    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 971.2k Views 155 Watching
    • fredo6F
      NEW RELEASE: JointPushPull Interactive v4.3a - 24 Feb 18
      JointPushPull Interactive 4.3a is a maintenance release:
      • **Bug fixing
      • [b]Introduction of Molding for Normal, Exytrude and Joint Tools (see video)
      JointPushPull 4.3a requires [b]LibFredo6 8.1** or above
      See plugin home page of JointPushPull for Download of JointPushPull.
      Main Post of the JointPushPull thread on this forum
        johnnygitarr
        hi fredo6,
        thnx for the update.
        i have troubles with the plugin icons, since the last update
        of curviloft and jointpushpull (sketchup pro 2018, mac os 10.13.3)
        the icons look now like the attached screenshot.
        i don't finde the molding option in the tool.
        can someone help me here?
        … found it, you have to show "more options"
        in the tools
        thnx in advance
        cheers
        johnny
        • fredo6F
          For Sketchup versions above SU2016, I now use SVG icons, which look like this
          I guess this is supported on Mac...!!
          EDIT: It seems on Mac, the icons files should in .PDF, whereas they are in SVG on Windows. Best is to update LibFredo6 to v8.1b, which fixes the problem for Mac.
            johnnygitarr
            hi fredo,
            with the latest update of libfredo now the icons working again.
            thnx for help!
            cheers and have a good weekend
            • E
              Einstein
              Thank you for update
              but...
              the behaviour of LOCAL XYZ vector extrusion didn't change. When we tick LOCAL, it still sticks to global axes.
              • fredo6F
                but...
                The problem was simply visual, with the Axis direction not shown correctly. I fixed it in 4.3a.
                As a reminder, the Local flag is only useful in relation with locking standard axes X, Y or Z (with arrows).
                When there is no axis lock, then the direction is whatever you pick in the model, Local or not Local.
                Also as a reminder, when you start JPP Vector, it is locked with the previous directions (in case you wish to re-use it). Just press Shift to unlock it.
                Thanks to advise
                • fredo6F
                  NEW RELEASE: JointPushPull Interactive v4.3b - 25 Feb 18
                  JointPushPull Interactive 4.3b includes PDF vector icons for Mac (thanks to Rich OBrien)
                  JointPushPull 4.3b requires LibFredo6 8.1b or above
                  • fredo6F
                    To Mac users.
                    I am testing the Vector-based icons for Joint Push Pull on Mac, which requires icon files in PDF formats.
                    Attached is the one for the JPP Quick Launcher.
                    JPP_icon_QuickLauncher.pdf
                    Could a kind Mac user downnload it and put it the folder Fredo6_JointPushPull/IMAGES_Standard, and then restart Sketchup to see if the icon displays OK.
                    EDIT: Just test version 4.3b on Mac to see if toolbar icons display well.
                    Many thanks
                    • E
                      Einstein
                      Perhaps it's my misunderstanding but it still goes along global, no local
                      • fredo6F
                        How did you set the X direction: via keyboard or clicking on the palette button?
                        • E
                          Einstein
                          Tried both with the same result.
                          • fredo6F
                            Could you post your model, because I don't see where this weird direction in red comes from.
                            • E
                              Einstein
                              It comes from global X axis. Local is ignored.
                              vector pushpull.skp
                              • CadFatherC
                                CadFather
                                had to go back to previous version, as often the pushpull goes the opposite way. can't find the reason but will keep posted if i experiment more with it.
                                • fredo6F
                                  Thanks to elaborate on this, while I am at fixing JPP.
                                  Is it when you type in the VCB, or when you drag, or when you drag and then use the VCB?
                                  • CadFatherC
                                    CadFather
                                    just when i drag - typing a negative/positive value works as expected
                                    • fredo6F
                                      Not clear
                                      • one particular tool or all tools?
                                      • if you drag, how does this happen exactly?
                                      • fredo6F
                                        NEW RELEASE: JointPushPull Interactive v4.3c - 27 Feb 18
                                        JointPushPull Interactive 4.3c fixes bugs in the Vector tool, as signaled by Einstein (see this post). You also need to upgrade LibFredo6 to v8.1c.
                                        JointPushPull 4.3c requires LibFredo6 8.1c or above
                                        • CadFatherC
                                          CadFather
                                          like here, but it happens on others too (ie. follow etc.)
                                          • fredo6F
                                            Impressive, clearly a bug or a mystery.
                                            Could you post the model, so that I try to understand what happens.
                                            EDIT: I could reproduce the problem (when the group is upside down). Fixing it. Thanks for signaling.
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 30
                                            • 31
                                            • 15 / 31
