    3D Truss Models
    1.5k Posts 31 Posters 869.7k Views 30 Watching
      I will make corrections on the post above! 😉
      • medeekM Offline
        medeek
        French translation of the Roof Truss Menu:
        http://design.medeek.com/resources/images/truss_su322_800.jpg
        I will roll a sub revision so everyone can try it out.
        Nathaniel P. Wilkerson PE
        Medeek Engineering Inc
        design.medeek.com
          It's a beginning! 😄
          Have you a system of translation ?
          Or I must edit some files ?
          • medeekM Offline
            medeek
            I am still compiling the list of words and phrases, there are a lot of menus, too many.
            design.medeek.com
              That is the problem of very detailed program! 😉
              Ps I can make an adpatation of this page in French! 😉
              Only for the fun, (It's my hobby) ☀
              So that will be a cool training for the future Panel's Truss Translation!
              Yet made Twillight, Podium, FlexTools, Groboto (collector), ZBrush, SimLab Composer,
              3DCoat (Manual), PolyBrush, Qubicle2, SUbD, Profil Builder2, Moi3D, GifCam, Monolith (manual), [url=http://visualizervf.weebly.com:26zyq7ev][u:26zyq7ev]Visualizer[/u:26zyq7ev][/url:26zyq7ev], [url=http://visualizervf.weebly.com:26zyq7ev][u:26zyq7ev]SolveSpace[/u:26zyq7ev][/url:26zyq7ev] etc...and so many UI, Manuals, curiosities etc...
              I'm frightened by this list! 💚
              • medeekM Offline
                medeek
                Wow, that is pretty amazing.
                design.medeek.com
                  Look at your Private messages! 😉
                  • medeekM Offline
                    medeek
                    As the number of advanced options have increased (common trusses) the user input menu has slowly grown in size until it is so large that it often does not fit the screen of many laptops and smaller screens.
                    This problem has been well documented by a number of users for quite some time.
                    This weekend I spent some time putting together a new HTML menu for advanced options for roof trusses:
                    http://design.medeek.com/resources/images/truss_su323_800.jpg
                    I still need to work out the metric version and also all of the language translations but otherwise I think it is almost ready to roll out.
                    As you mouse over each of the options a 320x240 image will display as shown, hopefully clarifying the meaning or usage of each parameter/option.
                    design.medeek.com
                      Help Image is a very very good idea! 👍
                      Very very first draft as you can see the "?" ! 😉
                      Veuillez choisir les options avancées pour les fermes de toiture
                      Roof and Wall Sheathing = Revêtement de Toiture et Revêtement Mural
                      Roof Sheathing = Revêtement de Toiture
                      Roof Sheating Thickness = Épaisseur du Revêtement de Toiture
                      Gable Wall Sheathing = Revêtement Mural du Pignon
                      sub-fascia = Sous-fascia ?
                      sub-fascia type = Type de Sous-fascia ?
                      sub-fascia width = Largeur de Sous-fascia ?
                      sub-fascia depth = Profondeur de Sous-fascia ?
                      rakeboard = ?
                      gable overhang = Porte-à-faux du Pignon
                      rake board width = Largeur ?
                      rake board depth = Profondeur ?
                      outloockers = Débords ?
                      outlooker spacing = Espacement du Débord ?
                      outlooker size = Taille du Débord ?
                      structural outlookers = Débord Structurel ?
                      outlooker @ roof peak = Débord @ Pointe de Toit ?
                      heel blocking = Blocage du Talon ?
                      heel block orientation = Orientation du Talon ?
                      cladding = Revêtement
                      roof cladding = Revêtement de Toiture
                      hip and ridge cap = Capuchon de Croupe et de Faîtage ?
                      gable wall cladding = Revêtement Mural du Pignon
                      additional options = Options Supplémentaires
                      soffit cut = Coupe de Soffite ?
                      roof returns = Retours de Toit
                      roof battens = Lattes de toit
                      ceiling gypsum = Gypse de Plafond
                      gutters = Gouttières
                      dropped top chord = Panne Supérieure Lancée ?
                        First glance! 😄 (must be refined)
                        Veuillez sélectionner l'un des types de fermes suivants:
                        Commun en W - Tunnel - Mono-Pente - Ciseaux - Empennage - Double-Pente
                        Corde d'Arc (?) - Arceau de Barrique (?) - Polynésien - Bombé - Cathédrale - Plateau (?)
                        Simple Ciseau - Simple Cathédrale - Shed - Voûte En Berceau (?) - Tunnel à la Mansart - Caisson
                        Treillis - Cathédrale Symétrique - Studio en Berceau - Double Inversé - Corde Parallèle - Charpente
                        Remarque: Les types de ferme Shed, Arceau de barrique, Studio en Berceau et Double Inversé sont en cours de développement et ne sont pas encore disponibles.
                        • medeekM Offline
                          medeek
                          Version 2.1.1 - 12.04.2017
                          • Enabled a graphical user interface for advanced options of roof trusses.
                          design.medeek.com
                            new refinement! 😄
                            • Commun ( Classique en w) - Grenier( Habitable) - Mono-Pente - Ciseaux( Entrait Retroussé)- Empennage ( à coyeau) Double-Pente ( Asymétrique)
                            • Corde d'Arc (Arc) - Arceau de Barrique (Arc triangulé) - Polynésien ( tropicale)- Bombé ( entrait retroussé variante ou Polonceau ) - Cathédrale - Plateau(Double ferme articulée)
                            • Simple Ciseau - Simple Cathédrale - Clergé (Contemporaine ) - Voûte En Berceau (En voute ) - Grenier Surélevé ( à la Mansart)- Caisson ( à entrait décalé)
                            • Plat ( poutre treillis )- Cathédrale Symétrique ( treillis à deux pentes) - Studio en Berceau ( à entrait décalé) - Double Inversé ( double articulée) - Corde Parallèle - Charpente
                            https://img15.hostingpics.net/pics/255775ferme03.jpg
                            https://img15.hostingpics.net/pics/647757ferme02.jpg
                            https://img15.hostingpics.net/pics/484019ferme04.jpg
                            https://img15.hostingpics.net/pics/576001ferme01.jpg
                            • medeekM Offline
                              medeek
                              I am trying to understand how the Mac .plist file works. Is it similar to the registry? I have a client that is having some trouble with registering (inputting their serial into the global settings) and having their system save the serial number.
                              Unfortunately, I don't own a Mac so I am not much help. Does anyone use the plugin on a Mac and have had similar problems with saving the serial number? Where does one go to manually edit the .plist file and enter in the serial number manually.
                              design.medeek.com
                                glro
                                not only that
                                i had the same questions
                                so i bought a mac: https://en.wikipedia.org/wiki/Mac_Mini
                                sheap, you can use windows mouse, keyboard and screen
                                there are a few things to modify in the ruby code por windows, to make it work on a mac
                                • medeekM Offline
                                  medeek
                                  I am working on adding the heel blocking since it is an option listed in the advanced options.
                                  http://design.medeek.com/resources/images/truss_su324_800.jpg
                                  So far there has not been much call for this feature but a few people have inquired so I figured we might as well add it in for completeness. The red coloration is for clarity in the image above.
                                  I will probably add the option to allow for venting holes since this is fairly typical in my neck of the woods.
                                  design.medeek.com
                                  • pbacotP Offline
                                    Very important. Sometimes the heel blocking, when taller, is a truss manufactured square that might have sheathing.
                                    • medeekM Offline
                                      medeek
                                      I agree, I was investigating this a while back but I'm not sure yet what is standard practice, there could be a number of ways of handling this.
                                      http://res.cloudinary.com/engineering-com/image/upload/v1484676854/tips/SHEAR_PANELS_ego3xz.jpg
                                      http://res.cloudinary.com/engineering-com/image/upload/v1484694321/tips/SHEAR_PANELS2_vis1pr.jpg
                                      design.medeek.com
                                      • pbacotP Offline
                                        Those look nice. I think sometimes the truss blocking has a diagonal which would make it effective (but the engineer will want plywood on it anyway it seems). You can have the truss all the way to the top or the method you show allows (1) continuous plywood gets nailed to the top of the truss block and the solid block provides the shear nailing (2) sometimes decorative rafter tails are added which need to pass through the space above the truss block.
                                        • medeekM Offline
                                          medeek
                                          Featured on the SketchUp Extension Inspection:
                                          design.medeek.com
                                            Very enlighting video! 😎
                                            else (Always : https://trussfr.weebly.com 😉
                                            Truss Type = Type de Fermes
                                            (not sure to translate all names of this little list of part of trusses)
                                            King Post
                                            Queen Post
                                            Fink
                                            Howe
                                            Fan
                                            Mod Queen
                                            Double Fink
                                            Double Howe
                                            Mod Fan
                                            Triple Fink
                                            Quad Fink
                                            Out-to-Out Span = Portée Hors tout
                                            Top Chord Angle = Angle de Corde Supérieure (?)
                                            Overhang Left = Porte-à-faux Gauche
                                            Overhang Right   (Same as Left) = Porte-à-faux Droit (Identique au Gauche)
                                            TC Size = Taille TC (? à définir)
                                            BC Size = Taille BC (? à définir)
                                            Web Size = Taille (?)
                                            Ply Thickness = Epaisseur du Pli
                                            Raised Heel (No, Yes) =Talon surélevé (?) ( (Non, Oui)
                                            Heel Heigh = Hauteur du Talon (?)
                                            Bldg.lenght = Longueur Bâtiment
                                            Truss Spacing = Espacement de Ferme
                                            Gable End Trusses (Yes, No, Front) = Poutrelles d'extrémité (Oui, Non, Face Avant)
                                            Gable Stud Spacing = Espacement Goujons de Pignon (?)
                                            Adv. Roof Options (Yes, No) = Options Avancées de Toit (Oui, Non)
                                            PS
                                            Does the Messages' window data is self-adapting to the length of words ?
                                            • 62
                                            • 63
                                            • 64
                                            • 65
                                            • 66
                                            • 74
                                            • 75
                                            • 64 / 75
