    [Plugin] ClothWorks v1.8.0 - 28 Apr 2024
    707 Posts 163 Posters 752.2k Views 163 Watching
    • U Offline
      Unexpectediteminbaggingarea
      @anton_s said:
      @unexpectediteminbaggingarea said:
      I can select the pins during playback in cloth works and I can use the move handles, and when I hold down Control the move handles do switch to expand/contract, but when I click the mouse on any of the handles the whole lot vanishes and the selection is lost.
      Is this a Mac bug??
      Yes, just checked. It's a bug! Will make a maintenance release today.
      Edit: Fixed. Upgrade to 1.1.1: https://sketchucation.com/pluginstore?pln=ClothWorks
      On Mac OS X, use SHIFT key for converging/diverging.
      Yey! I found an actual bug!
      Fast fix, all good now!
      Well done and thanks!!
      • U Offline
        Anton this plugin is just amazing!
        It's going to fill a HUGE gap in SketchUp for me for visualisation.
        And I know it's not meant as an animation tool, but if ever you felt like building a SketchUp animation tool I'm sure there's a big market out there!
          rv1974
          Anton, all examples I've seen so far looks like made of 2mm steel sheet. Is there a trick in settings to get much more sharper corners in bending areas (is creasing a good term for this)?
            rv1974
            Can you implement a loop of edges as "linear pin"? Could be useful for long curtains and waterfalls. And maybe for sharp corners too.
              Anton_S
              I don't know actually. Perhaps increasing cloth resolution (applying a grid with smaller spacing), could do the trick with forming sharp corners. I will need to test this around a bit and see if there is a way to achieve the sharp corners.
                Anton_S
                Can you provide more detail with that?
                • soloS Offline
                  +1
                    Jorgensen
                    Mood. First image using ClothWorks πŸ˜„
                      rv1974
                      it's a simple idea: you'd select a loop (or set of edges, even unconnected) and order it to stay fixed. instead of point pin you get a linear holder. What important is an easy access to those linear holders (for selecting\editing).
                        If you look up Vertex Groups in Blender you can get an idea what RV is asking.
                        Maybe you could add a feature that allows the user to make any object behave like a pin.
                        So selected edge/s behave the same as a collection of pins.
                        • jiminy-billy-bobJ Offline
                          jiminy-billy-bob
                          @rv1974 said:
                          1. The buying process should be reworked.
                          I agree!
                            Anton_S
                            For now, if you assign a pin type to the pole, and if the edges along the pole overlap the bounding box of the pole, they will be locked in place.
                            I checked the blenders group pins video: https://www.youtube.com/watch?v=yzRS2cCiBnc
                            It seems like it would be useful. Added to my TODO list (it would be an easy feature to implement).
                            @jiminy-billy-bob said:
                            I agree!
                            Yeah... The buying process is not so user friendly. It's not the worst start though πŸ’š
                            • BoxB Offline
                              How sharp and linear do you want it?
                              https://i.imgur.com/dI14YqS.gif
                                sofie9536
                                in order to get a sharp edge I doubled the mesh in the area of the edge with artisan.
                                  cas45
                                  Hi have 3.04.2018 the plugin ClothWork via PayPal, so far no license has been received. Have had the experience to send it immediately. Ask for info Thank you
                                    Anton_S
                                    Sent you a PM regarding this.
                                    • BoxB Offline
                                      A feature request of sorts, more of a think about this and see if it is possible.
                                      Can you make the shape of the geometry of the pin the thing that does the pinning rather than the bounding box of the pin/pin object.
                                      I know we can point pin, multi point pin and linear pin, but the ability to pin along a curve would be great.
                                      As you see here the pin itself is a curve but the bounding box makes it a rectangle.
                                      Whereas an array of small pins gives you a curve but it can be tricky to set up, gives you bumps and is less predictable than if you could use a specific edge.
                                      I know you could use a shaped collider in this instance, but I can see uses for curved pins.
                                        jiminy-billy-bob
                                        Hey Anton, I was wondering today: what's the performance bottleneck? Is it the physics simulation itself, or moving the whole geometry at each frame?
                                          rv1974
                                          I saw today some crazy project:
                                          https://architizer.com/projects/cluster-h-the-backyard/
                                          Notice those sail shades. In this case linear pins could be useful
                                            david harned
                                            Hi Anton, thanks so much for your quick replies to my questions! Looking forward to seeing what else you can do! Dave Harned
                                            • 11
                                            • 35
                                            • 36
                                            • 9 / 36
