    [Plugin Library] LibFredo6 - v16.0a - 08 Aug 26
    2.2k Posts 580 Posters 6.1m Views 582 Watching
      miir
      ok
      • fredo6F Offline
        NEW RELEASE: LibFredo6 v7.8d - 01 Nov 17
        LibFredo6 7.8d is a maintenance release fixing a major bug for MacOS platforms, whereby opening some dialog boxes will provoke a hang when exiting Sketchup.
        Thanks to driven, slbaumgartnerand mariochafor helping me troubleshooting and fixing the problem.
        • fredo6F Offline
          NEW RELEASE: LibFredo6 v7.9a - 02 Nov 17
          LibFredo6 7.9a is a maintenance release fixing a major bug for MacOS platforms, whereby opening some dialog boxes will provoke a hang when exiting Sketchup.
          It is also required for Animator 1.8a, for performance improvement when animating complex models.
            mrplease
            Hi guys,
            my libfredo6 toolbars have stopped working. Am using Win10 and SK2017, everything working fine until yesterday. As of today my Roundcorner and Fredoscale toolbars do nothing. They appear as always, but clicking does nothing. I've restarted, reinstalled, updated, backdated, etc to no avail. Any suggestions?
            Cheers,
            Mrplease
            • fredo6F Offline
              NEW RELEASE: LibFredo6 v8.0a - 12 Nov 17
              LibFredo6 8.0a is a maintenance release dedicated to bug fixing and support of JointPushPull 4.2a (shading in preview) and Souvenir 1.5a (Favorites).
              • fredo6F Offline
                NEW RELEASE: LibFredo6 v8.0b - 19 Nov 17
                LibFredo6 8.0b is a maintenance release dedicated to improving the circular interpolation of cameras in Animator 1.8b.
                  desayf
                  Error Loading File C:/Users/Fırat Aneyzi/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6/top_LibFredo6.rbe
                  Failed to read RBE/RBS file.
                  Error Loading File Fredo6_!LibFredo6.rb
                  Error: #<NameError: uninitialized constant LibFredo6_Loader::LibFredo6>
                  C:/Users/Fırat Aneyzi/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:63:in process' C:/Users/Fırat Aneyzi/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:70:in module:LibFredo6_Loader'
                  C:/Users/Fırat Aneyzi/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:28:in `<top (required)>'
                  how i fix it?
                  SU 2016
                    Fredo will reply definitively, in due course...
                    However, I suspect that it is the user-name which is causing the issues...
                    "Fırat Aneyzi"
                    I guess it is Turkish - where the non-dotted "ı", as opposed to the final dotted "i", is used for the "uh" sound, instead of the "ee" sound...
                    But using proper UTF8 encoding [as Fredo does?] should trap for such things [we know that older SketchUp versions failed because of this non-standard characters, but the newer version are much more robust !]
                    Fredo ???
                    • fredo6F Offline
                      I don't think this is the username, except for old versions of SU.
                      Sometimes, Sketchup cannot read the rbs/rbe file. This seems to come from an installation done without adminsitrator rights.
                      In general, a reinstallation of SU would solve the problem.
                        Thanks Fredo.
                        Perhaps the odd-characters in the user-name are a "red-herring".
                        For the avoidance of doubt...
                        On a PC the only correct way to install any application like SketchUp...
                        Close that version of SketchUp, if necessary.***
                        You must then find the SketchUp installer's exe file - it's usually in your "Downloads" folder.
                        Select its icon.
                        Right-click > Context-menu >
                        "Run as administrator"
                        When prompted choose "Repair".
                        Let it complete the installation.
                        When you restart SketchUp it should work properly.
                        ***If it's a new installation [e.g. you have previously uninstalled it, or it's just brand-new] the offered installer's option will just be "Install"...
                        • fredo6F Offline
                          NEW RELEASE: LibFredo6 v8.0c - 10 Dec 17
                          LibFredo6 8.0c is a maintenance release dedicated to the integration of VRay 3.6 in Animator.
                            MennaD
                            thankx
                            • fredo6F Offline
                              NEW RELEASE: LibFredo6 v8.1a - 23 Feb 18
                              LibFredo6 8.1a is a maintenance release dedicated to bug fixing and evolutions in other plugins
                              • fredo6F Offline
                                NEW RELEASE: LibFredo6 v8.1b - 25 Feb 18
                                LibFredo6 8.1b is a maintenance release dedicated to bug fixing and evolutions in other plugins. Please use 8.1b or above on Mac, as rhere was a problem with toolbar icons in Vector format on Mac with v8.1a.
                                  ChillBilla
                                  2018? why doesn't this work? Is the latest version even available for 2018?
                                  • fredo6F Offline
                                    What exactly is your problem?
                                    • fredo6F Offline
                                      NEW RELEASE: LibFredo6 v8.1c - 27 Feb 18
                                      LibFredo6 8.1c is a maintenance release dedicated to bug fixing for JointPushPull, Curviloft and FredoTools. Please also upgrade to the latest versions of these plugins.
                                      • fredo6F Offline
                                        NEW RELEASE: LibFredo6 v8.1d - 04 Mar 18
                                        LibFredo6 8.1d is a maintenance release dedicated to tentatively solving occasional bugsplats in Curviloft and FredoTools. Please also upgrade to the latest version if you have the case.
                                          ali_yonder
                                          Hello Fredo.
                                          When i installed fredo6 8.1 for SU2017, it has failed. How can i fix this problem?
                                          Error: #<ArgumentError: invalid byte sequence in UTF-8>
                                          c:/users/ali yönder/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:43:in gsub' c:/users/ali yönder/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:43:in get_dir_from_ENV'
                                          c:/users/ali yönder/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:405:in dir_appdata' c:/users/ali yönder/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:204:in startup'
                                          C:/Users/Ali Yönder/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:63:in process' C:/Users/Ali Yönder/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:70:in module:LibFredo6_Loader'
                                          C:/Users/Ali Yönder/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:28:in <top (required)>' Error Loading File Fredo6_FredoTools.rb Error: #<TypeError: can't convert nil into an exact number> C:/Users/Ali Yönder/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:79:in -'
                                          C:/Users/Ali Yönder/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:79:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require'
                                          C:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require' C:/Users/Ali Yönder/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_FredoTools.rb:47:in module:Fredo6'
                                          C:/Users/Ali Yönder/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_FredoTools.rb:26:in <top (required)>' Error Loading File Fredo6_ToolsOnSurface.rb Error: #<TypeError: can't convert nil into an exact number> C:/Users/Ali Yönder/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:79:in -'
                                          C:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require' C:/Users/Ali Yönder/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_ToolsOnSurface.rb:47:in module:Fredo6'
                                          C:/Users/Ali Yönder/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_ToolsOnSurface.rb:26:in `<top (required)>'
                                          Thank you 😄
                                            dci02081
                                            Ce ruby Libfredo6 v8.1d n’est pas marché sur sketchup pro 2016 (win10) dans l’ordinateur portable (surface pro5). Comment je le fixe ? en fait, le ‘***’ est la différente langue (c’est la langue coréenne). C’est la raison de montrer ce bug ?
                                            c:/users//appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:43:in gsub' c:/users/***/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:43:in get_dir_from_ENV'
                                            c:/users/
                                            /appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:405:in dir_appdata' c:/users/***/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:204:in startup'
                                            C:/Users//AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:63:in process' C:/Users/***/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:70:in module:LibFredo6_Loader'
                                            C:/Users/
                                            • 60
                                            • 61
                                            • 62
                                            • 63
                                            • 64
                                            • 111
                                            • 112
                                            • 62 / 112
