                            • fredo6F Offline
                              Best Regards Simon
                              I don't think TopoShaper can handle 130,000 points; and I don't think either that Sketchup will not scream with a mesh of 130,000 vertices.
                              So you'll probably have to find a way, with other tools to simplify the input points or raw mesh, either simplifying, or cutting in pieces if the cloud covers a very large area. I don't know if there are Ruby scripts in Sketchup to do that, but I know there are specialized terrain software that can do it. There are several discussion threads in Sketchucation and Sketchup forums about terrains.
                                rspierenburg
                                I'm trying to use Toposhaper to create a topo from points. I have points selected and when I run the plugin all I get is a blank error.
                                Toposhaper Error
                                • fredo6F Offline
                                  It would be helpful that you attach your model so that I can investigate. Thanks.
                                    rspierenburg
                                    Thanks, Here is the model.
                                    Topography.skp
                                    • fredo6F Offline
                                      @Rspierenburg
                                      You just need to put all contruction points and the contour within a Group, then select the group and run TopoShaper Cloud.
                                      Note that your model seems to have some points which create peaks.
                                      Rspierenburg - Topography - SU2015.skp
                                        Anastasia_0111
                                        What can be the reason of such error of TopoShaper?
                                        It appears on SketchUp17 and 18, if I try very simple terrain, just of 2 or 3 curves.
                                          Put your SKP, that can be helping! 😉
                                          Save as V6 for a more large audience! 😉
                                            Anastasia_0111
                                            As I said it happens in any file, just if I try to create a terrain from 2 simple curves drawn by "freehand".
                                            This is a full text of the error:
                                            body_lib6g6.rbe
                                            2254
                                            block in proximity_point_curve_by_circle
                                            body_lib6g6.rbe
                                            2249
                                            each
                                            body_lib6g6.rbe
                                            2249
                                            toposhaperalgo.rbe
                                            2419
                                            block in altitude_at_point
                                            toposhaperalgo.rbe
                                            2417
                                            each
                                            toposhaperalgo.rbe
                                            2417
                                            altitude_at_point
                                            toposhaperalgo.rbe
                                            2390
                                            altitude_multi
                                            toposhaperalgo.rbe
                                            427
                                            block in top_processing
                                            toposhaperalgo.rbe
                                            425
                                            each
                                            toposhaperalgo.rbe
                                            425
                                            each_with_index
                                            toposhaperalgo.rbe
                                            425
                                            top_processing
                                            toposhapertool.rbe
                                            574
                                            algo_processing
                                            toposhapertool.rbe
                                            666
                                            execute_validate
                                            toposhaperpalette.rbe
                                            130
                                            execute_from_palette
                                            76
                                            notify_from_palette
                                            518
                                            call
                                            518
                                            block (2 levels) in palette_validate
                                            body_lib6palette.rbe
                                            3596
                                            call
                                            3596
                                            execute_button
                                            3401
                                            onLButtonUp
                                            lib6palette.rbe
                                            91
                                            onLButtonUp
                                            toposhapertool.rbe
                                            984
                                            onLButtonUp
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 22
                                            • 23
                                            • 12 / 23
