    How to remove a chamfer on a box?
    34 Posts 9 Posters 6.8k Views 9 Watching
    • chippwaltersC
      chippwalters
      @rv1974 said:
      my try, x1 speed. suitable for simple cases. Unfortunately TT's flatten works only in Z direction.
      Flatten, marge coplanar, TIG's fillet, make face were used
      I like that! One could also use Vertex Tools to flatten as well. I'll have to look into TIG's fillet tool. Thanks for sharing!!!
      Currently working with Cross-Reality technologies
        rv1974
        One couldn't. Vertex tools aren't 100% precise.
        • chippwaltersC
          chippwalters
          They've worked for me. I typically scale to ~0 two or three times in a row and haven't had any problems creating planar faces. Artisan also has a make planar feature. Both also work on non orthogonal geometry as well.
            rv1974
            Hmm.. Does 'make faces' work after x3 VT scale to 0 on NON-XY planes? I'll check it tomorrow.
              rv1974
              Doh! moment: I discovered Artisan's 'make planar-best'. Vertex tools are way less accurate.
              • K
                kenancakir
                I draw a rectangle from outside of the group, make it fit with push pull tool easily, there was one egde to move with move tool and done.. πŸ˜„
                  For this special box case with any 4 chamfers (fillets) with only native tools (a big effort from my part! πŸ’š
                  • 4 guides lines on any of the original box = 4 clicks
                  • Draw Oriented Rectangle (second icon of Rectangle Tools) with 3 of intersctions above = 3 Clicks
                    Push Pull this new rectangle = 1 click
                  Total = 7 Clicks for an original new oriented box without chamfers(fillets)! πŸ˜„
                  Just now erase the original chamfered box! πŸ˜„
                  • K
                    kenancakir
                    Our ways are the same pilou.. "Thinking outside of the box" got its exact meaning.. πŸ˜„
                      Sure, maybe there is more tricky for draw easily this rectangle with less clicks! πŸ€“
                      What is your method ?
                      • chippwaltersC
                        chippwalters
                        [attachment=0:1oo1awgy]<!-- ia0 -->GIF_erase_chamfer.gif<!-- ia0 -->[/attachment:1oo1awgy]
                        OK. But now try it with the file I provided. A simple pushpull extrude won't get it because the sides are NOT parallel.
                        Here's the link again...
                        FILE:
                        https://altuit.cloud/web/3Dnew/chamfer.skp
                          Yes so that is not a general box but a polyedra! πŸ’š
                          So a new mini challenge! β˜€
                          • K
                            kenancakir
                            I tried with the shared rectangle with pen tool, as i said above, Δ± draw a rectangle that is paralel to the edges, made it fit with push pull tool and there was one edge not fit, selecting edge and moving with move tool solved that..
                            • kimi kimiK
                              kimi kimi
                              Here is my method (I'm not good at making GIFs):
                              1. Select all the main or big faces
                              2. Copy
                              3. Select everything
                              4. Delete
                              5. Paste in place
                              6. Offset, offset, offset on the outside, all of them
                              7. Clean up with CleanUp
                              8. Select all- intersect with selection
                              9. Select those big faces again
                              10. Copy
                              11. Select all
                              12. Delete
                              13. Paste in place.
                              Seems complicated, but it isn't.
                                The icon "F" of the Join Push Pull Interactive by Fredo makes the trick
                                for 2 faces around a chamfer! πŸ˜„
                                A sort of smart Push Pull! πŸ€“
                                So all faces in addition to the 2 faces
                                around the chamfer can have any orientations!
                                Maybe 2 Guides lines are necessary for the intersection!
                                because seems interferences don't works inside the plugin itself!
                                Alas it's only 2 faces by 2 faces! πŸ’š
                                • chippwaltersC
                                  chippwalters
                                  [attachment=0:x9keu75d]<!-- ia0 -->GIF_iconef.gif<!-- ia0 -->[/attachment:x9keu75d]
                                  Brilliant! Once again, creative thinking by the French! And the solution I was hoping for by posting this challenge. Much appreciated πŸ˜„
                                  • chippwaltersC
                                    chippwalters
                                    2. Copy
                                    4. Delete
                                    5. Paste in place
                                    10. Copy
                                    11. Select all
                                    12. Delete
                                    13. Paste in place.
                                    Another fine fine solution. Thanks for your help!
                                    • JQLJ
                                      JQL
                                      I usually do the following:
                                      1 - select all;
                                      2 - remove big faces from selection;
                                      3 - group and delete group;
                                      4 - use tak2hata extend trim faces plugin;
                                      5 - then cleanup plugin if needed for merge faces and repair edges.
                                      Step 4 is the one that needs getting used to.
                                      www.casca.pt
                                      Visit us on facebook!
                                        When you say
                                        it's not more little faces so the chamfer(s) ?
                                        No clean up necessary!
                                        Cool but again it's face by face! πŸ˜‰
                                        Here zoom is needing for more precision to click the face + segment! πŸ€“
                                        • JQLJ
                                          JQL
                                          @pilou said:
                                          When you say
                                          [attachment=0:2ikvu9kh]<!-- ia0 -->GIF_extend.gif<!-- ia0 -->[/attachment:2ikvu9kh]
                                          sorry I fotgot about the generate faces plugin. I use the one from tools on surface.
                                          And I really meant rwmove big faces from selection. They are easier to pick and if you remove them when you create the group, it becomes composed pnly of all small faces. Then, When you delete the group you delete only the small faces and keep the big ones.
                                          1 - select all;
                                          so, after review, I still thin the fastest method is:
                                          1 - select all;
                                          5 - Generate faces using a plugin (tools on surface is my choice)
                                          6 - then cleanup plugin if needed for merge faces and repair edges.
                                          It does require manual work, but all do until now, and this is the easiest I know, and I tried a lot.
                                          www.casca.pt
                                          • chippwaltersC
                                            chippwalters
                                            @jql said:
                                            @pilou said:
                                            When you say
                                            [attachment=0:3jt9ho9s]<!-- ia0 -->GIF_extend.gif<!-- ia0 -->[/attachment:3jt9ho9s]
                                            1 - select all;
                                            1 - select all;
                                            Interesting. This looks like a good strategy for removing both fillets and chamfers from more complex shapes. My favorite so far!
