    3D Truss Models
    1.5k Posts 32 Posters 1.7m Views 31 Watching
    • medeekM Offline
      medeek
      Version 2.1.1 - 12.04.2017
      • Enabled a graphical user interface for advanced options of roof trusses.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
        new refinement! 😄
        • Commun ( Classique en w) - Grenier( Habitable) - Mono-Pente - Ciseaux( Entrait Retroussé)- Empennage ( à coyeau) Double-Pente ( Asymétrique)
        • Corde d'Arc (Arc) - Arceau de Barrique (Arc triangulé) - Polynésien ( tropicale)- Bombé ( entrait retroussé variante ou Polonceau ) - Cathédrale - Plateau(Double ferme articulée)
        • Simple Ciseau - Simple Cathédrale - Clergé (Contemporaine ) - Voûte En Berceau (En voute ) - Grenier Surélevé ( à la Mansart)- Caisson ( à entrait décalé)
        • Plat ( poutre treillis )- Cathédrale Symétrique ( treillis à deux pentes) - Studio en Berceau ( à entrait décalé) - Double Inversé ( double articulée) - Corde Parallèle - Charpente
        https://img15.hostingpics.net/pics/255775ferme03.jpg
        https://img15.hostingpics.net/pics/647757ferme02.jpg
        https://img15.hostingpics.net/pics/484019ferme04.jpg
        https://img15.hostingpics.net/pics/576001ferme01.jpg
        • medeekM Offline
          medeek
          I am trying to understand how the Mac .plist file works. Is it similar to the registry? I have a client that is having some trouble with registering (inputting their serial into the global settings) and having their system save the serial number.
          Unfortunately, I don't own a Mac so I am not much help. Does anyone use the plugin on a Mac and have had similar problems with saving the serial number? Where does one go to manually edit the .plist file and enter in the serial number manually.
          design.medeek.com
            glro
            not only that
            i had the same questions
            so i bought a mac: https://en.wikipedia.org/wiki/Mac_Mini
            sheap, you can use windows mouse, keyboard and screen
            there are a few things to modify in the ruby code por windows, to make it work on a mac
            • medeekM Offline
              medeek
              I am working on adding the heel blocking since it is an option listed in the advanced options.
              http://design.medeek.com/resources/images/truss_su324_800.jpg
              So far there has not been much call for this feature but a few people have inquired so I figured we might as well add it in for completeness. The red coloration is for clarity in the image above.
              I will probably add the option to allow for venting holes since this is fairly typical in my neck of the woods.
              design.medeek.com
              • pbacotP Offline
                Very important. Sometimes the heel blocking, when taller, is a truss manufactured square that might have sheathing.
                • medeekM Offline
                  medeek
                  I agree, I was investigating this a while back but I'm not sure yet what is standard practice, there could be a number of ways of handling this.
                  http://res.cloudinary.com/engineering-com/image/upload/v1484676854/tips/SHEAR_PANELS_ego3xz.jpg
                  http://res.cloudinary.com/engineering-com/image/upload/v1484694321/tips/SHEAR_PANELS2_vis1pr.jpg
                  design.medeek.com
                  • pbacotP Offline
                    Those look nice. I think sometimes the truss blocking has a diagonal which would make it effective (but the engineer will want plywood on it anyway it seems). You can have the truss all the way to the top or the method you show allows (1) continuous plywood gets nailed to the top of the truss block and the solid block provides the shear nailing (2) sometimes decorative rafter tails are added which need to pass through the space above the truss block.
                    • medeekM Offline
                      medeek
                      Featured on the SketchUp Extension Inspection:
                      design.medeek.com
                        Very enlighting video! 😎
                        else (Always : https://trussfr.weebly.com 😉
                        Truss Type = Type de Fermes
                        (not sure to translate all names of this little list of part of trusses)
                        King Post
                        Queen Post
                        Fink
                        Howe
                        Fan
                        Mod Queen
                        Double Fink
                        Double Howe
                        Mod Fan
                        Triple Fink
                        Quad Fink
                        Out-to-Out Span = Portée Hors tout
                        Top Chord Angle = Angle de Corde Supérieure (?)
                        Overhang Left = Porte-à-faux Gauche
                        Overhang Right   (Same as Left) = Porte-à-faux Droit (Identique au Gauche)
                        TC Size = Taille TC (? à définir)
                        BC Size = Taille BC (? à définir)
                        Web Size = Taille (?)
                        Ply Thickness = Epaisseur du Pli
                        Raised Heel (No, Yes) =Talon surélevé (?) ( (Non, Oui)
                        Heel Heigh = Hauteur du Talon (?)
                        Bldg.lenght = Longueur Bâtiment
                        Truss Spacing = Espacement de Ferme
                        Gable End Trusses (Yes, No, Front) = Poutrelles d'extrémité (Oui, Non, Face Avant)
                        Gable Stud Spacing = Espacement Goujons de Pignon (?)
                        Adv. Roof Options (Yes, No) = Options Avancées de Toit (Oui, Non)
                        PS
                        Does the Messages' window data is self-adapting to the length of words ?
                        • medeekM Offline
                          medeek
                          Thank-you Pilou, I will add these phrases into the language file.
                          Yes, the SU menu automatically adjust for the length of the words so even though French is often more verbose than English it does not matter. I've noticed though that Russian has some problems rendering in the SU menus.
                          I would have liked to see the video dive into the advanced menus more but I realize there is far too much material to cover in such a short video.
                          design.medeek.com
                            Excellent! 👍
                            What is BC and TC size ? 😳
                            Minor Roof Family = Famille de Toit Secondaire
                            Gable Dormer = Lucarne de Pignon
                            Hit Dormer = Lucarne de Toit
                            Shed Dormer = Lucarne de Hangar
                            Gable Roof Minor = Pignon de Toit Secondaire (?)
                            Hip Roof Minor = Lucarne de Toit Secondaire (?)
                            Dutch Gable Roof Minor = Pignon de Toit Hollandais Secondaire (?)
                            The (?) does not signify that is forcefully false but can maybe be enhanced! 😉
                            Else works fine! 😄
                            • medeekM Offline
                              medeek
                              BC = Bottom Chord
                              TC = Top Chord
                              Web = Internal (web) members of truss
                              design.medeek.com
                                Thx for the Infos! ☀
                                • medeekM Offline
                                  medeek
                                  The license registration module was causing some problems in isolated cases so I've released a sub-rev. 2.1.1b to address that issue.
                                  If you are trying to enter in your serial number and it does not appear to take, first verify that you are not entering in any leading or trailing white spaces if that does not solve the problem you may be encountering the issue at top, in that case download the latest version which should address the issue fully.
                                  design.medeek.com
                                    Valley set chest => Panel de Noue
                                    Stepdown Hip Set => Panel de Panne de Rive Inclinée
                                    Terminal Hip Set => Panel de Sablière
                                    Northeast Hip Set => Panel de Linçoir
                                    Metal plate connectors = Connecteur Métallique Plat
                                    Gusset = Gousset
                                    Web = Membrure
                                    Web = Fiche & Contre-Fiche
                                    in this following Schema "Chantignole" is false : must be "Arbalétrier" ! 🤓
                                    https://media.ooreka.fr/public/image/plan-charpente-29-big-9926265.jpg
                                    • medeekM Offline
                                      medeek
                                      This week has been a bit tough for me to get any meaningful work done on any of the plugins, too many Christmas concerts, parties etc... but I guess its for the better. This weekend I will try to get out the update for the heel blocking and an update on the translations.
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        Version 2.1.2 - 12.18.2017
                                        • Enabled vertical and angled heel blocking within the advanced options for truss roofs.
                                        http://design.medeek.com/resources/images/truss_su325_800.jpg
                                        If you choose to enable vent holes the heelblock menu will prompt for the hole diameter. The vent hole algorithm will place vent holes in the heel blocking per the truss spacing:
                                        < 12 in. = 1 vent hole
                                        < 16 in. = 2 vent holes
                                        16 in. or greater = 3 vent holes
                                        Let me know if this makes sense, I can always modify it to meet any criteria. If this sort of thing varies a lot per locale I can also make it more user definable.
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          This type of heel blocking is very typical in my locale (Western Washington State):
                                          http://design.medeek.com/resources/images/truss_su326_800.jpg
                                          View model here:
                                          3D Warehouse
                                          (3dwarehouse.sketchup.com)
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            To end off the year with a bang and to thank our truss plugin clientele I have decided to reduce the license renewal fee for the Medeek Truss Plugin to $10.00 USD. This promotion will run until the end of this year (Dec. 31, 2017) and then the renewal price will return to its usual price of $20.00 USD.
                                            This year has been very busy with further developments of the truss and foundation plugins. I am looking forward to the new year and another full year of new features and even new plugins and tools.
                                            I've really appreciated all those who have actively contributed to the recent developments of the plugin, especially the translations.
                                            A Merry Christmas to all and a Happy New Year.
                                            design.medeek.com
                                            • 48
                                            • 49
                                            • 50
                                            • 51
                                            • 52
                                            • 76
                                            • 77
                                            • 50 / 77
