    Error Msg "Invalid ID" - SU can't fix
    4 Posts 3 Posters 764 Views 3 Watching
    • SJS66S
      SJS66
      Just got an error message on a file. Not sure what this means but I can't save the file. Help.
      • SJS66S
        SJS66
        Not sure what happened there! Just had to delete that file. Couldn't save even if I deleted every thing in it. Weird. I did run solid inspector2 on it & got the following msg. I tried to fix the 'border edges' in question but obviously didn't, just made it worse.
        What exactly does it mean when it says "close the mesh?"
        • pmolsonP
          pmolson
          I just now got this same message on a model file.
          I have not closed the file yet because I am afraid I will loose work.
          Are you saying you could no longer open the file after closing it?
          I suspect it is due to one of several imported components as it happened after I put a bunch of kitchen components in the model.
          windows 10
          latest build su
          p
            It means that the mesh is not manifold. It is not a solid volume and there's a hole somewhere that need to be filled.
            If you make a cube and group it SU Entity Info will report it as Solid. Delete a face and it becomes non-solid.
            Solid Inspector is hunting and finding this exact problem.
