    [Plugin Library] LibFredo6 - v16.3b - 21 Oct 26
    2.3k Posts 592 Posters 13.7m Views 594 Watching
    • fredo6F
      I don't think this is the username, except for old versions of SU.
      Sometimes, Sketchup cannot read the rbs/rbe file. This seems to come from an installation done without adminsitrator rights.
      In general, a reinstallation of SU would solve the problem.
        Thanks Fredo.
        Perhaps the odd-characters in the user-name are a "red-herring".
        For the avoidance of doubt...
        On a PC the only correct way to install any application like SketchUp...
        Close that version of SketchUp, if necessary.***
        You must then find the SketchUp installer's exe file - it's usually in your "Downloads" folder.
        Select its icon.
        Right-click > Context-menu >
        "Run as administrator"
        When prompted choose "Repair".
        Let it complete the installation.
        When you restart SketchUp it should work properly.
        ***If it's a new installation [e.g. you have previously uninstalled it, or it's just brand-new] the offered installer's option will just be "Install"...
        • fredo6F
          NEW RELEASE: LibFredo6 v8.0c - 10 Dec 17
          LibFredo6 8.0c is a maintenance release dedicated to the integration of VRay 3.6 in Animator.
            MennaD
            thankx
            • fredo6F
              NEW RELEASE: LibFredo6 v8.1a - 23 Feb 18
              LibFredo6 8.1a is a maintenance release dedicated to bug fixing and evolutions in other plugins
              • fredo6F
                NEW RELEASE: LibFredo6 v8.1b - 25 Feb 18
                LibFredo6 8.1b is a maintenance release dedicated to bug fixing and evolutions in other plugins. Please use 8.1b or above on Mac, as rhere was a problem with toolbar icons in Vector format on Mac with v8.1a.
                • C
                  ChillBilla
                  2018? why doesn't this work? Is the latest version even available for 2018?
                  • fredo6F
                    What exactly is your problem?
                    • fredo6F
                      NEW RELEASE: LibFredo6 v8.1c - 27 Feb 18
                      LibFredo6 8.1c is a maintenance release dedicated to bug fixing for JointPushPull, Curviloft and FredoTools. Please also upgrade to the latest versions of these plugins.
                      • fredo6F
                        NEW RELEASE: LibFredo6 v8.1d - 04 Mar 18
                        LibFredo6 8.1d is a maintenance release dedicated to tentatively solving occasional bugsplats in Curviloft and FredoTools. Please also upgrade to the latest version if you have the case.
                          ali_yonder
                          Hello Fredo.
                          When i installed fredo6 8.1 for SU2017, it has failed. How can i fix this problem?
                          Error Loading File Fredo6_!LibFredo6.rb
                          Error: #<ArgumentError: invalid byte sequence in UTF-8>
                          c:/users/ali yönder/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:43:in gsub' c:/users/ali yönder/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:43:in get_dir_from_ENV'
                          c:/users/ali yönder/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:405:in dir_appdata' c:/users/ali yönder/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:204:in startup'
                          C:/Users/Ali Yönder/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:63:in process' C:/Users/Ali Yönder/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:70:in module:LibFredo6_Loader'
                          C:/Users/Ali Yönder/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:28:in <top (required)>' Error Loading File Fredo6_FredoTools.rb Error: #<TypeError: can't convert nil into an exact number> C:/Users/Ali Yönder/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:79:in -'
                          C:/Users/Ali Yönder/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:79:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require'
                          C:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require' C:/Users/Ali Yönder/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_FredoTools.rb:47:in module:Fredo6'
                          C:/Users/Ali Yönder/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_FredoTools.rb:26:in <top (required)>' Error Loading File Fredo6_ToolsOnSurface.rb Error: #<TypeError: can't convert nil into an exact number> C:/Users/Ali Yönder/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:79:in -'
                          C:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require' C:/Users/Ali Yönder/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_ToolsOnSurface.rb:47:in module:Fredo6'
                          C:/Users/Ali Yönder/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_ToolsOnSurface.rb:26:in `<top (required)>'
                          Thank you 😄
                            dci02081
                            Ce ruby Libfredo6 v8.1d n’est pas marché sur sketchup pro 2016 (win10) dans l’ordinateur portable (surface pro5). Comment je le fixe ? en fait, le ‘***’ est la différente langue (c’est la langue coréenne). C’est la raison de montrer ce bug ?
                            c:/users//appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:43:in gsub' c:/users/***/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:43:in get_dir_from_ENV'
                            c:/users/
                            /appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:405:in dir_appdata' c:/users/***/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:204:in startup'
                            C:/Users//AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:63:in process' C:/Users/***/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:70:in module:LibFredo6_Loader'
                            C:/Users/
                            /AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:28:in `<top (required)>'
                              c:/users/ali yönder/appdata/...
                              I suspect it's to do with your Windows user name [ali yönder] containing some invalid character [likely the 'ö'].
                              Ruby must be given UTF-8 encoded text strings.
                              I'm sure that Fredo's code will attempt to force every string's encoding into an acceptable format.
                              Clearly it's failing in your case...
                              What is your normal system encoding ?
                              Perhaps Fredo can comment...
                              The other similar post's issue is again almost certainly because of the 'langue coréenne' user-name encoding...
                              • fredo6F
                                This is related to the encoding of ENV["xxx"] variables, where LibFredo6 does try to convert them to UTF-8.
                                Could you open the Ruby console and type sequentially
                                • a = ENV["LOCALAPPDATA"]
                                • b = a.force_encoding("UTF-8")
                                • b.encoding (should return UTF-8)
                                Can you also type
                                • c = LibFredo6.get_dir_from_ENV("LOCALAPPDATA")
                                • c.encoding (should return UTF-8)
                                Thanks to report if there are errors.
                                  ali_yonder
                                  Thanx for reply TIG & Fredo
                                  I am from Turkey nd there are 'ı,ü,ö' letters in my sytstem.
                                  I've written
                                  • b.encoding
                                  to ruby conlose.
                                  but it has failed again.
                                  Error: #<RuntimeError: can't modify frozen String>
                                  <main>:in force_encoding' <main>:in <main>'
                                  SketchUp:1:in `eval'
                                  b.encoding
                                  Error: #<NoMethodError: undefined method encoding' for nil:NilClass> <main>:in <main>'
                                  then, i ve written
                                  • c.encoding
                                  to ruby console, but it has failed again 😞
                                  <main>:in <main>' SketchUp:1:in eval'
                                  c.encoding
                                  Do u have any suggestion?
                                  thanx all 😄
                                    Try this slightly different way, which sidesteps reading in the frozen system string...
                                    puts a = ENV["LOCALAPPDATA"]**+""** puts b.encoding puts b = a.force_encoding("UTF-8") puts b.encoding
                                    Fredo needs to fix his coding, once we get to the bottom of this issue...
                                    • fredo6F
                                      Apparently ENV["LOCALAPPDATA"] is not defined.
                                      Could you type in the Ruby console
                                      ENV["LOCALAPPDATA"].inspect
                                      @TIG: indeed, in LibFredo6 code, I duplicate the original string before forcing encoding. Just forgot this detail here.
                                        So whenever any of us intend to use a 'frozen reference' we need to use something like:
                                        a = ENV["LOCALAPPDATA"]+""
                                        to make a copy of it to work on 😉
                                          ali_yonder
                                          Thanx for replies again 😄
                                          i've written ENV["LOCALAPPDATA"].inspect
                                          "C:\Users\Ali Y\xF6nder\AppData\Local"
                                          • fredo6F
                                            Many thanks
                                            Then can you type the commands suggested by TIG
                                            puts a = ENV["LOCALAPPDATA"]+"" puts a.encoding puts b = a.force_encoding("UTF-8") puts b.encoding
                                            and add this one
                                            puts a = ENV["LOCALAPPDATA"].encode("UTF-8")
                                            IMPORTANT: your profile says you use Sketchup 8. Is that correct?
                                            • 60
                                            • 61
                                            • 62
                                            • 63
                                            • 64
                                            • 115
                                            • 116
                                            • 62 / 116
