    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 951.1k Views 155 Watching
    • fredo6F
      @Einstein
      I am not clear with your request.
      But if you look for the old Joint Push Pull, here it is.
      • E
        Einstein
        @fredo6 said:
        @Einstein
        Thank you.
        I meant, if I choose "vector pushpull" and tick LOCAL, the extrusion along X, Y or Z still does not respect gropu's local axes but global axes of model. I am referring to the new version of plugin.
        • fredo6F
          You'right. There is a problm there.
          Actually, in Local mode, the Vector Push Pull does follow the local direction, but the visual dashed line shows the direction wrongly (in model coordinates).
          I'll fix it and republish.
          Thanks for signaling.
          • fredo6F
            NEW RELEASE: JointPushPull Interactive v4.3a - 24 Feb 18
            JointPushPull Interactive 4.3a is a maintenance release:
            • **Bug fixing
            • [b]Introduction of Molding for Normal, Exytrude and Joint Tools (see video)
            JointPushPull 4.3a requires [b]LibFredo6 8.1** or above
            See plugin home page of JointPushPull for Download of JointPushPull.
            Main Post of the JointPushPull thread on this forum
              johnnygitarr
              hi fredo6,
              thnx for the update.
              i have troubles with the plugin icons, since the last update
              of curviloft and jointpushpull (sketchup pro 2018, mac os 10.13.3)
              the icons look now like the attached screenshot.
              i don't finde the molding option in the tool.
              can someone help me here?
              … found it, you have to show "more options"
              in the tools
              thnx in advance
              cheers
              johnny
              • fredo6F
                For Sketchup versions above SU2016, I now use SVG icons, which look like this
                I guess this is supported on Mac...!!
                EDIT: It seems on Mac, the icons files should in .PDF, whereas they are in SVG on Windows. Best is to update LibFredo6 to v8.1b, which fixes the problem for Mac.
                  johnnygitarr
                  hi fredo,
                  with the latest update of libfredo now the icons working again.
                  thnx for help!
                  cheers and have a good weekend
                  • E
                    Einstein
                    Thank you for update
                    but...
                    the behaviour of LOCAL XYZ vector extrusion didn't change. When we tick LOCAL, it still sticks to global axes.
                    • fredo6F
                      but...
                      The problem was simply visual, with the Axis direction not shown correctly. I fixed it in 4.3a.
                      As a reminder, the Local flag is only useful in relation with locking standard axes X, Y or Z (with arrows).
                      When there is no axis lock, then the direction is whatever you pick in the model, Local or not Local.
                      Also as a reminder, when you start JPP Vector, it is locked with the previous directions (in case you wish to re-use it). Just press Shift to unlock it.
                      Thanks to advise
                      • fredo6F
                        NEW RELEASE: JointPushPull Interactive v4.3b - 25 Feb 18
                        JointPushPull Interactive 4.3b includes PDF vector icons for Mac (thanks to Rich OBrien)
                        JointPushPull 4.3b requires LibFredo6 8.1b or above
                        • fredo6F
                          To Mac users.
                          I am testing the Vector-based icons for Joint Push Pull on Mac, which requires icon files in PDF formats.
                          Attached is the one for the JPP Quick Launcher.
                          JPP_icon_QuickLauncher.pdf
                          Could a kind Mac user downnload it and put it the folder Fredo6_JointPushPull/IMAGES_Standard, and then restart Sketchup to see if the icon displays OK.
                          EDIT: Just test version 4.3b on Mac to see if toolbar icons display well.
                          Many thanks
                          • E
                            Einstein
                            Perhaps it's my misunderstanding but it still goes along global, no local
                            • fredo6F
                              How did you set the X direction: via keyboard or clicking on the palette button?
                              • E
                                Einstein
                                Tried both with the same result.
                                • fredo6F
                                  Could you post your model, because I don't see where this weird direction in red comes from.
                                  • E
                                    Einstein
                                    It comes from global X axis. Local is ignored.
                                    vector pushpull.skp
                                    • CadFatherC
                                      CadFather
                                      had to go back to previous version, as often the pushpull goes the opposite way. can't find the reason but will keep posted if i experiment more with it.
                                      • fredo6F
                                        Thanks to elaborate on this, while I am at fixing JPP.
                                        Is it when you type in the VCB, or when you drag, or when you drag and then use the VCB?
                                        • CadFatherC
                                          CadFather
                                          just when i drag - typing a negative/positive value works as expected
                                          • fredo6F
                                            Not clear
                                            • one particular tool or all tools?
                                            • if you drag, how does this happen exactly?
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 30
                                            • 31
                                            • 15 / 31
