    [Plugin][$] VisuHole - v1.5a - 01 Apr 24
    104 Posts 40 Posters 138.9k Views 39 Watching
    • fredo6F Offline
      Ken,
      OK. Got it. and it makes a lot of sense.
      Just a bug I will fix.
      Thanks for signaling.
      • fredo6F Offline
        NEW RELEASE: VisuHole v1.4b - 12 Oct 17
        VisuHole 1.4b is a miantenance release:
        • fix a problem where pre-selection was lost after an operation
        • certified SU2017
        • Support of Hi-res screen
        • compatibility OSX High Sierra
        Note: v1.4a, published also on 12 Oct had a bug left. So better take v1.4b
        The fix for Pre-selection concerns a bug signaled by Ken.
        See main post of this thread for Download of VisuHole.
        • kenK Offline
          ken
          Thanks you Fredo. It works just like I need.
          Short story. I have had this plugin on my computer for sometime, I never could get it to drill consistance holes. So I started this new project and I have way to many holes to drill holes as I have been doing. So I made a concerted effort to learn the plugin. I knew the problem was with me, because no one else was complaining. Than I found one of my problems, the "group in" and "group out". Didn't quite understand what was happening there. Figured that out and watch the video over and over. Trying to see the exact setup in the menu.
          The other times I just gave up, had stuff to do. But this time I just kept at it. Then I found the post about guidelines and guide points. Then I knew it should work with more that one guideline or point. So now I knew I wasn't the problem.
          I am grateful for all of your plugins.
            bharralure
            2017-10-13 09_47_12-Sans titre - SketchUp Make 2017.jpgBonjour Fredo,
            Juste un souhait qui n'est peut-être pas réalisable : est-il possible que VisuHole n'explose pas les courbes, arcs et autre cercles, et ainsi ne pas perdre les inférences et autres renseignements disponibles dans "Info sur l'entité" ?
            D'avance merci.
            • fredo6F Offline
              @bharralure said:
              [attachment=0:2s4g1kip]<!-- ia0 -->2017-10-13 09_47_12-Sans titre - SketchUp Make 2017.jpg<!-- ia0 -->[/attachment:2s4g1kip]Bonjour Fredo,
              D'avance merci.
              Not obvious, but I'll think of it in a next version.
                bharralure
                Bonjour Fredo, et merci d'avoir bien voulu prendre ma demande en considération, mais sachez que ce n'est pas une obligation, mais simplement une suggestion, surtout qu'il est possible de ressouder manuellement ces arcs et cercles, pour retrouver facilement, par inférence, leur centre par exemple (très utile, entre autre, pour la cotation).
                  rv1974
                  cutting crossing window\polyline would be amazing spin-off.
                  • fredo6F Offline
                    And on top of that, it does a chamfering of the intersection!
                    ...and keep everything as a solid!
                    what else?
                      rv1974
                      actually when I thought for 2nd time (after first wows!) I realized it hardly can be a precise tool- not so suitable for archviz (my case). could be good for conceptual doodling.
                        rv1974
                        what else?
                        hehe don't you start..
                        from 31m00s- grooving 😲
                        or even better:
                        • fredo6F Offline
                          I feel like playing in the schoolyard when seeing these videos.
                          Must be a trick, because the first time I played with Blender, I gave up after 2 hours and never came back.
                            rv1974
                            well after watching those ones I have rough idea what indians felt seenig gunned conquistadors on horses for a first time 😆
                              jtri
                              I have some some great uses for this plugin in my modeling, thanks. But when using Drill thru with nested components I get expected results. When using carve I do not see the colors of the nested components. To see the colors I would need to go clean up the model. Is this to be expected with this plugin or operator error? Top model in my example has been cleaned up.
                              Visuhole.skp
                              • fredo6F Offline
                                Yes, when the carving has the same size that the component, you need some cleanup of the thin faces left over by VisuHole. Unfortunately, the intersection in Sketchup is not always predictable for these special cases, and also, since components are separate, you may not want the cleanup.
                                  jtri
                                  Thanks for all your plugins and your support!
                                    gnome_mo
                                    @pants said:
                                    Fredo,
                                    Hope you got time for this, because it feels so close...anyway, can you confirm that you're able to make up new stencils and have them work as "punches?" I've found this only works for me if I use your "stock" three sample stencils - the ones you provided as defaults. It lets me pick a new shape that turns yellow and shows all signs of being ready to make a hole, but when I double-click, or try to "orient," etc...no hole results...just a "time elapsed" display.
                                    I also have some Sketchucation plugins-vs-extensions issues/possible confusion. Plugin manager shows current 2/4 version. Later, after finding I was still having problems, I noticed the SUcation Extensions manager still showed the old version (now disabled). I keep thinking there's a need to delete/uninstall old versions, not just disable. Apparently one can disable a plugin and still find that it shows up as the old version, active, but in the SUcation extensions manager. Confusing, to me, anyway.
                                    Mahalo - Dave
                                    I have the very same problem. Haven't managed even all default shapes, circle yes and polygon yes, but rectangle doesn't drill. Neither does my shape. (Rougly - looks like letter "T").
                                    I'm trilling through a floor made of 700 planks.
                                    Pants, did you manage to drill yours?
                                      With any image or file it's difficult to say something! 😄
                                      Else I see no dificulties to make some drills on floors, walls etc...
                                      Just select before your objects then call the crazzy VisuHole! 😄
                                      One of my favorite when you can't use Boolean function who don't existing on the Make Versions! 😉
                                      Here all object is a Group, and view Front Face
                                      (will be the same if wall was a floor ! So from View Top)
                                      Will be of course the same if the form was a "T" 😉
                                        gnome_mo
                                        Here's the file:
                                        Dropbox
                                        (www.dropbox.com)
                                          With a file its' very more easy to answer! ☀
                                          Always post a file is the Golden Rule! 🤓
                                          It's because your objets are not VOLUMES!!! 😮
                                          They have no bottom! 💚
                                          They are not homogeneous!
                                          It's more difficult for VisuHole!
                                          Your objets must be "manifold" without space between us!
                                          So draw them "pasted" like my drawing above then use VisuHole then Exploded view" X,Y! 😉
                                            gnome_mo
                                            I didn't think that was the problem, since it drilled simple circle, no problem.
                                            But I really need those spaces between them, is it at all possible?
                                            • 3 / 6
