    [Plugin][$] Tools On Surface - v2.6a - 01 Apr 24
    638 Posts 203 Posters 1.9m Views 202 Watching
      Have you an Skp file example?
        applemango85
        Sorry I'm still having no joy with the arc
        I've been using the ellipse tool instead. But even that is hit and miss. The tools don't always draw on the surface and draw weirdly on the x or y axis instead. I seem to get success when a purple dots show up but more often then not it's the red star for the intersection.
        I'd love to sing the praises of this plugin because it's a great concept but I need help to get it working properly
          Upload an example SKP file with a surface on which you can't draw a curve. Give us something to work with. Maybe we can help.
            applemango85
            sorry just done it now
            Ive been using a separate group with lines as a guide.
            Ive been using the ellipse tool instead of the arc as the arc tool will not draw a solid line.
            the plan is once the 4th ellipse is drawn to delete the above area then delete the Bottom of the ellipse lines (first time I did this I did a few of the measurements wrong so I know it works I just need to do it again)
            thank you all in advance
            tools on surface.skp
              The group you created as a guide is getting in the way of letting the tool work properly.
              I copied the top edge of the cylinder down to give me a base line for the arcs and set a few guidelines to locate the ends of the arcs. The Arc on Surface tool works just fine.
              Click to animate
                applemango85
                think that my guides were drawn wrong so I redraw I but now I have the problem that the ellipses round is made up of many little lines not the one line which is a tad of a problem when trying to use jointpushpull on the cylinder surface
                  applemango85
                  thank you dave - ill see if that works now
                    It's hard to tell what you have going on now without seeing the file.
                      applemango85
                      well I'm getting a solid line but my arc isn't happening - its either a mess or something like the attachment
                      tools on surface.pdf
                        applemango85
                        oh my goodness, I think I got it to work - I deleted a few of the guidelines and zoomed out - not the prettiest looking object but it does the job
                        thank you for sparing the time to help
                        the key seems to be to note where the blue/purple dots appear and keep guides to a minimum
                        test 1.skp
                          Good for you. If you use the inferencing tools you really shouldn't need much in the way of guides.
                            aofaofaof
                            thanks
                            • T
                              tonamu
                              Thanks for share.
                              tonamu
                              • fredo6F
                                NEW RELEASE: Tools on Surface 2.3a- 06 Oct 17
                                This maintenance release is required for:
                                • the support of usernames with non-ascii characters
                                • the compatibility for High Sierra for Mac users
                                • the support for hi-resolution screens
                                • the certification for SU2017
                                You will need to migrate to LibFredo6 7.7g or higher
                                Please see main post for download
                                  rv1974
                                  Fredo would it be hard to add fillet tool please?
                                  • fredo6F
                                    What do you mean?
                                    This is a set of tools "on Surface".
                                      rv1974
                                      I mean fillet on 3d surface. See attached:
                                      Say you have AB and CD lines. The red fillet connectig AB abd CD is demanded.
                                      fil.skp
                                        rv1974
                                        Street - underground parking ramp junction. Example from real life (VERY common an tedious task).
                                        ca.skp
                                        • fredo6F
                                          @rv1974
                                          Somehow, you are asking if I could implement teh equivalent of BezierSpline 'on surface', of which the filetting is just one tool.
                                          That's probably possible, but non trivial.
                                          Actually the real difficulty with TOS is to handle the sharp changes in surface, because this is where directions may change abruptly. If everything was on a smooth surfce it would be simpler.
                                          I'll think about it.
                                            rv1974
                                            I'd gladly use this 3d fillet on more or less 'calm' surfaces and get an error report on sharp ones. no problem.
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 28 / 32
