    Rough Corner plugin
    13 Posts 5 Posters 2.5k Views 5 Watching
      sofie9536
      You could do this with the erode plugin. Best round with the round corner plugin before.
      Sketchup Plugin Fractal Terrain Eroder. fredo6 round corner(not necessarily)
      The looks better, just other parameters
      • SJS66S
        SJS66
        Thanks for the suggestions. Ended up doing a bit of the old "join the dots". Didn't take too long & now I have some rough corner inserts that I can scale/rotate/adjust to customize if needed. The erode plugin works ok too, although I think I like the sharper "chipped" look by doing it manually. Still, forgot I had that erode plugin. Very handy. Cheers Sofie9536
        I've attached an Explorer Twilight Render image with the stone materials & I reckon that should just about do it for this job. I could muck around with weld edges etc in TR but not sure if it requires it.
        • SJS66S
          SJS66
          might turn the bump down a little bit in TR actually. Looks a bit rougher than the real thing.
          • SJS66S
            SJS66
            Getting there, roughed up the edges a bit. Starting to look like the real thing. Just need to turn on the water now.
            • SJS66S
              SJS66
              [attachment=0:2j5la394]<!-- ia0 -->Screenshot_3.png<!-- ia0 -->[/attachment:2j5la394]
              Oh wow, that looks good. Do you mind if I ask what erode parameters you used for that last screenshot?
                sofie9536
                Am today very fast πŸ˜„
                • HornOxxH
                  HornOxx
                  interesting subject - great suggestions - great video tutorial πŸ‘
                  thanks guys!
                  never trust a skinny cook
                  • SJS66S
                    SJS66
                    Great video & tunes! Luv ya work!
                    Thanks for that.
                    • SJS66S
                      SJS66
                      Did a variation on the sofie9536 method using round corner & erode.
                        sofie9536
                        God idea, but "There are many roads to Rome". Thanks πŸ˜„πŸ™‚
                        • ntxdaveN
                          ntxdave
                          The tutorial video was really good.........
                          Press F1...thank me later
