    šŸ”Œ Smart Spline | Fluid way to handle splines for furniture design and complex structures. Download
    [Plugin Library] LibFredo6 - v15.8e - 15 Feb 26
    2.2k Posts 573 Posters 4.2m Views 575 Watching
    • fredo6F Offline
      @chillbilla said:
      2018? why doesn't this work? Is the latest version even available for 2018?
      What exactly is your problem?
      • fredo6F Offline
        NEW RELEASE: LibFredo6 v8.1c - 27 Feb 18
        LibFredo6 8.1c is a maintenance release dedicated to bug fixing for JointPushPull, Curviloft and FredoTools. Please also upgrade to the latest versions of these plugins.
        • fredo6F Offline
          NEW RELEASE: LibFredo6 v8.1d - 04 Mar 18
          LibFredo6 8.1d is a maintenance release dedicated to tentatively solving occasional bugsplats in Curviloft and FredoTools. Please also upgrade to the latest version if you have the case.
            ali_yonder
            Hello Fredo.
            When i installed fredo6 8.1 for SU2017, it has failed. How can i fix this problem?
            Error Loading File Fredo6_!LibFredo6.rb
            Error: #<ArgumentError: invalid byte sequence in UTF-8>
            c:/users/ali yƶnder/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:43:in gsub' c:/users/ali yƶnder/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:43:in get_dir_from_ENV'
            c:/users/ali yƶnder/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:405:in dir_appdata' c:/users/ali yƶnder/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:204:in startup'
            C:/Users/Ali Yƶnder/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:63:in process' C:/Users/Ali Yƶnder/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:70:in module:LibFredo6_Loader'
            C:/Users/Ali Yƶnder/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:28:in <top (required)>' Error Loading File Fredo6_FredoTools.rb Error: #<TypeError: can't convert nil into an exact number> C:/Users/Ali Yƶnder/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:79:in -'
            C:/Users/Ali Yƶnder/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:79:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require'
            C:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require' C:/Users/Ali Yƶnder/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_FredoTools.rb:47:in module:Fredo6'
            C:/Users/Ali Yƶnder/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_FredoTools.rb:26:in <top (required)>' Error Loading File Fredo6_ToolsOnSurface.rb Error: #<TypeError: can't convert nil into an exact number> C:/Users/Ali Yƶnder/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:79:in -'
            C:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require' C:/Users/Ali Yƶnder/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_ToolsOnSurface.rb:47:in module:Fredo6'
            C:/Users/Ali Yƶnder/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_ToolsOnSurface.rb:26:in `<top (required)>'
            Thank you šŸ˜„
              dci02081
              Ce ruby Libfredo6 v8.1d n’est pas marchĆ© sur sketchup pro 2016 (win10) dans l’ordinateur portable (surface pro5). Comment je le fixe ? en fait, le ā€˜***’ est la diffĆ©rente langue (c’est la langue corĆ©enne). C’est la raison de montrer ce bug ?
              c:/users//appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:43:in gsub' c:/users/***/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:43:in get_dir_from_ENV'
              c:/users/
              /appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:405:in dir_appdata' c:/users/***/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:204:in startup'
              C:/Users//AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:63:in process' C:/Users/***/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:70:in module:LibFredo6_Loader'
              C:/Users/
              /AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:28:in `<top (required)>'
                c:/users/ali yƶnder/appdata/...
                I suspect it's to do with your Windows user name [ali yƶnder] containing some invalid character [likely the 'ƶ'].
                Ruby must be given UTF-8 encoded text strings.
                I'm sure that Fredo's code will attempt to force every string's encoding into an acceptable format.
                Clearly it's failing in your case...
                What is your normal system encoding ?
                Perhaps Fredo can comment...
                The other similar post's issue is again almost certainly because of the 'langue corƩenne' user-name encoding...
                • fredo6F Offline
                  This is related to the encoding of ENV["xxx"] variables, where LibFredo6 does try to convert them to UTF-8.
                  Could you open the Ruby console and type sequentially
                  • a = ENV["LOCALAPPDATA"]
                  • b = a.force_encoding("UTF-8")
                  • b.encoding (should return UTF-8)
                  Can you also type
                  • c = LibFredo6.get_dir_from_ENV("LOCALAPPDATA")
                  • c.encoding (should return UTF-8)
                  Thanks to report if there are errors.
                    ali_yonder
                    Thanx for reply TIG & Fredo
                    I am from Turkey nd there are 'ı,ü,ö' letters in my sytstem.
                    I've written
                    • b.encoding
                    to ruby conlose.
                    but it has failed again.
                    Error: #<RuntimeError: can't modify frozen String>
                    <main>:in force_encoding' <main>:in <main>'
                    SketchUp:1:in `eval'
                    b.encoding
                    Error: #<NoMethodError: undefined method encoding' for nil:NilClass> <main>:in <main>'
                    then, i ve written
                    • c.encoding
                    to ruby console, but it has failed again šŸ˜ž
                    <main>:in <main>' SketchUp:1:in eval'
                    c.encoding
                    Do u have any suggestion?
                    thanx all šŸ˜„
                      Try this slightly different way, which sidesteps reading in the frozen system string...
                      puts a = ENV["LOCALAPPDATA"]**+""** puts b.encoding puts b = a.force_encoding("UTF-8") puts b.encoding
                      Fredo needs to fix his coding, once we get to the bottom of this issue...
                      • fredo6F Offline
                        Apparently ENV["LOCALAPPDATA"] is not defined.
                        Could you type in the Ruby console
                        ENV["LOCALAPPDATA"].inspect
                        @TIG: indeed, in LibFredo6 code, I duplicate the original string before forcing encoding. Just forgot this detail here.
                          So whenever any of us intend to use a 'frozen reference' we need to use something like:
                          a = ENV["LOCALAPPDATA"]+""
                          to make a copy of it to work on šŸ˜‰
                            ali_yonder
                            Thanx for replies again šŸ˜„
                            i've written ENV["LOCALAPPDATA"].inspect
                            "C:\Users\Ali Y\xF6nder\AppData\Local"
                            • fredo6F Offline
                              Many thanks
                              Then can you type the commands suggested by TIG
                              puts a = ENV["LOCALAPPDATA"]+"" puts a.encoding puts b = a.force_encoding("UTF-8") puts b.encoding
                              and add this one
                              puts a = ENV["LOCALAPPDATA"].encode("UTF-8")
                              IMPORTANT: your profile says you use Sketchup 8. Is that correct?
                                ali_yonder
                                Thanx fredo. I use sketchup 2017. i have to update my profile.
                                i've written these
                                puts a.encoding
                                puts b.encoding
                                and ruby said;
                                puts a.encoding
                                Windows-1254
                                puts b.encoding
                                UTF-8
                                C:\Users\Ali Yƶnder\AppData\Local
                                but still my problem is not solved. maybe i have to format my pc. i do not know.
                                • fredo6F Offline
                                  Ali,
                                  You need to type the commands one by one.
                                  Apparently the last one seems to work.
                                  Could send me a private message with an email address where I can send you a modified version of LibFredo6.
                                  To be sure, can you type separately the 3 commands below:
                                  a.encoding
                                  a.gsub(/\\/, "/")
                                  The last one should return the path with \ replaced by /
                                  • fredo6F Offline
                                    The problem should be resolved with the new version 8.1e.
                                    Many thanks to Ali
                                    • fredo6F Offline
                                      NEW RELEASE: LibFredo6 v8.1e - 13 Mar 18
                                      LibFredo6 8.1e is a maintenance release dedicated to solving (again) occasional issue on Windows when the username contains non-ascii characters.
                                        mgfranz
                                        After downloading and installing the latest version, I am getting these errors;
                                        Error Loading File C:/Users/mgfranz/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6/top_LibFredo6.rbe
                                        Failed to read RBE/RBS file.
                                        Error: #<NameError: uninitialized constant LibFredo6_Loader::LibFredo6>
                                        C:/Users/mgfranz/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:64:in process' C:/Users/mgfranz/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:71:in module:LibFredo6_Loader'
                                        C:/Users/mgfranz/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:28:in <top (required)>' Error Loading File Fredo6_RoundCorner.rb Error: #<TypeError: can't convert nil into an exact number> C:/Users/mgfranz/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:80:in -'
                                        C:/Users/mgfranz/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:80:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require'
                                        C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require' C:/Users/mgfranz/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_RoundCorner.rb:47:in module:Fredo6'
                                        C:/Users/mgfranz/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_RoundCorner.rb:26:in `<top (required)>'
                                        I have full permissions on all folders in my Sketchup Plugins folder.
                                        "If you like what you do, it will never be work..."
                                        In memory of Sam Maloof, 1916-2009
                                          After reinstalling the Lib have you restarted SketchUp 2016 ?
                                            mgfranz
                                            Yes, of course. That's when I receive the error window.
                                            • 59
                                            • 60
                                            • 61
                                            • 62
                                            • 63
                                            • 109
                                            • 110
                                            • 61 / 110
