    šŸ”Œ Smart Spline | Fluid way to handle splines for furniture design and complex structures. Download
    [Plugin Library] LibFredo6 - v15.8e - 15 Feb 26
    2.2k Posts 573 Posters 4.2m Views 575 Watching
    • fredo6F Offline
      NEW RELEASE: LibFredo6 v8.1d - 04 Mar 18
      LibFredo6 8.1d is a maintenance release dedicated to tentatively solving occasional bugsplats in Curviloft and FredoTools. Please also upgrade to the latest version if you have the case.
        ali_yonder
        Hello Fredo.
        When i installed fredo6 8.1 for SU2017, it has failed. How can i fix this problem?
        Error Loading File Fredo6_!LibFredo6.rb
        Error: #<ArgumentError: invalid byte sequence in UTF-8>
        c:/users/ali yƶnder/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:43:in gsub' c:/users/ali yƶnder/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:43:in get_dir_from_ENV'
        c:/users/ali yƶnder/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:405:in dir_appdata' c:/users/ali yƶnder/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:204:in startup'
        C:/Users/Ali Yƶnder/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:63:in process' C:/Users/Ali Yƶnder/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:70:in module:LibFredo6_Loader'
        C:/Users/Ali Yƶnder/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:28:in <top (required)>' Error Loading File Fredo6_FredoTools.rb Error: #<TypeError: can't convert nil into an exact number> C:/Users/Ali Yƶnder/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:79:in -'
        C:/Users/Ali Yƶnder/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:79:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require'
        C:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require' C:/Users/Ali Yƶnder/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_FredoTools.rb:47:in module:Fredo6'
        C:/Users/Ali Yƶnder/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_FredoTools.rb:26:in <top (required)>' Error Loading File Fredo6_ToolsOnSurface.rb Error: #<TypeError: can't convert nil into an exact number> C:/Users/Ali Yƶnder/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:79:in -'
        C:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require' C:/Users/Ali Yƶnder/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_ToolsOnSurface.rb:47:in module:Fredo6'
        C:/Users/Ali Yƶnder/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_ToolsOnSurface.rb:26:in `<top (required)>'
        Thank you šŸ˜„
          dci02081
          Ce ruby Libfredo6 v8.1d n’est pas marchĆ© sur sketchup pro 2016 (win10) dans l’ordinateur portable (surface pro5). Comment je le fixe ? en fait, le ā€˜***’ est la diffĆ©rente langue (c’est la langue corĆ©enne). C’est la raison de montrer ce bug ?
          c:/users//appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:43:in gsub' c:/users/***/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:43:in get_dir_from_ENV'
          c:/users/
          /appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:405:in dir_appdata' c:/users/***/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:204:in startup'
          C:/Users//AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:63:in process' C:/Users/***/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:70:in module:LibFredo6_Loader'
          C:/Users/
          /AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:28:in `<top (required)>'
          • TIGT Online
            c:/users/ali yƶnder/appdata/...
            I suspect it's to do with your Windows user name [ali yƶnder] containing some invalid character [likely the 'ƶ'].
            Ruby must be given UTF-8 encoded text strings.
            I'm sure that Fredo's code will attempt to force every string's encoding into an acceptable format.
            Clearly it's failing in your case...
            What is your normal system encoding ?
            Perhaps Fredo can comment...
            The other similar post's issue is again almost certainly because of the 'langue corƩenne' user-name encoding...
            • fredo6F Offline
              This is related to the encoding of ENV["xxx"] variables, where LibFredo6 does try to convert them to UTF-8.
              Could you open the Ruby console and type sequentially
              • a = ENV["LOCALAPPDATA"]
              • b = a.force_encoding("UTF-8")
              • b.encoding (should return UTF-8)
              Can you also type
              • c = LibFredo6.get_dir_from_ENV("LOCALAPPDATA")
              • c.encoding (should return UTF-8)
              Thanks to report if there are errors.
                ali_yonder
                Thanx for reply TIG & Fredo
                I am from Turkey nd there are 'ı,ü,ö' letters in my sytstem.
                I've written
                • b.encoding
                to ruby conlose.
                but it has failed again.
                Error: #<RuntimeError: can't modify frozen String>
                <main>:in force_encoding' <main>:in <main>'
                SketchUp:1:in `eval'
                b.encoding
                Error: #<NoMethodError: undefined method encoding' for nil:NilClass> <main>:in <main>'
                then, i ve written
                • c.encoding
                to ruby console, but it has failed again šŸ˜ž
                <main>:in <main>' SketchUp:1:in eval'
                c.encoding
                Do u have any suggestion?
                thanx all šŸ˜„
                • TIGT Online
                  Try this slightly different way, which sidesteps reading in the frozen system string...
                  puts a = ENV["LOCALAPPDATA"]**+""** puts b.encoding puts b = a.force_encoding("UTF-8") puts b.encoding
                  Fredo needs to fix his coding, once we get to the bottom of this issue...
                  • fredo6F Offline
                    Apparently ENV["LOCALAPPDATA"] is not defined.
                    Could you type in the Ruby console
                    ENV["LOCALAPPDATA"].inspect
                    @TIG: indeed, in LibFredo6 code, I duplicate the original string before forcing encoding. Just forgot this detail here.
                    • TIGT Online
                      So whenever any of us intend to use a 'frozen reference' we need to use something like:
                      a = ENV["LOCALAPPDATA"]+""
                      to make a copy of it to work on šŸ˜‰
                        ali_yonder
                        Thanx for replies again šŸ˜„
                        i've written ENV["LOCALAPPDATA"].inspect
                        "C:\Users\Ali Y\xF6nder\AppData\Local"
                        • fredo6F Offline
                          Many thanks
                          Then can you type the commands suggested by TIG
                          puts a = ENV["LOCALAPPDATA"]+"" puts a.encoding puts b = a.force_encoding("UTF-8") puts b.encoding
                          and add this one
                          puts a = ENV["LOCALAPPDATA"].encode("UTF-8")
                          IMPORTANT: your profile says you use Sketchup 8. Is that correct?
                            ali_yonder
                            Thanx fredo. I use sketchup 2017. i have to update my profile.
                            i've written these
                            puts a.encoding
                            puts b.encoding
                            and ruby said;
                            puts a.encoding
                            Windows-1254
                            puts b.encoding
                            UTF-8
                            C:\Users\Ali Yƶnder\AppData\Local
                            but still my problem is not solved. maybe i have to format my pc. i do not know.
                            • fredo6F Offline
                              Ali,
                              You need to type the commands one by one.
                              Apparently the last one seems to work.
                              Could send me a private message with an email address where I can send you a modified version of LibFredo6.
                              To be sure, can you type separately the 3 commands below:
                              a.encoding
                              a.gsub(/\\/, "/")
                              The last one should return the path with \ replaced by /
                              • fredo6F Offline
                                The problem should be resolved with the new version 8.1e.
                                Many thanks to Ali
                                • fredo6F Offline
                                  NEW RELEASE: LibFredo6 v8.1e - 13 Mar 18
                                  LibFredo6 8.1e is a maintenance release dedicated to solving (again) occasional issue on Windows when the username contains non-ascii characters.
                                    mgfranz
                                    After downloading and installing the latest version, I am getting these errors;
                                    Error Loading File C:/Users/mgfranz/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6/top_LibFredo6.rbe
                                    Failed to read RBE/RBS file.
                                    Error: #<NameError: uninitialized constant LibFredo6_Loader::LibFredo6>
                                    C:/Users/mgfranz/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:64:in process' C:/Users/mgfranz/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:71:in module:LibFredo6_Loader'
                                    C:/Users/mgfranz/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:28:in <top (required)>' Error Loading File Fredo6_RoundCorner.rb Error: #<TypeError: can't convert nil into an exact number> C:/Users/mgfranz/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:80:in -'
                                    C:/Users/mgfranz/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:80:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require'
                                    C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require' C:/Users/mgfranz/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_RoundCorner.rb:47:in module:Fredo6'
                                    C:/Users/mgfranz/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_RoundCorner.rb:26:in `<top (required)>'
                                    I have full permissions on all folders in my Sketchup Plugins folder.
                                    "If you like what you do, it will never be work..."
                                    In memory of Sam Maloof, 1916-2009
                                    • TIGT Online
                                      After reinstalling the Lib have you restarted SketchUp 2016 ?
                                        mgfranz
                                        Yes, of course. That's when I receive the error window.
                                        • TIGT Online
                                          Fredo will chip in soon...
                                          • fredo6F Offline
                                            The fail to read seems to be due to a wrong installation of Sketchup, that is without a "run as an administrator" on the install exe file.
                                            • 104
                                            • 105
                                            • 106
                                            • 107
                                            • 108
                                            • 109
                                            • 110
                                            • 106 / 110
