    How to remove a chamfer on a box?
    34 Posts 9 Posters 6.4k Views 9 Watching
      rv1974
      @ecati said:
      You want it to look like in the pictures. You can use Round Corner plugin.
      https://sketchucation.com/forums/viewtopic.php?t=20485
      How exactly Round corner would solve this task?
      I thought of JPP (Follow pushpull)- but unfortunately it has no snap at the moment the pushed chamfer desappears. And there's 'delete coplanar edges' (of fredo6?) for one-click cleaning.
      • chippwaltersC
        chippwalters
        I don't think you understood the question. It was how to REMOVE chamfers, not how to ADD them. πŸ˜„
        Currently working with Cross-Reality technologies
        • chippwaltersC
          chippwalters
          @box said:
          Draw the two edges in using the magenta inference then pushpull.
          That was the first think I tried. While that works, it has lots of mouseclicks then cleanup. I think my way may be faster.
            Best will be a plugin who special join 2 any faces by the common edges starting the chamfer (or fillet) and kill them! πŸ˜‰
            Don't know if yet existing?
            But that is a funny challenge with the native tools! β˜€
            • chippwaltersC
              chippwalters
              Or even a merge vertices which merged them to the second point selected (instead of the average of the two). Newtek has one called "weld" which will move all the points to the last selected. Very handy!
              • sdmitchS
                sdmitch
                This was my first thought as well.
                http://sdmitch.blogspot.com/
                  rv1974
                  my try, x1 speed. suitable for simple cases. Unfortunately TT's flatten works only in Z direction.
                  Flatten, marge coplanar, TIG's fillet, make face were used
                  • chippwaltersC
                    chippwalters
                    I like that! One could also use Vertex Tools to flatten as well. I'll have to look into TIG's fillet tool. Thanks for sharing!!!
                      rv1974
                      One couldn't. Vertex tools aren't 100% precise.
                      • chippwaltersC
                        chippwalters
                        They've worked for me. I typically scale to ~0 two or three times in a row and haven't had any problems creating planar faces. Artisan also has a make planar feature. Both also work on non orthogonal geometry as well.
                          rv1974
                          Hmm.. Does 'make faces' work after x3 VT scale to 0 on NON-XY planes? I'll check it tomorrow.
                            rv1974
                            Doh! moment: I discovered Artisan's 'make planar-best'. Vertex tools are way less accurate.
                            • K
                              kenancakir
                              I draw a rectangle from outside of the group, make it fit with push pull tool easily, there was one egde to move with move tool and done.. πŸ˜„
                                For this special box case with any 4 chamfers (fillets) with only native tools (a big effort from my part! πŸ’š
                                • 4 guides lines on any of the original box = 4 clicks
                                • Draw Oriented Rectangle (second icon of Rectangle Tools) with 3 of intersctions above = 3 Clicks
                                  Push Pull this new rectangle = 1 click
                                Total = 7 Clicks for an original new oriented box without chamfers(fillets)! πŸ˜„
                                Just now erase the original chamfered box! πŸ˜„
                                • K
                                  kenancakir
                                  Our ways are the same pilou.. "Thinking outside of the box" got its exact meaning.. πŸ˜„
                                    Sure, maybe there is more tricky for draw easily this rectangle with less clicks! πŸ€“
                                    What is your method ?
                                    • chippwaltersC
                                      chippwalters
                                      [attachment=0:1oo1awgy]<!-- ia0 -->GIF_erase_chamfer.gif<!-- ia0 -->[/attachment:1oo1awgy]
                                      OK. But now try it with the file I provided. A simple pushpull extrude won't get it because the sides are NOT parallel.
                                      Here's the link again...
                                      FILE:
                                      https://altuit.cloud/web/3Dnew/chamfer.skp
                                        Yes so that is not a general box but a polyedra! πŸ’š
                                        So a new mini challenge! β˜€
                                        • K
                                          kenancakir
                                          I tried with the shared rectangle with pen tool, as i said above, Δ± draw a rectangle that is paralel to the edges, made it fit with push pull tool and there was one edge not fit, selecting edge and moving with move tool solved that..
                                          • kimi kimiK
                                            kimi kimi
                                            Here is my method (I'm not good at making GIFs):
                                            1. Select all the main or big faces
                                            2. Copy
                                            3. Select everything
                                            4. Delete
                                            5. Paste in place
                                            6. Offset, offset, offset on the outside, all of them
                                            7. Clean up with CleanUp
                                            8. Select all- intersect with selection
                                            9. Select those big faces again
                                            10. Copy
                                            11. Select all
                                            12. Delete
                                            13. Paste in place.
                                            Seems complicated, but it isn't.
