[Plugin Library] LibFredo6 - v14.5b - 24 May 24
@chillbilla said:
2018? why doesn't this work? Is the latest version even available for 2018?
What exactly is your problem?
NEW RELEASE: LibFredo6 v8.1c - 27 Feb 18
LibFredo6 8.1c is a maintenance release dedicated to bug fixing for JointPushPull, Curviloft and FredoTools. Please also upgrade to the latest versions of these plugins.
NEW RELEASE: LibFredo6 v8.1d - 04 Mar 18
LibFredo6 8.1d is a maintenance release dedicated to tentatively solving occasional bugsplats in Curviloft and FredoTools. Please also upgrade to the latest version if you have the case.
Hello Fredo.
When i installed fredo6 8.1 for SU2017, it has failed. How can i fix this problem?
Error Loading File Fredo6_!LibFredo6.rb
Error: #<ArgumentError: invalid byte sequence in UTF-8>
c:/users/ali yönder/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:43:ingsub' c:/users/ali yönder/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:43:in
get_dir_from_ENV'
c:/users/ali yönder/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:405:indir_appdata' c:/users/ali yönder/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:204:in
startup'
C:/Users/Ali Yönder/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:63:inprocess' C:/Users/Ali Yönder/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:70:in
module:LibFredo6_Loader'
C:/Users/Ali Yönder/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:28:in<top (required)>' Error Loading File Fredo6_FredoTools.rb Error: #<TypeError: can't convert nil into an exact number> C:/Users/Ali Yönder/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:79:in
C:/Users/Ali Yönder/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:79:in<top (required)>' C:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in
require'
C:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:inrequire' C:/Users/Ali Yönder/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_FredoTools.rb:47:in
module:Fredo6'
C:/Users/Ali Yönder/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_FredoTools.rb:26:in<top (required)>' Error Loading File Fredo6_ToolsOnSurface.rb Error: #<TypeError: can't convert nil into an exact number> C:/Users/Ali Yönder/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:79:in
require'
C:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:inrequire' C:/Users/Ali Yönder/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_ToolsOnSurface.rb:47:in
module:Fredo6'
C:/Users/Ali Yönder/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_ToolsOnSurface.rb:26:in `<top (required)>'Thank you
Ce ruby Libfredo6 v8.1d n’est pas marché sur sketchup pro 2016 (win10) dans l’ordinateur portable (surface pro5). Comment je le fixe ? en fait, le ‘***’ est la différente langue (c’est la langue coréenne). C’est la raison de montrer ce bug ?
c:/users//appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:43:ingsub' c:/users/***/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:43:in
get_dir_from_ENV'
c:/users//appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:405:indir_appdata' c:/users/***/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:204:in
startup'
C:/Users//AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:63:inprocess' C:/Users/***/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:70:in
C:/Users//AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:28:in `<top (required)>' -
c:/users/ali yönder/appdata/...I suspect it's to do with your Windows user name [ali yönder] containing some invalid character [likely the 'ö'].
Ruby must be given UTF-8 encoded text strings.
I'm sure that Fredo's code will attempt to force every string's encoding into an acceptable format.
Clearly it's failing in your case...
What is your normal system encoding ?
Perhaps Fredo can comment...The other similar post's issue is again almost certainly because of the 'langue coréenne' user-name encoding...
This is related to the encoding of ENV["xxx"] variables, where LibFredo6 does try to convert them to UTF-8.
Could you open the Ruby console and type sequentially
a = ENV["LOCALAPPDATA"]
b = a.force_encoding("UTF-8")
b.encoding
(should return UTF-8)
Can you also type
c = LibFredo6.get_dir_from_ENV("LOCALAPPDATA")
c.encoding
Thanks to report if there are errors.
Thanx for reply TIG & Fredo
I am from Turkey nd there are 'ı,ü,ö' letters in my sytstem.
I've written
- a = ENV["LOCALAPPDATA"]
- b = a.force_encoding("UTF-8")
- b.encoding
to ruby conlose.
but it has failed again.
Error: #<RuntimeError: can't modify frozen String>
<main>:inforce_encoding' <main>:in
<main>'
SketchUp:1:in `eval'b.encoding
Error: #<NoMethodError: undefined methodencoding' for nil:NilClass> <main>:in
<main>'
SketchUp:1:in `eval'then, i ve written
- c = LibFredo6.get_dir_from_ENV("LOCALAPPDATA")
- c.encoding
to ruby console, but it has failed again
get_dir_from_ENV'
<main>:in<main>' SketchUp:1:in
eval'c.encoding
<main>'
SketchUp:1:in `eval'Do u have any suggestion?
thanx all
Try this slightly different way, which sidesteps reading in the frozen system string...
puts a = ENV["LOCALAPPDATA"]**+""** puts b.encoding puts b = a.force_encoding("UTF-8") puts b.encoding
Fredo needs to fix his coding, once we get to the bottom of this issue...
Apparently ENV["LOCALAPPDATA"] is not defined.
Could you type in the Ruby console
ENV["LOCALAPPDATA"].inspect
@TIG: indeed, in LibFredo6 code, I duplicate the original string before forcing encoding. Just forgot this detail here.
So whenever any of us intend to use a 'frozen reference' we need to use something like:
a = ENV["LOCALAPPDATA"]+""
to make a copy of it to work on -
Thanx for replies again
i've written ENV["LOCALAPPDATA"].inspect
"C:\Users\Ali Y\xF6nder\AppData\Local" -
"C:\Users\Ali Y\xF6nder\AppData\Local"Many thanks
Then can you type the commands suggested by TIG
puts a = ENV["LOCALAPPDATA"]+"" puts a.encoding puts b = a.force_encoding("UTF-8") puts b.encoding
and add this one
puts a = ENV["LOCALAPPDATA"].encode("UTF-8")
IMPORTANT: your profile says you use Sketchup 8. Is that correct?
Thanx fredo. I use sketchup 2017. i have to update my profile.
i've written these
puts a.encoding
puts b.encodingputs a = ENV["LOCALAPPDATA"].encode("UTF-8")
and ruby said;
puts a.encoding
Windows-1254puts b = a.force_encoding("UTF-8")
puts b.encoding
UTF-8puts a = ENV["LOCALAPPDATA"].encode("UTF-8")
C:\Users\Ali Yönder\AppData\Localbut still my problem is not solved. maybe i have to format my pc. i do not know.
Ali,
You need to type the commands one by one.
Apparently the last one seems to work.
Could send me a private message with an email address where I can send you a modified version of LibFredo6.
To be sure, can you type separately the 3 commands below:
a.encoding
a.gsub(/\\/, "/")
The last one should return the path with \ replaced by /
The problem should be resolved with the new version 8.1e.
Many thanks to Ali
NEW RELEASE: LibFredo6 v8.1e - 13 Mar 18
LibFredo6 8.1e is a maintenance release dedicated to solving (again) occasional issue on Windows when the username contains non-ascii characters.
After downloading and installing the latest version, I am getting these errors;
Error Loading File C:/Users/mgfranz/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6/top_LibFredo6.rbe
Failed to read RBE/RBS file.
Error: #<NameError: uninitialized constant LibFredo6_Loader::LibFredo6>
C:/Users/mgfranz/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:64:inprocess' C:/Users/mgfranz/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:71:in
C:/Users/mgfranz/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:28:in<top (required)>' Error Loading File Fredo6_RoundCorner.rb Error: #<TypeError: can't convert nil into an exact number> C:/Users/mgfranz/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:80:in
C:/Users/mgfranz/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:80:in<top (required)>' C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in
require'
C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:inrequire' C:/Users/mgfranz/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_RoundCorner.rb:47:in
module:Fredo6'
C:/Users/mgfranz/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_RoundCorner.rb:26:in `<top (required)>'I have full permissions on all folders in my Sketchup Plugins folder.
After reinstalling the Lib have you restarted SketchUp 2016 ?
Yes, of course. That's when I receive the error window.
