    SketchUp 2018
    173 Posts 63 Posters 70.7k Views 63 Watching
      2min 5 secs
        rv1974
        I can predict main feature: brand new and awesome 8 in 201x title.
        • jujuJ
          juju
          yes, but if you turn the 8 on its side it is the symbol for infinity, which is what symbolizes what you can do** with SketchUp
          **** as long as you keep to a fairly low poly model, properly modeled and organised**
          • PixeroP
            Pixero
            I heard from a local reseller that SU 2018 would be out in november and would probably make more people happy than the last version. Sounds good...
            • jujuJ
              juju
              I hope that there will be noteworthy features.
              From the SU2018 wishlist thread, this is what I hope for:
              1. I wish the layers I've set up in SU (as per the pages visibility setup) would translate verbatim to LO, which then would be able to export those (together with the additional ones created in LO) to DWG/DXF, ending up with a DWG/DXF like we're used to in the construction industry. This would probably mean a better layer manager in LO as well.
              2. I wish that LO would import DWG/DXF, without losing any information, so I can do overlays and coordinate.
              There are more things, but this is at the top for me, other things I can get by with for the time being.
              • PixeroP
                Pixero
                As I rarely never uses LO I hope to see some great new SU features added.
                • HieruH
                  Hieru
                  So, it won't be long until we find out if Trimble have decided to shift to a subscription model.
                  www.davidhier.co.uk
                  • jujuJ
                    juju
                    If that is the case, it would be sad indeed. I detest subscription software.
                    • HieruH
                      Hieru
                      Same here. I just hope that there was a strong negative response to their questionnaire and have decided to leave things as they are for now.
                      www.davidhier.co.uk
                      • PixeroP
                        Pixero
                        Same with me.
                        I think Affinity Photo is a great example of a new pro app that succeeds without subscription.
                        And even makes that a great selling point compared to competition (Adobe).
                        • B
                          Ben Ritter
                          But isn't it already, since Trimble would like an additional $120/year to maintain support and future updates?
                          • jujuJ
                            juju
                            @ben ritter said:
                            But isn't it already, since Trimble would like an additional $120/year to maintain support and futurew updates?
                            No. The current licence is perpetual, maintenance and support is to enable you to upgrade to newer versions within that period. You can keep on using your latst version until such time as other factors force you to upgrade or abandon.
                            • B
                              Ben Ritter
                              So for maintain maintenance and support, you still have to pay for major upgrades?
                                slbaumgartner
                                The main difference in a subscription scheme is that if you let your subscription lapse, the software ceases to run at all! In SketchUp's permanent license scheme you just lose support and upgrade to the next version. The software continues to run as is. As a result, there are a lot of people out there still using (for example) SketchUp v8 because it was the last version without the no-commercial-use restriction in the license for free/Make.
                                I also despise subscription licensed software. From what I can see it is nothing more than a mechanism to keep sucking money out of your wallet even if they have added/fixed nothing that affects you. The big guys went to this when it became apparent that people were no longer slavishly updating to every new release - because the vendors ran out of new things to add that were valuable to more than a specialized subgroup of users, or started making changes that were just "tomayto" vs "tomahto".
                                Frankly, there are enough long-outstanding bugs in SketchUp that the team could work on them to make a new release without adding any more features at all!
                                • HieruH
                                  Hieru
                                  I've just received my annual Maintenance and Support notice, so it looks like Trimble decided against a subscription model...for now.
                                  www.davidhier.co.uk
                                    it'll creep up on you when you least expect it.
                                    • jujuJ
                                      juju
                                      The anticipation is killing me, so close yet so far (but imminent).
                                      C'mon SketchUp (Trimble), release SU2018 into the wild - you know you want to. πŸ˜›
                                      • G
                                        grabuge
                                        I'm sad, I had bet on last monday ! Can't wait for it either. Hope it will be next monday...
                                        • JQLJ
                                          JQL
                                          If you pay your yearly maintenance and support fee you are entitled to all the major upgrades Sketchup releases as well as any maintenance release in the meantime.
                                          I'd really hate Sketchup to be turned into a subscription.
                                          www.casca.pt
                                          Visit us on facebook!
                                            rogalxxx
                                            The 2 and 3 year old S&M will be gone next monday (13th). this might be a release date for 2018.
                                            • 1 / 9
