    SketchUp 2017 load errors
    5 Posts 4 Posters 983 Views 4 Watching
    • jujuJ Offline
      juju
      All of a sudden I'm having SketchUp load errors, it started on Friday evening, from opening one file to the next in the same session.
      It threw out my dashboard arrangement of extension / plugins, disabled a few (I had to re-enable them manually) from menu's, and I'm getting strange load errors (see attached TXT file).
      Does anybody have any ideas?
      SU 2017 load errors 20170911.txt
      • TIGT Online
        Estimator and Skalp both need an internet connection for license verification.
        Although I think Estimator only prints errors, without a fail - except after some load-count limit is reached ?
        Have you checked your internet connectivity ?
        • jujuJ Offline
          juju
          Good call, the mobile broadband was bad on Friday night (and tonight). Although I got it earlier in the day as well when connected to wired internet (fibre) connection...
            Garry K
            Maybe Estimator and Skalp should consider modifying their approach.
            I analyzed this issue in depth and choose for my plugins to connect to my web service once a week or on demand when the user invokes check license themselves.
            This provides a strategy for a number of issues.
            1. It allows a user to go off grid for up to a week since the last web service check.
            2. It provides me with a way of resetting a user account so they can lock the plugin license to a different computer. This is necessary when a computer dies / gets replaced / or the OS gets re installed or updated. If the user was less than truthful - then the original license will fail after a week which is the same time frame as my free trials.
            Anyway - just my 2 cents.
            • medeekM Offline
              medeek
              I agree, having to rely on internet connectivity to validate your license is probably not a good idea. Even if you are online, what if the server you are phoning home to is having issues or experiencing some downtime.
              For that reason a more reasonable approach is probably better.
              Nathaniel P. Wilkerson PE
              Medeek Engineering Inc
              design.medeek.com
              With your input, this post could be even better šŸ’—
