    SU18 Section Fill Question
    7 Posts 7 Posters 1.8k Views 7 Watching
    • cwmunroC
      cwmunro
      A2_Floor plans_ALADDIN_30X42_2.jpgSo - I'm really digging the new Section Fill tool.
      I am wondering if any of you know a way to only fill certain groups but, not others.
      For Instance:
      I want my walls shaded but not the masonry. I create a group for walls and a separate group for masonry. I was thinking that I could place the section inside the walls group and select it to be filled and simply not fill the masonry layer (that would keep it white). In my drawings - you have to be able to differentiate the difference between the frame wall and the masonry.
      C W Munro
      Professional Building Designer
      http://www.thealaddincompany.com
        To do more complex fills you need a tool like "Skalp" - see its PluginStore's page...
        • srxS
          srx
          Maybe place the masonry in its own group with its own section and settings.
          www.saurus.rs
          • K
            kaas
            My 2 cnts; the new automatically filled sections are a nice feature while modelling / showing preliminary designs.
            When making the working drawings, you do need a bit more control; a difference in shade / color for the individual objects (different materials, old/new). TIG's SectionCutFace is my preferred tool for doing just that.
            • JQLJ
              JQL
              Better still, use TIG's own "SectionCutFace" plugin.
              www.casca.pt
              Visit us on facebook!
              • utilerU
                utiler
                @cwmunro - A bit of a workaround but you could isolate your internal walls in a separate scene and apply specific fills to that style. Same for the masonry walls in another scene...
                Then overlay them both in LO.
                Just Curious...
                • P
                  pcmoor
                  in any sketchup version, select the underside of the wall, reverse this face, paint with a pattern, reverse face back, when cut it will show the pattern
