    [Plugin] Center of Gravity
    183 Posts 41 Posters 336.3k Views 41 Watching
    • PockocmocP
      Pockocmoc
      I am so stupid πŸ˜’ ... you are right TIG, it was because of the units, obviously! The blade weights 42 grams, so (0.0)42 Kg .
      http://img15.hostingpics.net/pics/610277poidsnonmasse.png
      Thank you for all.
      • H
        hute_zhaw
        Hi Folks
        I just installed this plugin into SketchUp 2017. It doesn't work as expected for me. The find CofG still works fine as far as I can tell but the Composit CofG returns a ruby error:
        Error; #<TypeError; reference to deleted Group>
        /Users/hute/Library/Application Support/SketchUp 2017/SketchUp/Plugins/CofGravity.rb;670;in `entities'
        /Users/hute/Library/Application Support/SketchUp 2017/SketchUp/Plugins/CofGravity.rb;670;in `block in do_composite'
        /Users/hute/Library/Application Support/SketchUp 2017/SketchUp/Plugins/CofGravity.rb;669;in `each'
        /Users/hute/Library/Application Support/SketchUp 2017/SketchUp/Plugins/CofGravity.rb;669;in `do_composite'
        /Users/hute/Library/Application Support/SketchUp 2017/SketchUp/Plugins/CofGravity.rb;117;in `initialize'
        /Users/hute/Library/Application Support/SketchUp 2017/SketchUp/Plugins/CofGravity.rb;817;in `new'
        /Users/hute/Library/Application Support/SketchUp 2017/SketchUp/Plugins/CofGravity.rb;817;in `block in <top (required)>'
        SketchUp;1;in `call'
        Has anybody got a clue how to fix this? It is really a pretty cool plugin and would be a shame if it became unusable.
          Thanks for the bug-report.
          I suspect that this is a glitch in the way v2017 handles exploded entities.
          I'll investigate and fix it...
            Here's v2.0 http://sketchucation.com/pluginstore?pln=CofG Its coding is now compatible with v2017 and it is also signed for use in v2016/v2017 in any loading-policy.
            • H
              hute_zhaw
              Outstanding work TIG, thanks that was quick, I can confirm it works after the upgrade of the plug-in.
              Cheers
                jbkbm
                The plugin does not seem to be able to detect hollow spaces. Am I doing something wrong? I am trying to find the CoG of steel assemblies but when it calculates the weight, it includes the space between plates and gives me a number much higher than the actual weight.
                http://imgur.com/a/bIITC
                  Your image attachment isn't showing.
                  An object needs to be a sensibly formed 'solid' - as reported in Entity Info.
                  Otherwise results can be flaky...
                  'Hollows' are accounted for, if it's a proper solid...
                  If you attach your SKP we can look at it...
                  • L
                    lsorrentino
                    Hello All, hello TIG,
                    I want to calculate the center of gravity of a small magnet, but the calculation always report volume = 0 and eventully weight = 0.
                    The plugin works perfectly on my pc with larger objects, the density is 7.6 g/cm3, I'm a newbie with sketchup in general, I'm probably doing something wrong 😞
                    Luca
                    sketchup file
                    screenshot
                    result
                      It must be a rounding issue.
                      The object looks like it has no volume to SketchUp, therefore no weight.
                      I'll investigate...
                        Yes, I see it.
                        It was never intended for such small objects.
                        It rounds to the nearest cu", so your small object appears to have no volume !
                        I'll look at a way of adjusting it...
                        • L
                          lsorrentino
                          Wow, very interesting. Thank you very much!
                            Here's v3.0 https://sketchucation.com/pluginstore?pln=CofG It now reports the Volume/Weight of very small objects with more dp etc...
                            • L
                              lsorrentino
                              Thank you very much, I will use it tomorrow!
                              Luca
                              • L
                                lsorrentino
                                It obviously works!!!
                                Thank you very much TIG, extremely useful plugin.
                                Luca
                                OK
                                • L
                                  lsorrentino
                                  Other little thing I can't understand.
                                  The little magnets of my previous post goes attached to a wood base that according to sketchup is 4500 mm3, but calculated by CoG is 4000.
                                  The volume of the magnet is ok regardless is far little than the wood base.
                                  Bye,
                                  Luca
                                  s1
                                  s2
                                  sk1
                                  • L
                                    lsorrentino
                                    My feeling is that if the volume is only mantissa, ie 0.04555 cm3 works good, when volume is ie 4.75 cm3 decimal part is truncated.
                                    Luca
                                      Must be a glitch somewhere in the 'rounding'...
                                      I'll fix it...
                                        Here's v3.1 https://sketchucation.com/pluginstore?pln=CofG The rounding glitch on some small values is now fixed.
                                        The Volume/Weight now shown with between 1dp and 4dp, suppressing trailing zeros beyond .0 as necessary.
                                        • L
                                          lsorrentino
                                          It works!
                                          Luca
                                          • sketchartist023S
                                            sketchartist023
                                            Mine does not show up with the added component information. It just turnes the solid into a bunch of layers (horizontal lining). SU 8 Pro windows 7 64bit
                                            • 8 / 10
