    3D Truss Models
    1.5k Posts 31 Posters 976.9k Views 30 Watching
    • medeekM Offline
      medeek
      Valley sets can get a little interesting when you start dealing with intersecting hip roofs. If the width of the projection were to increase the valley set would become a combination of standard valley trusses and flat top or hip valley trusses.
      http://design.medeek.com/resources/images/truss_su316_800.jpg
      View model here:
      3D Warehouse
      (3dwarehouse.sketchup.com)
      With the projection width extended:
      http://design.medeek.com/resources/images/truss_su317_800.jpg
      View model here:
      3D Warehouse
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        Version 2.0.9 - 11.25.2017
        • Structural outlookers (vert. & horz.) enabled under advanced roof options for Parallel Chord truss type.
        • Metal plate connectors now enabled for all parallel chord trusses.
        http://design.medeek.com/resources/images/truss_su318_800.jpg
        This truss type should now be up-to-date with all of the advanced options available:
        roof returns, gutters, ceiling drywall, ridge cap etc...
        design.medeek.com
        • medeekM Offline
          medeek
          I was discussing the plugin with a family friend and he suggested I offer a student version of the plugin (ie. fully functional but time limited to one year and purchase requires a student ID).
          I already offer a trial version (freemium model) that is limited in its functionality.
          Is there any need for this?
          design.medeek.com
          • pbacotP Offline
            Some sort of educational version might be good, or licensing to school or class that has an expiration so it is harder to pirate... It may be some teachers would like to use it to familiarize students with construction methods, besides the modelling aspect.
            • jujuJ Offline
              juju
              Is there some way you can incorporate a method for exporting/importing settings (user defined layers for example) in your various extensions? I'm migrating to a new machine and this seems like a useful feature, even though it may be one that will probably not be used a lot.
              • medeekM Offline
                medeek
                Version 2.1.0 - 11.28.2017
                • Added Northeast hip set trusses.
                • Enabled advanced options for northeast hip sets.
                • Added energy/raised heels for northeast hip set (3 variants: wedge, slider and vertical w/ strut).
                • Added the option for open vs. closed end jacks.
                • Added the option for a drop in purlin frame.
                • Enabled a graphical user interface for Truss Set selection.
                http://design.medeek.com/resources/images/truss_su319_800.jpg
                http://design.medeek.com/resources/images/truss_su320_800.jpg
                I only plan on adding the midwest and california variants if requested.
                I don't want to toot my own horn but these truss sets are quite complex, I'm still amazed that I've been able to finally write the code to generate all of this geometry. At first it is a bit overwhelming but when you break it down into its components and slowly grind each one out sooner or later it emerges.
                I still have not added plates to the truss hip sets due to the complexity and the fact that it is low on the priority list for now. Complex roof are currently my biggest hurdle and I am still battling with how to best approach these from a systematic standpoint and then dive into the details once the overall layout is configured.
                Until I have complex roofs figured out the plugin is only about halfway there, but at least I've got my foot in the door and I'm making progress.
                When you consider that you can create one of these hip truss sets literally in seconds with all of the sheathing, cladding, fascia, gutters etc... and it is all geometrically correct, it is pretty cool. Manually it would take me well over an hour to try and generate this level of detail without the plugin, there is something to be said for automation.
                design.medeek.com
                • medeekM Offline
                  medeek
                  I don't know how to do it on a Mac but if your running Windows you can probably pull the settings directly from the registry and then insert them back in on the new machine.
                  I will give this some thought.
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    The reason I am taking so long with complex rafter and truss roofs is the possible permutations is making things very challenging.
                    For example take the truss roof below:
                    http://design.medeek.com/resources/images/truss_su321_800.jpg
                    I'm assuming there are no interior bearing walls and we want to clearspan the entire building outline. I can get the basic roof and truss layout by creating to hip truss sets as primitives but that is where it then becomes very interesting.
                    As you can see there are two mid-building girder trusses that then catch the mono pitch sub-girders which are each supporting two common trusses. Next to the sub-girders is a small valley set (half valley) that fills in the roof behind the sub-girders.
                    The largest span is 36', which is reasonable. This appears to be the simplest way to truss this roof out but is probably not the only solution. A good truss technician could tell me how close I am to the optimal solution.
                    Granted the complex rafter roof is not IMHO as hard a problem but it also has similar difficulties and issues.
                    View model at this link:
                    3D Warehouse
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      C'est merveilleux, merci beaucoup.
                      design.medeek.com
                        I will make corrections on the post above! 😉
                        • medeekM Offline
                          medeek
                          French translation of the Roof Truss Menu:
                          http://design.medeek.com/resources/images/truss_su322_800.jpg
                          I will roll a sub revision so everyone can try it out.
                          design.medeek.com
                            It's a beginning! 😄
                            Have you a system of translation ?
                            Or I must edit some files ?
                            • medeekM Offline
                              medeek
                              I am still compiling the list of words and phrases, there are a lot of menus, too many.
                              design.medeek.com
                                That is the problem of very detailed program! 😉
                                Ps I can make an adpatation of this page in French! 😉
                                Only for the fun, (It's my hobby) ☀
                                So that will be a cool training for the future Panel's Truss Translation!
                                Yet made Twillight, Podium, FlexTools, Groboto (collector), ZBrush, SimLab Composer,
                                3DCoat (Manual), PolyBrush, Qubicle2, SUbD, Profil Builder2, Moi3D, GifCam, Monolith (manual), [url=http://visualizervf.weebly.com:26zyq7ev][u:26zyq7ev]Visualizer[/u:26zyq7ev][/url:26zyq7ev], [url=http://visualizervf.weebly.com:26zyq7ev][u:26zyq7ev]SolveSpace[/u:26zyq7ev][/url:26zyq7ev] etc...and so many UI, Manuals, curiosities etc...
                                I'm frightened by this list! 💚
                                • medeekM Offline
                                  medeek
                                  Wow, that is pretty amazing.
                                  design.medeek.com
                                    Look at your Private messages! 😉
                                    • medeekM Offline
                                      medeek
                                      As the number of advanced options have increased (common trusses) the user input menu has slowly grown in size until it is so large that it often does not fit the screen of many laptops and smaller screens.
                                      This problem has been well documented by a number of users for quite some time.
                                      This weekend I spent some time putting together a new HTML menu for advanced options for roof trusses:
                                      http://design.medeek.com/resources/images/truss_su323_800.jpg
                                      I still need to work out the metric version and also all of the language translations but otherwise I think it is almost ready to roll out.
                                      As you mouse over each of the options a 320x240 image will display as shown, hopefully clarifying the meaning or usage of each parameter/option.
                                      design.medeek.com
                                        Help Image is a very very good idea! 👍
                                        Very very first draft as you can see the "?" ! 😉
                                        Veuillez choisir les options avancées pour les fermes de toiture
                                        Roof and Wall Sheathing = Revêtement de Toiture et Revêtement Mural
                                        Roof Sheathing = Revêtement de Toiture
                                        Roof Sheating Thickness = Épaisseur du Revêtement de Toiture
                                        Gable Wall Sheathing = Revêtement Mural du Pignon
                                        sub-fascia = Sous-fascia ?
                                        sub-fascia type = Type de Sous-fascia ?
                                        sub-fascia width = Largeur de Sous-fascia ?
                                        sub-fascia depth = Profondeur de Sous-fascia ?
                                        rakeboard = ?
                                        gable overhang = Porte-à-faux du Pignon
                                        rake board width = Largeur ?
                                        rake board depth = Profondeur ?
                                        outloockers = Débords ?
                                        outlooker spacing = Espacement du Débord ?
                                        outlooker size = Taille du Débord ?
                                        structural outlookers = Débord Structurel ?
                                        outlooker @ roof peak = Débord @ Pointe de Toit ?
                                        heel blocking = Blocage du Talon ?
                                        heel block orientation = Orientation du Talon ?
                                        cladding = Revêtement
                                        roof cladding = Revêtement de Toiture
                                        hip and ridge cap = Capuchon de Croupe et de Faîtage ?
                                        gable wall cladding = Revêtement Mural du Pignon
                                        additional options = Options Supplémentaires
                                        soffit cut = Coupe de Soffite ?
                                        roof returns = Retours de Toit
                                        roof battens = Lattes de toit
                                        ceiling gypsum = Gypse de Plafond
                                        gutters = Gouttières
                                        dropped top chord = Panne Supérieure Lancée ?
                                          First glance! 😄 (must be refined)
                                          Veuillez sélectionner l'un des types de fermes suivants:
                                          Commun en W - Tunnel - Mono-Pente - Ciseaux - Empennage - Double-Pente
                                          Corde d'Arc (?) - Arceau de Barrique (?) - Polynésien - Bombé - Cathédrale - Plateau (?)
                                          Simple Ciseau - Simple Cathédrale - Shed - Voûte En Berceau (?) - Tunnel à la Mansart - Caisson
                                          Treillis - Cathédrale Symétrique - Studio en Berceau - Double Inversé - Corde Parallèle - Charpente
                                          Remarque: Les types de ferme Shed, Arceau de barrique, Studio en Berceau et Double Inversé sont en cours de développement et ne sont pas encore disponibles.
                                          • medeekM Offline
                                            medeek
                                            Version 2.1.1 - 12.04.2017
                                            • Enabled a graphical user interface for advanced options of roof trusses.
                                            design.medeek.com
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 75
                                            • 76
                                            • 22 / 76
