[Plugin Library] LibFredo6 - v14.5b - 24 May 24
Thanks for the reply TIG. I have tried all of the above, I think. The extension manager shows the plug ins there however When I start Sketchup 2017 make I get all kinds of error messages about not being able to read a bunch of files. I have even tried re-installing sketchup and still I get nothing. I'll get rid of every thing I have tried and then start over using your instructions.
Could you tell what are those errors (maybe a snapshot of the message dialogbox)
ok
NEW RELEASE: LibFredo6 v7.8d - 01 Nov 17
LibFredo6 7.8d is a maintenance release fixing a major bug for MacOS platforms, whereby opening some dialog boxes will provoke a hang when exiting Sketchup.
Thanks to driven, slbaumgartnerand mariochafor helping me troubleshooting and fixing the problem.
NEW RELEASE: LibFredo6 v7.9a - 02 Nov 17
LibFredo6 7.9a is a maintenance release fixing a major bug for MacOS platforms, whereby opening some dialog boxes will provoke a hang when exiting Sketchup.
It is also required for Animator 1.8a, for performance improvement when animating complex models.
Hi guys,
my libfredo6 toolbars have stopped working. Am using Win10 and SK2017, everything working fine until yesterday. As of today my Roundcorner and Fredoscale toolbars do nothing. They appear as always, but clicking does nothing. I've restarted, reinstalled, updated, backdated, etc to no avail. Any suggestions?
Cheers,
Mrplease
NEW RELEASE: LibFredo6 v8.0a - 12 Nov 17
LibFredo6 8.0a is a maintenance release dedicated to bug fixing and support of JointPushPull 4.2a (shading in preview) and Souvenir 1.5a (Favorites).
NEW RELEASE: LibFredo6 v8.0b - 19 Nov 17
LibFredo6 8.0b is a maintenance release dedicated to improving the circular interpolation of cameras in Animator 1.8b.
Error Loading File C:/Users/Fırat Aneyzi/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6/top_LibFredo6.rbe
Failed to read RBE/RBS file.
Error Loading File Fredo6_!LibFredo6.rb
Error: #<NameError: uninitialized constant LibFredo6_Loader::LibFredo6>
C:/Users/Fırat Aneyzi/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:63:inprocess' C:/Users/Fırat Aneyzi/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:70:in
module:LibFredo6_Loader'
C:/Users/Fırat Aneyzi/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:28:in `<top (required)>'how i fix it?
SU 2016
Fredo will reply definitively, in due course...
However, I suspect that it is the user-name which is causing the issues...
"Fırat Aneyzi"
I guess it is Turkish - where the non-dotted "ı", as opposed to the final dotted "i", is used for the "uh" sound, instead of the "ee" sound...
But using proper UTF8 encoding [as Fredo does?] should trap for such things [we know that older SketchUp versions failed because of this non-standard characters, but the newer version are much more robust !]Fredo ???
I don't think this is the username, except for old versions of SU.
Sometimes, Sketchup cannot read the rbs/rbe file. This seems to come from an installation done without adminsitrator rights.
In general, a reinstallation of SU would solve the problem.Fredo
Thanks Fredo.
Perhaps the odd-characters in the user-name are a "red-herring".For the avoidance of doubt...
On a PC the only correct way to install any application like SketchUp...
Close that version of SketchUp, if necessary.***
You must then find the SketchUp installer's exe file - it's usually in your "Downloads" folder.
Select its icon.
Right-click > Context-menu >
"Run as administrator"
When prompted choose "Repair".
Let it complete the installation.
When you restart SketchUp it should work properly.***If it's a new installation [e.g. you have previously uninstalled it, or it's just brand-new] the offered installer's option will just be "Install"...
NEW RELEASE: LibFredo6 v8.0c - 10 Dec 17
LibFredo6 8.0c is a maintenance release dedicated to the integration of VRay 3.6 in Animator.
thankx
NEW RELEASE: LibFredo6 v8.1a - 23 Feb 18
LibFredo6 8.1a is a maintenance release dedicated to bug fixing and evolutions in other plugins
NEW RELEASE: LibFredo6 v8.1b - 25 Feb 18
LibFredo6 8.1b is a maintenance release dedicated to bug fixing and evolutions in other plugins. Please use 8.1b or above on Mac, as rhere was a problem with toolbar icons in Vector format on Mac with v8.1a.
2018? why doesn't this work? Is the latest version even available for 2018?
What exactly is your problem?
NEW RELEASE: LibFredo6 v8.1c - 27 Feb 18
LibFredo6 8.1c is a maintenance release dedicated to bug fixing for JointPushPull, Curviloft and FredoTools. Please also upgrade to the latest versions of these plugins.
NEW RELEASE: LibFredo6 v8.1d - 04 Mar 18
LibFredo6 8.1d is a maintenance release dedicated to tentatively solving occasional bugsplats in Curviloft and FredoTools. Please also upgrade to the latest version if you have the case.
