    [Plugin][$] VisuHole - v1.5a - 01 Apr 24
    103 Posts 39 Posters 124.8k Views 39 Watching
      bharralure
      Bonjour Fredo, et merci d'avoir bien voulu prendre ma demande en considération, mais sachez que ce n'est pas une obligation, mais simplement une suggestion, surtout qu'il est possible de ressouder manuellement ces arcs et cercles, pour retrouver facilement, par inférence, leur centre par exemple (très utile, entre autre, pour la cotation).
        rv1974
        cutting crossing window\polyline would be amazing spin-off.
        • fredo6F Offline
          And on top of that, it does a chamfering of the intersection!
          ...and keep everything as a solid!
          what else?
            rv1974
            actually when I thought for 2nd time (after first wows!) I realized it hardly can be a precise tool- not so suitable for archviz (my case). could be good for conceptual doodling.
              rv1974
              what else?
              hehe don't you start..
              from 31m00s- grooving 😲
              or even better:
              • fredo6F Offline
                I feel like playing in the schoolyard when seeing these videos.
                Must be a trick, because the first time I played with Blender, I gave up after 2 hours and never came back.
                  rv1974
                  well after watching those ones I have rough idea what indians felt seenig gunned conquistadors on horses for a first time 😆
                    jtri
                    I have some some great uses for this plugin in my modeling, thanks. But when using Drill thru with nested components I get expected results. When using carve I do not see the colors of the nested components. To see the colors I would need to go clean up the model. Is this to be expected with this plugin or operator error? Top model in my example has been cleaned up.
                    Visuhole.skp
                    • fredo6F Offline
                      Yes, when the carving has the same size that the component, you need some cleanup of the thin faces left over by VisuHole. Unfortunately, the intersection in Sketchup is not always predictable for these special cases, and also, since components are separate, you may not want the cleanup.
                        jtri
                        Thanks for all your plugins and your support!
                          gnome_mo
                          @pants said:
                          Fredo,
                          Hope you got time for this, because it feels so close...anyway, can you confirm that you're able to make up new stencils and have them work as "punches?" I've found this only works for me if I use your "stock" three sample stencils - the ones you provided as defaults. It lets me pick a new shape that turns yellow and shows all signs of being ready to make a hole, but when I double-click, or try to "orient," etc...no hole results...just a "time elapsed" display.
                          I also have some Sketchucation plugins-vs-extensions issues/possible confusion. Plugin manager shows current 2/4 version. Later, after finding I was still having problems, I noticed the SUcation Extensions manager still showed the old version (now disabled). I keep thinking there's a need to delete/uninstall old versions, not just disable. Apparently one can disable a plugin and still find that it shows up as the old version, active, but in the SUcation extensions manager. Confusing, to me, anyway.
                          Mahalo - Dave
                          I have the very same problem. Haven't managed even all default shapes, circle yes and polygon yes, but rectangle doesn't drill. Neither does my shape. (Rougly - looks like letter "T").
                          I'm trilling through a floor made of 700 planks.
                          Pants, did you manage to drill yours?
                            With any image or file it's difficult to say something! 😄
                            Else I see no dificulties to make some drills on floors, walls etc...
                            Just select before your objects then call the crazzy VisuHole! 😄
                            One of my favorite when you can't use Boolean function who don't existing on the Make Versions! 😉
                            Here all object is a Group, and view Front Face
                            (will be the same if wall was a floor ! So from View Top)
                            Will be of course the same if the form was a "T" 😉
                              gnome_mo
                              Here's the file:
                              Dropbox
                              (www.dropbox.com)
                                With a file its' very more easy to answer! ☀
                                Always post a file is the Golden Rule! 🤓
                                It's because your objets are not VOLUMES!!! 😮
                                They have no bottom! 💚
                                They are not homogeneous!
                                It's more difficult for VisuHole!
                                Your objets must be "manifold" without space between us!
                                So draw them "pasted" like my drawing above then use VisuHole then Exploded view" X,Y! 😉
                                  gnome_mo
                                  I didn't think that was the problem, since it drilled simple circle, no problem.
                                  But I really need those spaces between them, is it at all possible?
                                    Seems you can't!
                                    But if you draw a rectangular box between the 2 existing that will works! 😉
                                    So not a big deal if you know that from the beginning! 😄
                                    Just erase the "Joint(s)" at the end! 😄
                                      Something like this 😄
                                        jeff1harmed
                                        I downloaded and installed VisuHole_v1.4b. I got random results on curved surfaces, and frequent crashes on SU2017. Great potential but unrealised in my case and I had to uninstall
                                          Did you also install the latest Lib Fredo ?
                                            kochmichi86
                                            I have a problem with trying to bend small letters (1cm) on a cylinder as the picture shows in the attachement.
                                            Could anyone help ?
                                            • 5 / 6
