    [Tutorial] Animator Quick Start
    renderpluginsextensions
    136 Posts 39 Posters 899.0k Views 40 Watching
    • jgbJ
      jgb
      @fredo6 said:
      Actually, I did not find a way to cover "Save, Load, Modify" with a single dialog box. If you have ideas, more than welcome.
      A bug. I just fixed it. Strange nobody signaled it.
      I will look at a combo as I gain experience with Animator.
      I like descriptive names, so spaces are needed between words. I dislike dashes.
      Others are more simplistic.
      jgb
        Dik Harrison
        Fredo, I like Animator far more than the other animation plug-ins I have for SU. I have made a number of animations in the past, but have not had the time of late, but the other day I was designing something for my workshop and decided I wanted to make another animation. I had installed Animator a while back, but had not had a project to try it out on. I am very impressed, It didn't take me neatly as long to create a video and the process was not only easy, but the control I have is marvelous.
        I do have one issue that I cannot resolve. I have an object moving linearly in sync with an object moving in an arc. I assumed I could use easing to match the liner motion to the movement of the arc, but I cannot figure out how this can be done. As can be seen in the video, the white post does not stay within the slot in the rotating arm.
        https://youtu.be/5R8BlZueUNY
        Have fun...
        Dik
        • fredo6F
          Dick,
          There is a problem with attachment in your post. I don't see it.
          Also, synchronisation of linear and circular movement is always tricky.
          In principle, Animator will try to help via the implementation of kinematics constraints in the future, for cases like crane and mechanical machines where you have hinges and anchors.
            Dik Harrison
            Yeah, I had to right click, copy and paste into the address bar. This is the link: https://www.youtube.com/watch?v=5R8BlZueUNY
            I guess until the next release, I'll just have to live with the lack of synchronicity.
            Thank you for such a great plug-in and all the others that I use all the time...
            Dik
            Have fun...
            Dik
            • fredo6F
              Dik,
              I see that you were able to tweak the synchronization and it looks good.
              I am interested in the mode to try a few things. So if you have time, could you PM it or post it.
                Dik Harrison
                I didn't tweak it, that is the result from your plug-in. I guess I'm just picky, but the post that is part of the gate should stay centered in the slot in the arm, and it doesn't. Anyway, I have tried to post or send the file every way I can think of and I always get a server error. The zipped file is only 4,284KB.
                Try this link: https://drive.google.com/drive/folders/0B_3KP1W09NjeR0psd1BwWktyZHc?usp=sharing
                Have fun...
                Dik
                • fredo6F
                  Dik,
                  Thanks. I got the model file.
                  Sorry if I don't understand. But if the black arm is locked by an hinge at the bottom and the actuator moves in a rigid direction, then I don't see how the center of the black arm could remain centered.
                  For me, it's pretty much the same as for the top of the arm. The center of the arm should also have an oblong hole.
                  Unless of course if you pivot the actuator, like this.
                  Again, not a specialist. I don't even know what the tool is for.
                  Anyway, a very good example to test some forward kinematics. So many thanks.
                    Dik Harrison
                    The actuator and arm are not the issue, they work well together. The problem is the stud that is attached to the gate (door). The gate moves linearly and the arm pivots at the bottom. The slot in the arm also pivots, but relative to the stud, at a different rate (linearly) at the beginning and of its arc.
                    This setup is to open the gate and turn on dust collection for my router table. This is a short post I did on this: https://ezsmart.blogspot.com/2017/11/semi-automatic-dust-collector-blast.html
                    I'm glad that this will help in continuing to develop Animator.
                    Take care,
                    Dik
                    Have fun...
                    Dik
                    • Smax4455S
                      Smax4455
                      Hello! I have a problem - I used wrong program to rendering video, so it don't render video, only images, reinstalling plugins don't helping. Where is CFG file, to remove the wrong program from plugin and add ffmpeg?
                      • fredo6F
                        Not sure I understand. What is a CFG file?
                        • L
                          lizcol
                          Hello Fredo - I am trying to use Animator as walk through - can you send instructions please?
                          thanks. Lisette
                          • fredo6F
                            thanks. Lisette
                            Lisette,
                            There is no specific instructions, except the videos posted in this forum and this thread.
                            Currently, there is no tool to support walk-through automatically (i.e. along a path). This will come soon.
                            In the meantime, you can define walk-through manually as a succession of views (or scenes) and adjusting them in the timeline.
                              dbrenders
                              is it possible to attach sketchup physics simulation footage?
                              • fredo6F
                                SketchyPhysics has it own module for animation and video recording.
                                • ArchiblogA
                                  Archiblog
                                  Hi Everyone!
                                  As Fredo hasn't created a playlist of his Animator videos on YouTube, I've taken the liberty of creating one. You can find it at:
                                  I hope it proves useful.
                                  NF
                                  • jgbJ
                                    jgb
                                    Archiblog
                                    VERY Useful. πŸ‘ πŸ‘ πŸ‘ πŸ€“
                                    Thank You.
                                    jgb
                                    • ArchiblogA
                                      Archiblog
                                      Hi jgb,
                                      Thanks for your reply to my previous post.
                                      On 16 August 2017 you said that you were doing a step-by-step self tutorial based on the words and videos at the top of this thread and that you would document your steps for potentially a detailed written tutorial.
                                      I'm considering doing something similar myself - to help me learn more about how to use Animator - and wonder if you are still intending to publish a written tutorial?
                                      Before getting started I downloaded and installed the Animator plugin from https://sketchucation.com/pluginstore?pln=Animator and the LibFredo6 shared plugin library from https://sketchucation.com/plugin/903-libfredo6.
                                      Starting with 'Animator Beta - Tutorial 1 - Preparing a Model' and fredo6's advice, here are the steps I've followed so far:
                                      (1) download Burkhard Heimlich's original model from https://sketchucation.com/forums/download/file.php?id=139360
                                      (2) download fredo6's model with animation from https://sketchucation.com/forums/download/file.php?id=139359
                                      (3) copy and rebuild Burkhard's model - i.e. grouping objects (components and groups); naming objects; and assigning objects to layers
                                      (4) reduce the scale of my rebuilt model by a factor of 0.4 and upload it to 3D Warehouse at https://3dwarehouse.sketchup.com/model/329bb204-84c8-421e-a77c-fe863782d9e1/Forklift-Truck
                                      (5) save the original position of the model.
                                      The next thing I'm going to do is copy and rescale the pallet, boxes and "tarmac" from fredo6's model and then I shall move on to 'Animator Beta - Tutorial 2 - Creating a First Animation'.
                                      I should appreciate any comments and advice on this procedure.
                                      NF
                                      • fredo6F
                                        @Archiblog
                                        First, thank you for your interest in Animator. Definitely, the script lacks from proper tutorial, and most of the videos are now a little bit outdated, as Animator has evolved in the meantime.
                                        I don't have the time to make new tutorial videos or user manual, so I am glad if you help on that while going through our learning curve.
                                        In the current state, Animator's framework should remain stable, but what can still change in the future are:
                                        • new category of animation of elements (like travelling camera, ove to target movements, etc...)
                                        • some elements of the decorations (pseudo-icons, timeline, ...)
                                        • some dialog boxes related to Positioner, video generation and possibly other areas.
                                        • jgbJ
                                          jgb
                                          Archiblog & Fredo
                                          I haven't forgotten my promise to create a tutorial. But soon after I started playing with Animator I got seriously sidetracked on some other (non SU oriented) project and just recently got back to using SU again. I have to clear much of that and then restart the Animator Tutorial, which I will need to learn to complete that SU project, in order to demonstrate how a very complex piece of machinery works.
                                          Animating SU models is something that has eluded me for many years. Since SketchyPhysics (which I found to have a too steep a learning curve) I have tried most so-called SU Animators, but found them either too complex or just unworkable for my needs.
                                          What I need is akin to SketchyPhysics but without the gravitational aspects and with better controls. I need to simply animate articulated models of aerospace components more than anything else. I'm hoping Fredo's Animator will do the trick, but haven't got into it far enough to say it will.
                                          If you want me to collaborate on a tutorial, I'm game on for that. Please PM me as we can best communicate by Email. This is not a convenient forum to do that, although we should update progress here for the "masses".
                                          jgb
                                            applemango85
                                            Could I ask a question?
                                            Love the plugin fredo - looks harder to use than it actually was so that was good news
                                            I'm making a few 60sec videos to show my boss a new way of presenting work. My settings was set at 20fps and speed of 0.75.
                                            However when playing the mov/MP4 file created I get a stutter every second or 2 - making it a bit unwatchable.
                                            Anyone come by the same problem?
                                            I can't post the video on the forum but I can private message it to anyone who think they can help.
                                            I'm trying one now at 45fps - seeing if that makes a difference
                                            There is a option to use QuickTime screen record to record a window once I've made the animater plugin film which will take a lot much less time to process but will take up much more mb- so perhaps not a solution
                                            • 3 / 7
