    Rough Corner plugin
    13 Posts 5 Posters 2.5k Views 5 Watching
    • SJS66S
      SJS66
      Thanks for the suggestions. Ended up doing a bit of the old "join the dots". Didn't take too long & now I have some rough corner inserts that I can scale/rotate/adjust to customize if needed. The erode plugin works ok too, although I think I like the sharper "chipped" look by doing it manually. Still, forgot I had that erode plugin. Very handy. Cheers Sofie9536
      I've attached an Explorer Twilight Render image with the stone materials & I reckon that should just about do it for this job. I could muck around with weld edges etc in TR but not sure if it requires it.
      • SJS66S
        SJS66
        might turn the bump down a little bit in TR actually. Looks a bit rougher than the real thing.
        • SJS66S
          SJS66
          Getting there, roughed up the edges a bit. Starting to look like the real thing. Just need to turn on the water now.
          • SJS66S
            SJS66
            @sofie9536 said:
            You could do this with the erode plugin. Best round with the round corner plugin before.
            The looks better, just other parameters
            [attachment=0:2j5la394]<!-- ia0 -->Screenshot_3.png<!-- ia0 -->[/attachment:2j5la394]
            Oh wow, that looks good. Do you mind if I ask what erode parameters you used for that last screenshot?
              sofie9536
              Am today very fast πŸ˜„
              • HornOxxH
                HornOxx
                interesting subject - great suggestions - great video tutorial πŸ‘
                thanks guys!
                never trust a skinny cook
                • SJS66S
                  SJS66
                  Great video & tunes! Luv ya work!
                  Thanks for that.
                  • SJS66S
                    SJS66
                    Did a variation on the sofie9536 method using round corner & erode.
                      sofie9536
                      God idea, but "There are many roads to Rome". Thanks πŸ˜„πŸ™‚
                      • ntxdaveN
                        ntxdave
                        The tutorial video was really good.........
                        Press F1...thank me later
