    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 916.9k Views 155 Watching
    • panixiaP Offline
      panixia
      @fredo6 said:
      If I understood well, you would like that in the offset surface, each quad is also composed of 2 co-planar triangles, whereas JPP does not make the triangles co-planar for each quad.
      No sir, I don't need them to be coplanar: I mean they preserve pseudo/non-planar quads as per Thomthom's Quadface Tools definition.
      403 Forbidden
      (sketchucation.com)
      That very same standard is found in Curviloft and in Trupaint "Quad Mapping Method", you added it at some point and works 100% bulletproof, whereas in JPP offsetted pseudo-quad faces are preserved, while extruded borders create "broken quads" with shadow-casting diagonals.. I suppose Thom is able to explain this better than me.. 🤓
      • fredo6F Offline
        NEW RELEASE: JointPushPull Interactive v4.2a - 12 Nov 17
        JointPushPull Interactive 4.2a is a maintenance release:
        • Diagonals for faces and borders are now created with the quad convention for diagonals, that is: Soft, Smooth, Hidden and NOT casting shadows
        • Shading of the wireframe preview, based on a suggestion and code from Eneroth3
        JointPushPull 4.1a requires LibFredo6 8.0 or above
        See plugin home page of JointPushPull for Download of JointPushPull.
        Main Post of the JointPushPull thread on this forum
        • panixiaP Offline
          panixia
          @fredo6 said:
          [*]Diagonals for faces and borders are now created with the quad convention for diagonals, that is: Soft, Smooth, Hidden and NOT casting shadows
          Thank you sooooo much!!! 🎉
          I don't have sketchup on this pc but I'll try this as soon as possible.
            Thank you very much for these updates Fredo!
            • boofredlayB Offline
              boofredlay
              Thank you Fredo!
                tomaszdrgas
                I have little bug for JPP. Seems to be related to different matherials used for fases and edges since clearing all the materials to default helps..
                I often use different material for edges to make them look lighter on jpgs,so it actually happens a lot..
                I gave to it all default mat. and tried to replicate the error. (I marked the selection in red copied in front of it.) I added again different material to the 2 middle horizontal edges (everything else default). Still working. I added different mat. for fases sorrounding edges and it still worked. I added more mat. to all faces neighbouring with the selection to be pushedpull. Erra..
                I attached file..
                J-Fredo cleared.skp
                • E Offline
                  Einstein
                  Is it possible to perform Joint Push Pull on both sides (positive + negative offset) in one go?
                  Every time I have to exit tool, select faces again and again run the tool typing opposite value.
                  • E Offline
                    Einstein
                    @fredo6 said:
                    @dtrarch said:
                    Dear Fredo
                    If it is at all possible please make the old JPP version work in SU2014?
                    The old version was so elegant and simple and while the new and improved will do more, for me it just crashes, loses object elements and the settings do not do what they are told to do.
                    I will be pleased to the first to add to your cookie jar if we could have the option to choose the JPP version to install.
                    SU user since V2 and honestly I did install the new JPP properly too.
                    I cleaned out the old version (.....roaming/sketchup and such as well)
                    Thanks and please
                    dtr
                    The old version (v2.1a) is still available at the following post.
                    It is compatible with SU2014.
                    You can run the new and old versions concurrently.
                    PS: do you get bugsplats or intercepted crashes (with a clean dialog box)? And If so, is it during the geometry generation?
                    Hi!
                    Sorry for bringing up oldish answers but the problem still remains. I have exactly the same problem as Xiombarg - cannot pushpull faces along group's local direction (X,Y,Z). I did what Dave suggested - "removed" all plugins (by renaming Plugins folder and creating a new one only for LibFredo ad JointPushPull) to see if any plugin influences behaviour of JPP - none of them does, I assume. (Only v-ray, laubwerk and adv camera tools remained) Then tried to use link you gave to download an old version of JPP - "the requested topis does not exis", says sketchucation.
                    • fredo6F Offline
                      @Einstein
                      I am not clear with your request.
                      But if you look for the old Joint Push Pull, here it is.
                      • E Offline
                        Einstein
                        @fredo6 said:
                        @Einstein
                        Thank you.
                        I meant, if I choose "vector pushpull" and tick LOCAL, the extrusion along X, Y or Z still does not respect gropu's local axes but global axes of model. I am referring to the new version of plugin.
                        • fredo6F Offline
                          You'right. There is a problm there.
                          Actually, in Local mode, the Vector Push Pull does follow the local direction, but the visual dashed line shows the direction wrongly (in model coordinates).
                          I'll fix it and republish.
                          Thanks for signaling.
                          • fredo6F Offline
                            NEW RELEASE: JointPushPull Interactive v4.3a - 24 Feb 18
                            JointPushPull Interactive 4.3a is a maintenance release:
                            • **Bug fixing
                            • [b]Introduction of Molding for Normal, Exytrude and Joint Tools (see video)
                            JointPushPull 4.3a requires [b]LibFredo6 8.1** or above
                              johnnygitarr
                              hi fredo6,
                              thnx for the update.
                              i have troubles with the plugin icons, since the last update
                              of curviloft and jointpushpull (sketchup pro 2018, mac os 10.13.3)
                              the icons look now like the attached screenshot.
                              i don't finde the molding option in the tool.
                              can someone help me here?
                              … found it, you have to show "more options"
                              in the tools
                              thnx in advance
                              cheers
                              johnny
                              • fredo6F Offline
                                For Sketchup versions above SU2016, I now use SVG icons, which look like this
                                I guess this is supported on Mac...!!
                                EDIT: It seems on Mac, the icons files should in .PDF, whereas they are in SVG on Windows. Best is to update LibFredo6 to v8.1b, which fixes the problem for Mac.
                                  johnnygitarr
                                  hi fredo,
                                  with the latest update of libfredo now the icons working again.
                                  thnx for help!
                                  cheers and have a good weekend
                                  • E Offline
                                    Einstein
                                    Thank you for update
                                    but...
                                    the behaviour of LOCAL XYZ vector extrusion didn't change. When we tick LOCAL, it still sticks to global axes.
                                    • fredo6F Offline
                                      but...
                                      The problem was simply visual, with the Axis direction not shown correctly. I fixed it in 4.3a.
                                      As a reminder, the Local flag is only useful in relation with locking standard axes X, Y or Z (with arrows).
                                      When there is no axis lock, then the direction is whatever you pick in the model, Local or not Local.
                                      Also as a reminder, when you start JPP Vector, it is locked with the previous directions (in case you wish to re-use it). Just press Shift to unlock it.
                                      Thanks to advise
                                      • fredo6F Offline
                                        NEW RELEASE: JointPushPull Interactive v4.3b - 25 Feb 18
                                        JointPushPull Interactive 4.3b includes PDF vector icons for Mac (thanks to Rich OBrien)
                                        JointPushPull 4.3b requires LibFredo6 8.1b or above
                                        • fredo6F Offline
                                          To Mac users.
                                          I am testing the Vector-based icons for Joint Push Pull on Mac, which requires icon files in PDF formats.
                                          Attached is the one for the JPP Quick Launcher.
                                          JPP_icon_QuickLauncher.pdf
                                          Could a kind Mac user downnload it and put it the folder Fredo6_JointPushPull/IMAGES_Standard, and then restart Sketchup to see if the icon displays OK.
                                          EDIT: Just test version 4.3b on Mac to see if toolbar icons display well.
                                          Many thanks
                                          • E Offline
                                            Einstein
                                            Perhaps it's my misunderstanding but it still goes along global, no local
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 30
                                            • 31
                                            • 15 / 31
