    [Plugin] FredoTools - v4.5c - 24 Jun 24
    463 Posts 123 Posters 698.3k Views 121 Watching
    • fredo6F Offline
      @cadmunkey
      You are right. Actually, the result is correct mathematically. In the algorithm, negative volumes are normally used for holes in solids. But intuitively, we are not used to negative volumes.
      So, I fixed it, and it will go in the next release.
        cadmunkey
        @fredo6 said:
        @cadmunkey
        These are not holes in solids, if you want I can email you my model for analysis.
        Its a marble stone cut list, and some of the stones are reporting back as negative volumes.
        • fredo6F Offline
          I mean that when you flip along a group or component instances, you actually transform their axes and mathematically, this gives a negative volume, as it does for holes in the solid.
          Anyway, many thanks for signalling the problem.
            rv1974
            I wish Curvishear could be become way more usable by
            letting user 'in-vivo' move a vertex (and thus setting desired height and slope direction)
              bharralure
              Bonjour Dave
              Je confirme que "Volume Solides" affiche une valeur négative pour toute instance crée en miroir.
              Ce problème n'est pas spécifique à SU 2017, l'ayant déjà constaté sous SU 2016 et SU 2015.
              Je joint un Gif crée sous SU 2017.
              • fredo6F Offline
                NEW RELEASE: FredoTools v3.1a - 09 Jul 17
                Requirement: LibFredo6 v7.7a
                FredoTools 3.1a introduces a new plugin, called DivideEdges. It also supports hi-resolution screens and fixes some bugs.
                See FredoTools home page for Download.
                • JClementsJ Offline
                  JClements
                  Divide Edges (DE) is a nice new addition to your toolset. Thank you!
                  Perhaps a version of DE could be adapted to produce dashed lines? When selected only an ODD number of segments would be available, then every-other-segment after the first segment would be deleted or hidden (not sure which would be the best to go). Maybe it could be "parametric" in the sense that the user could restore the original at later time and apply and different number of segments.
                  • fredo6F Offline
                    NEW RELEASE: FredoTools v3.1b - 11 Jul 17
                    FredoTools 3.1b fixes a bug in FredoTools::SolidVolume, as signaled by Alex37550. See this post.
                    See FredoTools plugin home page for Download.
                    See also main post of this thread for User Discussion.
                      rv1974
                      MoveAlong question:
                      How difficult would it be to implement
                      a Multiple objects move (rotate?) by their local axes?
                      • fredo6F Offline
                        @rv1974 said:
                        MoveAlong question:
                        Should be a dedicated tool.
                        MoveAlong is already complex, and I did not add the move along local axes (there are inferences however), as I did in Animator.
                        That's not a matter of programming ; Putting too many features in a plugin defeats the purpose, as then it is judged cluttered with options that nobody really uses.
                        • fredo6F Offline
                          NEW RELEASE: FredoTools v3.1c - 18 Aug 17
                          FredoTools 3.1c fixes problems with non-ascii usernames and provides verious bug fixing.
                          • fredo6F Offline
                            NEW RELEASE: FredoTools v3.1d - 28 Sep 17
                            FredoTools 3.1d fixes potential bugsplat in ThruPaint. Thanks to report if you have any.
                            • ecatiE Offline
                              ecati
                              For Msphysics, I used "Convexify" to divide the object shown in the figure into convex pieces, but I did not create the division process. What would be the reason?
                              1.skp
                              • fredo6F Offline
                                I tried, and it's probably too much for the algorithm.
                                And on a portion of it, the convexification won't give you something 'nice as expected', because the the triangulation makes most individual edges concave, with relatively large angles.
                                I guess you have to find another way to generate the shape directly into small bits.
                                • fredo6F Offline
                                  NEW RELEASE: FredoTools v3.1e - 01 Oct 17
                                  FredoTools 3.1e fixes a major bug preventing the correct load under Mac OSX High Sierra. So you really need to upgrade if you have upgraded or plan to upgrade to High Sierra.
                                  • mariochaM Offline
                                    mariocha
                                    Hi Mac users. A litlle survey.
                                    Lately I'm having a small annoyance with this extension.
                                    If I open the pane for the tools (see image) once in a session, then SU cannot quit normally. Beachball.
                                    I removed all the other extension leaving only it and the Lib. Still bug.
                                    Anyone else ?
                                    update: Just did it with Curvizard.
                                    %(#008000)[Mario C.
                                    • Mousa_SAM Offline
                                      Mousa_SA
                                      Hello Fredo,
                                      Firstly, thanks for all of your plugins.
                                      I get a bugsplat when I enable Thrupaint, please check the attachment to see the bug report.
                                      Thrupaint bug
                                      • fredo6F Offline
                                        Yes, there are cases of bugsplat, and for what whatever reason, they may occur systematically for some users. I did not find the reason and fix yet, but I am trying...
                                        • Mousa_SAM Offline
                                          Mousa_SA
                                          I have made some tests and found that this issue occur when Profile builder 2 and SubD is enabled, but I installed SketchUp 2017, Profile Builder 2 and SubD on another machine and Thrupaint worked fine!
                                          • OxerO Offline
                                            Oxer
                                            Hi, I found a minor issue with Thrupaint on OS X 10.11.6 & SU2017, when you make click to enter in Visual edition, the gizmo and the options window disappear immediately but "right click ->Contextual menu->Enter in Visual edition" or "Enter" work fine, for this reason for me is a minor issue.
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 22 / 24
