    [Plugin] FredoTools - v4.5c - 24 Jun 24
    463 Posts 123 Posters 798.1k Views 121 Watching
    • JClementsJ Offline
      JClements
      Divide Edges (DE) is a nice new addition to your toolset. Thank you!
      Perhaps a version of DE could be adapted to produce dashed lines? When selected only an ODD number of segments would be available, then every-other-segment after the first segment would be deleted or hidden (not sure which would be the best to go). Maybe it could be "parametric" in the sense that the user could restore the original at later time and apply and different number of segments.
      • fredo6F Offline
        NEW RELEASE: FredoTools v3.1b - 11 Jul 17
        FredoTools 3.1b fixes a bug in FredoTools::SolidVolume, as signaled by Alex37550. See this post.
        See FredoTools plugin home page for Download.
        See also main post of this thread for User Discussion.
          rv1974
          MoveAlong question:
          How difficult would it be to implement
          a Multiple objects move (rotate?) by their local axes?
          • fredo6F Offline
            @rv1974 said:
            MoveAlong question:
            Should be a dedicated tool.
            MoveAlong is already complex, and I did not add the move along local axes (there are inferences however), as I did in Animator.
            That's not a matter of programming ; Putting too many features in a plugin defeats the purpose, as then it is judged cluttered with options that nobody really uses.
            • fredo6F Offline
              NEW RELEASE: FredoTools v3.1c - 18 Aug 17
              FredoTools 3.1c fixes problems with non-ascii usernames and provides verious bug fixing.
              • fredo6F Offline
                NEW RELEASE: FredoTools v3.1d - 28 Sep 17
                FredoTools 3.1d fixes potential bugsplat in ThruPaint. Thanks to report if you have any.
                • ecatiE Offline
                  ecati
                  For Msphysics, I used "Convexify" to divide the object shown in the figure into convex pieces, but I did not create the division process. What would be the reason?
                  1.skp
                  • fredo6F Offline
                    I tried, and it's probably too much for the algorithm.
                    And on a portion of it, the convexification won't give you something 'nice as expected', because the the triangulation makes most individual edges concave, with relatively large angles.
                    I guess you have to find another way to generate the shape directly into small bits.
                    • fredo6F Offline
                      NEW RELEASE: FredoTools v3.1e - 01 Oct 17
                      FredoTools 3.1e fixes a major bug preventing the correct load under Mac OSX High Sierra. So you really need to upgrade if you have upgraded or plan to upgrade to High Sierra.
                      • mariochaM Offline
                        mariocha
                        Hi Mac users. A litlle survey.
                        Lately I'm having a small annoyance with this extension.
                        If I open the pane for the tools (see image) once in a session, then SU cannot quit normally. Beachball.
                        I removed all the other extension leaving only it and the Lib. Still bug.
                        Anyone else ?
                        update: Just did it with Curvizard.
                        %(#008000)[Mario C.
                        • Mousa_SAM Offline
                          Mousa_SA
                          Hello Fredo,
                          Firstly, thanks for all of your plugins.
                          I get a bugsplat when I enable Thrupaint, please check the attachment to see the bug report.
                          Thrupaint bug
                          • fredo6F Offline
                            Yes, there are cases of bugsplat, and for what whatever reason, they may occur systematically for some users. I did not find the reason and fix yet, but I am trying...
                            • Mousa_SAM Offline
                              Mousa_SA
                              I have made some tests and found that this issue occur when Profile builder 2 and SubD is enabled, but I installed SketchUp 2017, Profile Builder 2 and SubD on another machine and Thrupaint worked fine!
                              • OxerO Offline
                                Oxer
                                Hi, I found a minor issue with Thrupaint on OS X 10.11.6 & SU2017, when you make click to enter in Visual edition, the gizmo and the options window disappear immediately but "right click ->Contextual menu->Enter in Visual edition" or "Enter" work fine, for this reason for me is a minor issue.
                                • fredo6F Offline
                                  I think the problem was already signaled, and it seems this happens only on MacOS.
                                  Note that you can also type Enter to activate / deactivate the gizmo.
                                  Difficult for me to troubleshoot as I don't have a Mac. I made a modif blindly, just in case this improves.
                                  Fredo6_FredoTools - v3.1f - 03 Nov 17 - certified - encrypted.rbz
                                  Could you check if you still have the problem.
                                  • OxerO Offline
                                    Oxer
                                    I installed that version but the issue persists.
                                    Fredo like I said to you before, for me it's a minor issue.
                                    • OxerO Offline
                                      Oxer
                                      The FredoTools v3.1e works fine on OS X 10.11.6 & SU2016, the issue is with SU2017.
                                      • fredo6F Offline
                                        Even more weird.
                                        Did you try with double-click on a textured face?
                                        • OxerO Offline
                                          Oxer
                                          Yes, but this doesn't resolve the issue. Don't worry Fredo, it's a little problem but it doesn't interrupt my workflow.
                                          • fredo6F Offline
                                            Just try to understand what can be caused by
                                            • a difference between Mac and Windows
                                            • a difference between SU2016 and SU2017
                                            To you get a stable gizmo when pressing Enter on a textured face ?
                                            What happen if you click down, release without moving the mouse ?
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 23
                                            • 24
                                            • 14 / 24
