    [Plugin] Center of Gravity
    183 Posts 41 Posters 316.1k Views 41 Watching
      Yes, I see it.
      It was never intended for such small objects.
      It rounds to the nearest cu", so your small object appears to have no volume !
      I'll look at a way of adjusting it...
        lsorrentino
        Wow, very interesting. Thank you very much!
          Here's v3.0 https://sketchucation.com/pluginstore?pln=CofG It now reports the Volume/Weight of very small objects with more dp etc...
            lsorrentino
            Thank you very much, I will use it tomorrow!
            Luca
              lsorrentino
              It obviously works!!!
              Thank you very much TIG, extremely useful plugin.
              Luca
              OK
                lsorrentino
                Other little thing I can't understand.
                The little magnets of my previous post goes attached to a wood base that according to sketchup is 4500 mm3, but calculated by CoG is 4000.
                The volume of the magnet is ok regardless is far little than the wood base.
                Bye,
                Luca
                s1
                s2
                sk1
                  lsorrentino
                  My feeling is that if the volume is only mantissa, ie 0.04555 cm3 works good, when volume is ie 4.75 cm3 decimal part is truncated.
                  Luca
                    Must be a glitch somewhere in the 'rounding'...
                    I'll fix it...
                      Here's v3.1 https://sketchucation.com/pluginstore?pln=CofG The rounding glitch on some small values is now fixed.
                      The Volume/Weight now shown with between 1dp and 4dp, suppressing trailing zeros beyond .0 as necessary.
                        lsorrentino
                        It works!
                        Luca
                        • sketchartist023S Offline
                          sketchartist023
                          Mine does not show up with the added component information. It just turnes the solid into a bunch of layers (horizontal lining). SU 8 Pro windows 7 64bit
                            Version 8 is by now pretty much unsupported, but it should still work.
                            If you have the Ruby Console open what errors do you see when it fails ?
                            It's clearly doing its temporary slicing to get the centroid... but not completing...
                            How big is this object ?
                            Can you upload the SKP you are having issues with...
                              sketchartist023
                              TY for the quick response 😄
                              So, the console shows in the attachment.
                              It initializes, goes through the steps, and gets to call.
                              Or looks like ruby reads up maybe idk 😛
                              The skp is attached also 😄 Thank you for helping! I notice the ruby icon is not right also, so is it possible it is a ruby issue with SU8 atm?
                              NAMEEXAMPLE.skp
                                Can you please post the top half of the error message [or even better expand the RC window and attach the whole error].
                                Without all of it, the cryptic second half is somewhat useless...
                                PS: I confirm that your SKP works fine in v2017/v2018 so it's probably a v8 glitch where making it compatible for the last half dozen updates generated an error in very old ones, like v8.
                                Unfortunately I don't have v8 loaded any more, but I can try and see what the RC error is, make some tweaks that maintain the current versions' usage and PM you that fixed RB to try and see if that works for you...
                                If so I'll then republish it...
                                  PS: I'd still like to see the full v8 error, but I've also PM'd you an older version of the RB, which I am hopeful will work in v8 for you...
                                  robertWanR 1 Reply Last reply Reply Quote 0
                                  • Z Offline
                                    zstadel
                                    TIG please help!
                                    The Center of Gravity tool works great, but I can't get Composite C of G to work.
                                    I select two C of G groups,
                                    then I go to Extensions>C of G...>Composite C of G
                                    and it looks as though another group is generated, but it's empty
                                    Running SketchUp Pro 17.2.2554 on MacOS 10.13.4
                                    Thanks for any help you can offer
                                    Zack
                                      Works fine for me !
                                      Your objects are quite small and have a small volume/weight.
                                      I'm wondering if the two CofG's combined have zero values ?
                                      If you retry with the Ruby Console open are there any error messages ?
                                      If you try with more appropriate settings in the dialog does it improve ?
                                      What version of CofG are you using ?
                                      The most up to date one from the PluginStore ??
                                        auvergnemobois
                                        Capture.JPGHello, I have a problem With the same component, I get 2 different volumes and a different center of gravity depending on the position of the component ??
                                        j'ai un soucis. Avec le même composant, j'obtiens 2 volumes différents et un centre de gravité différent suivant la position du composant ??
                                          Change the axes on the rotated component so the blue axis is up. Make it unique before doing this so as not to affect the other one.
                                            What level of accuracy are you using ?
                                            If it's a solid it has no affect, but if your object is a non-solid [like this one] then it takes a series of horizontal slices through the form, and accumulates those areas to arrive at an approx volume - the more slices the more accuracy, however if it does slices that just miss some parts of some elements, then their assumed volume is less.
                                            It wasn't really intended for 'stick' assemblies, as potentially a significant part of some horizontal sticks could be overlooked.
                                            Laying your non-solid assembly 'flat' on the ground would probably give the most accurate result, since every 'stick' then gets sliced evenly and only a tiny sliver might get missed...
                                            Whereas 'solid' objects will have a set volume or even pseudo-solids will approximate well too...
                                            If you were to explode all of the sub-component parts and intersect them together, and then run a 'solid' tool on the main container, then you should find them to be solid, and the Entity Info volume is then used in CofG...
                                            Such 'solid' fixer tools include my 'SolidSolver' and thomthom's 'SolidInspector' - which are available from the SketchUcation PluginStore...
                                            • 8 / 10
