    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.1m Views 254 Watching
      muchomurka2
      wow,thx!
        Sejoe
        This plugin doesn't working on version 2015 always giving error
          It works for others with SketchUp 2015.
          Saying "always giving error" but not sharing the error message makes it impossible for anyone to help you if that's what you want. Share the error and you will get some assistance.
            Yes works fine for the 2015 & 2016! 😎
              Sejoe
              This is my make fur error what can i do for this?I uninstalled program and installed two times but nothing changed,please help...
              my make fur error
                This looks like a UTF8 issue with SketchUp's Ruby file-path reading...
                There are ways of sidestepping this in the newest Ruby - not always invoked.
                So these might not have been effected in this tool's code.
                Your Windows user-name seems to be "ADMİN" [I assume that's Turkish (Türk) with a dotted 'I' ?] rather than the immediately acceptable "ADMIN".
                Accented characters in user-names are very well known for causing issues like this...
                But newer Plugins, which ought to use the latest Ruby methods, can often sidestep these problem...
                  marcodallago
                  I have a problem.. I need to create grass in the green area of the image, so that will look the walkway emerge from the grass. But how can i do? With your plugin grass elements come out from the path and this is not what I want. Is there a workaround?
                  • majidM Offline
                    majid
                    فایل آپدیت زبان فارسی
                    Here is the updated Persian ( Farsi ) language file
                    در مسیر فایلهای زبان پلاگین بریزید
                    مثلا
                    C:\Users"User name"\AppData\Roaming\SketchUp\SketchUp 2016\SketchUp\Plugin
                      sexypox69
                      I too had the issue of selecting a surface and when I make fur it would be scattered everywhere except the selected surface. After changing the axis of my proxy that seem to solve the issue. I the tutorial i watch it showed the changing of the axis of the component but not to the proxy created with it. I guest when I changed component to a proxy it changed the imput axis....well this is what worked for me...Im a bit lost when it comes to these things
                        jaapberg
                        Please can someone teach me who can i create plugin? I need this.
                        Thank you
                          @einstein said:
                          Any ideas?
                          My guess is pilot error. I just installed it and it works fine for me. We need more information about what exactly you are doing when you try to use it.
                          • E Offline
                            Einstein
                            No fur (grass) is created 😞 The window shows up but there's no preview, no creation 😞 Sketchup 2017 pro, Win 7 64bit. Any ideas?
                            • E Offline
                              Einstein
                              @dave r said:
                              @einstein said:
                              Any ideas?
                              [attachment=1:37noox4j]<!-- ia1 -->fur.gif<!-- ia1 -->[/attachment:37noox4j]
                              What do you mean by "pilot error", what does it mean?
                              Now I restarted SketchUp a few times and it started working... almost correclty. I can see the preview and generate nice fur. Unless I change some of the parameters: Length, RootWidth (Main tab) and directions, forces (Detail tab) cause the script to kinda get stuck. The preview doesn't change and the geometry doesn't generate. Nothing happens when I click MAKE FUR. I can only close the window and start again with the same issues. In comparison: if I adjust e.g. Stiffness, Divide (Main tab) or things in Detail tab marked green, everything works properly. Looks like the Author wanted to say: green background means "compatibility guaranteed", white bacground means "you're doing this at your own risk". I don't know if it really matters, if the script somehow checks compatibility. Cuz the Author's menu is all green 😛
                              And one more question - is it possible with this plugin to retain proxies after generation and render fur fully only in external renderer, like v-ray?
                              I attached the file I'm working with but certainly the problem is not about certain model.
                              Untitled.skp
                                Pilot error=user error. I thought Einstein would know that. Sorry.
                                Maybe you've set the length too short?
                                Click the picture
                                As for proxies, I'm not sure that is within the scope of this extension. I think you'd need another approach for that.
                                • E Offline
                                  Einstein
                                  Maybe I should change my nickname...
                                  I assume that when you click MAKE FUR, the geometry generates. So yes, this must be something with my sketchup.
                                  The behaviour doesn't change but thank you for your attempt to help me!
                                    What settings do you have - compared to Dave's - which work ?
                                    Perhaps a screen-shot ?
                                    If you try it with the Ruby Console open are there any error messages ?
                                    Please be aware that this toolset is getting somewhat old...
                                    • E Offline
                                      Einstein
                                      I tried to generate fur with SketchUp 8 also but the same problem exists with the same set of non-working params.
                                      Working parameters: Density, MaxNumber, Stiffness, Divide (Main tab), all Jitters, ValidDistance (Detail tab).
                                      Non-working parameters: Length, RootWidth (Main tab), directions and forces (Detail tab).
                                      No matter what values I am using, errors show up. I tried similar values to Dave's but it didn't change anything.
                                      Example error in Ruby console when adjusting non-working params:
                                      Error: #<ArgumentError: Cannot convert "0.006" to Length>
                                      C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/FUR_EN/main.rb:2407:in to_l' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/FUR_EN/main.rb:2407:in s_to_l'
                                      C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/FUR_EN/main.rb:1398:in start_fur_test' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/FUR_EN/main.rb:1340:in show_webdialog'
                                      C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/FUR_EN/main.rb:2407:in `call'
                                      Additionally, when I adjust a non-working param and after that, a working param, also that working param starts to generate Ruby errors. Only when I restart plugin, I can use some of the params again.
                                        def s_to_l( tstr1 )
                                          if tstr1
                                            tstr = tstr1.to_s.gsub(/\~ /,"")
                                            return tstr.to_l ####### THROWS ERROR
                                        In the error-message tstr1 is "0.0006" so if you type this in the Ruby Console it should work:
                                        x="0.0006" x.to_l
                                        If that works I can't see what's up !
                                        • E Offline
                                          Einstein
                                          I should type in Ruby Console
                                          x="0.006"
                                          x.to_l
                                          where "0.006" is the value I adjusted with the slider; type it right after moving the slider, right? And then Make Fur.
                                          Sadly this still generates errors 😞
                                            This was not a FIX.
                                            I wanted to see what got returned when you set a reference to a string and then used .to_l to change that into a length...
                                            It should work in SketchUp >= 6 - particularly when tested outside of the main code.
                                            Fortunately your code in the Ruby Console shows the error.
                                            This should NEVER happen !
                                            What are your Model Info > Units set to ?
                                            A screen-shot might help.
                                            • 11
                                            • 32
                                            • 33
                                            • 9 / 33
