    Delete a list of components by their definitions.
    24 Posts 5 Posters 6.3k Views 5 Watching
    • TNTDAVIDT
      TNTDAVID
      **Hello TIG,
      Thank you for your very complete and precise example.
      I made a simple test on a component with the definition "BOX" which has a texture called "RED".
      The ruby dialog box returns "True", but does not delete the cube or the texture.
      http://i.imgur.com/ukvVTXi.gif
      Here is the code I copied and pasted into the dialog box:
        match = ['BOX']
        model=Sketchup.active_model
        defstogo=model.definitions.find_all{|d| d.name =~ match }
        matstogo=['RED']
        defstogo.each{|d|
        d.instances.each{|i|
        matstogo << i.material unless matstogo.include?(i.material)
        d.entities.each{|e|
        matstogo << e.material unless matstogo.include?(e.material)
      ( matstogo << e.back_material unless matstogo.include?(e.material) ) if e.is_a?(Sketchup;;Face)
        matstogo.compact!
        matstogo.uniq!
        defsnottogo=model.definitions.find_all{|d| ! d.name =~ /#{match}/ }
        matsnottogo=['RED']
        defsnottogo.each{|d|
        matsnottogo << i.material unless matsnottogo.include?(i.material)
        d.entities.each{|e|
        matsnottogo << e.material unless matsnottogo.include?(e.material)
      ( matsnottogo << e.back_material unless matsnottogo.include?(e.material) ) if e.is_a?(Sketchup;;Face)
        matsnottogo.compact!
        matsnottogo.uniq!
        matstogo.clone.each{|e|
        matstogo.delete(e) if matsnottogo.include?(e)
        model.start_operation('Purger', true)
        defstogo.each{|d| d.entities.clear! }
        matstogo.each{|m| model.materials.remove(m) }
        model.commit_operation
      Or is my mistake?
      Thank you in advance for your help.
      David**
      [b:8wt9py2i]* Nouveau !!![/b:8wt9py2i] Découvrez notre nouveau Plugin [url=http://www.composant-dynamique.com/:8wt9py2i][color=#40FF00:8wt9py2i]C[/color:8wt9py2i][color=#77FF00:8wt9py2i]l[/color:8wt9py2i][color=#ADFF00:8wt9py2i]i[/color:8wt9py2i][color=#E4FF00:8wt9py2i]c[/color:8wt9py2i][color=#FFDB09:8wt9py2i]k[/color:8wt9py2i][color=#FF921B:8wt9py2i]-[/color:8wt9py2i][color=#FF492E:8wt9py2i]C[/color:8wt9py2i][color=#FF0040:8wt9py2i]u[/color:8wt9py2i][color=#ED2577:8wt9py2i]i[/color:8wt9py2i][color=#DA49AD:8wt9py2i]s[/color:8wt9py2i][color=#C86EE4:8wt9py2i]i[/color:8wt9py2i][color=#AD77FF:8wt9py2i]n[/color:8wt9py2i][color=#8965FF:8wt9py2i]e[/color:8wt9py2i] [color=#4040FF:8wt9py2i]2[/color:8wt9py2i][/url:8wt9py2i], pour créer vos cuisines 3D !
        When I wrote match=/BOX/
        That is a regular expression.
        You wrote match=['BOX']
        That's an array containing a string...
        They are not the same thing !!
        So you need to try with a better set of variables !
        When I set a variable like matstogo=[] it's making an empty array to which we add elements...
        What made you think you need to diverge from my guidance ??
        • TNTDAVIDT
          TNTDAVID
          **I used a array to "match" because there will be several different definitions to delete.
          As in your code you use:
          defstogo.each {| d |
          It seemed to me that "each" was used to browse a array.
          Your code works perfectly for a single definition, what if we have "CUBE", "TOTO" and "LOLA" to delete?
          For matstogo I did not know that it was possible to collect materials of a definition without naming them. I'm still surprised by the Ruby.
          Thank you for your help.
          David**
          • TNTDAVIDT
            TNTDAVID
            **Hello Dan Rathbun and thank you for your help.
            @dan rathbun said:
            Then either you wrap what TIG showed you into a method, and call it 3 times from a loop:
            How to write the loop?
            I have done several tests and I still get this error message:
            Error; # <SyntaxError; <main>; syntax error, unexpected '|'
            For cname in ['CUBE', 'TOTO', 'LOLA'] do | cname |
            Then I tried your method by adding:
            Cnames = ['CUBE', 'TOTO', 'LOLA']
            The ruby console returns:
            purge_comps
            But nothing changes in SketchUp. 😲
            I have to move on from something obvious that I can not understand.
            Thank you in advance for your help.**
            • sdmitchS
              sdmitch
              You are trying to define the variable "cname" twice in the same statement. delete the do | cname |
              As usual Dan is right. You just need to wrap TIG's code with
              ["cube","toto","lola"].each{|name|
                match = /#{name}/i
              http://sdmitch.blogspot.com/
              • Dan RathbunD
                Dan Rathbun
                MY BAD! I had a bad example (above.) [ Commented out that " do | cname |" part ]
                >   match = /#{name}/i
                That will actually create a separate undo operation for each entity (and it's materials) and will be much slower.
                I gave you a complete working method at the bottom of that previous post !!!!!!
                https://forums.sketchup.com/t/ruby-learning-resources-wikilists/22861
                Get the old "Pick Axe" book and read it.
                I'm not here much anymore.
                • Dan RathbunD
                  Dan Rathbun
                  TIG is showing you how to purge ONEdefinition and it's materials.
                  @tntdavid said:
                  Your code works perfectly for a single definition, ...
                  No it does not. because you made 3 edits that make it NOT work properly.
                  CORRECTION: Actually I found 4 errors that made it not delete all the components or materials.
                  The second use of the Regexp was ! d.name =~ /#{name}/ (the regexp var is match.)
                  matsNOTtogo=[] was defined as matsNOYtogo=[], resulting in NameError
                  The comparison of back_material was conditional upon inclusion of front material in two statements.
                  @tntdavid said:
                  ... what if we have "CUBE", "TOTO" and "LOLA" to delete?
                  First, learn how and why TIG's code works for ONE definition, then learn how to modify it for multiple definitions.
                  for cname in ['CUBE','TOTO','LOLA'] # WHOOPS this not needed --> do |cname|
                    purge_comp(cname)
                  ... or you build a multi-match regular expression ( Regexp😞
                  cnames = ['CUBE','TOTO','LOLA'] match = /#{cnames.join('|')}/
                  Test file (SU2016):
                  CubeLolaToto.skp
                  "Color B04" and "Color J08" are unused.
                  "Color K03", "Color M06" are used by primitive faces.
                  "Material 2" is the leader color.
                  So here is a method with extra quirks:
                  • Returns false if array of cnames is empty.
                  • Short circuits and returns 0 if no definitions are found to delete.
                  • Reports both to console and message box number of definitions and materials purged.
                  • Returns number of definitions deleted.
                  # To test;
                  # purge_comps('CUBE','TOTO','LOLA')
                  # ... or;
                  # del = ['CUBE','TOTO','LOLA']
                  # purge_comps(del)
                  def purge_comps(*cnames)
                    return false if cnames.empty?
                    cnames.flatten!
                    # collect matching definitions
                    return 0 if defstogo.empty?
                    # collect materials.
                    matstogo=[]
                    defstogo.each{|d|
                      # first used by instances
                      # now used by its entities
                      d.entities.each{|e|
                        ( matstogo << e.back_material unless matstogo.include?(e.back_material) ) if e.is_a?(Sketchup;;Face)
                    matstogo.compact!
                    matstogo.uniq!
                    # now check if materials used elsewhere
                    defsNOTtogo=model.definitions.find_all{|d| ! d.name =~ match }
                    matsNOTtogo=[]
                    defsNOTtogo.each{|d|
                        matsNOTtogo << i.material unless matsNOTtogo.include?(i.material)
                      d.entities.each{|e|
                        matsNOTtogo << e.material unless matsNOTtogo.include?(e.material)
                        ( matsNOTtogo << e.back_material unless matsNOTtogo.include?(e.back_material) ) if e.is_a?(Sketchup;;Face)
                    matsNOTtogo.compact!
                    matsNOTtogo.uniq!
                    # now reduce matstogo as necessary...
                      matstogo.delete(e) if matsNOTtogo.include?(e)
                    defsgone = defstogo.size
                    matsgone = matstogo.size
                    # start and operation to ensure Garbage Collection works...
                    # now delete the selected entities
                    # now delete the unneeded materials
                    # clear the arrays of references to deleted objects;
                    matstogo.clear
                    defstogo.clear
                    # commit
                    msg = "#{defsgone} definitions purged\n#{matsgone} materials purged"
                    puts msg
                    UI.messagebox(msg,MB_OK)
                    return defsgone
                  If you absolutely must, you can call GC.start to ensure Ruby garbage collection runs.
                  • TNTDAVIDT
                    TNTDAVID
                    CODE: SELECT ALL
                      match = /#{name}/i
                    Great thanks sdmitch,
                    You allowed me to understand what Dan Rathbun was explaining to me.
                    @dan rathbun said:
                    https://forums.sketchup.com/t/ruby-lear ... ists/22861
                    Thanks for the Dan link, I will follow your advice.
                    Here is the TIG method, which works for several definitions:
                    http://i.imgur.com/UwLix09.gif
                      match = /#{name}/i
                      matstogo=[]
                      defstogo.each{|d|
                      d.entities.each{|e|
                      matstogo.compact!
                      matstogo.uniq!
                      matsnottogo=[]
                      d.entities.each{|e|
                      matsnottogo.uniq!
                    With your help I reach my goals and I discover more and more the Ruby. 😉
                    Thank you all for your help.
                    • Dan RathbunD
                      Dan Rathbun
                      Your implementation still has a few errors.
                      David, I say again, that I gave you the code for a complete corrected method above.
                      It defines a method name purge_comps(*cnames)
                      • TNTDAVIDT
                        TNTDAVID
                        **Sorry Dan, but I can not seem to make your method work.
                        In your method, how to integrate "CUBE", "TOTO" and "LOLA"?
                        David**
                        • TNTDAVIDT
                          TNTDAVID
                          **Sorry Dan, I had not paid attention to your instructions in the code:
                          @dan rathbun said:
                          To test:
                          ... or:
                          purge_comps(del)
                          Your method works very well and offers new benefits. 👍
                          I noticed a small problem:
                          How to avoid deleting the texture of 'CUBE', if it is used elsewhere in SketchUp?
                          Thanks in advance for your help.**
                          • Dan RathbunD
                            Dan Rathbun
                            It is TIG's method with a few extra "bells and whistles".
                            I'll look at it today a bit and see if there is an issue.
                            EDIT: Okay, YES I see the issue. The method does not check the model level entities collection for used materials (on primitive entity objects.)
                            • Dan RathbunD
                              Dan Rathbun
                              # To test;
                              # ... or;
                              # purge_comps(del)
                              # ver; 2.0
                                cnames.flatten!
                                matstogo=[]
                                defstogo.each{|d|
                                  d.entities.each{|e|
                                matstogo.compact!
                                matstogo.uniq!
                                matsNOTtogo=[]
                                  d.entities.each{|e|
                                # now used by model entities
                                model.entities.each{|e|
                                matsNOTtogo.uniq!
                                matstogo.clear
                                defstogo.clear
                                # commit
                                puts msg
                                return defsgone
                              • TNTDAVIDT
                                TNTDAVID
                                **Thanks for your reactivity Dan.
                                Your solution works in the most by cases, but not all the time.
                                The texture applied to TOTO should not be removed because it is used by the 4 Rectangle to Left:
                                http://i.imgur.com/ywPqHyg.gif
                                This mistake this product on my Click-Cuisine 2 furniture, and therefore makes the method unusable.
                                Here's the SKP file:
                                CubeLolaToto2.skp
                                If you test your code on other examples the problem will not exist! 😮
                                For this reason the problem is strange and requires an investigation.
                                David**
                                • Dan RathbunD
                                  Dan Rathbun
                                  I agree. Sounds like a good learning experience for you.
                                  I'll let you do the investigation, and fix it.
                                  I've given you enough help for now.
                                  Your turn to do some of the work. 😉
                                  • TNTDAVIDT
                                    TNTDAVID
                                    **Hello,
                                    You are right Dan, for the moment I still have not found a solution.
                                    I'm stubborn and I'd end up finding it!
                                    Thanks for your example Dirven ☀
                                    I have tested your code and the components are all removed from the SketchUp scene but nothing is purged.
                                    Is this normal?
                                    Edite:
                                    The Ruby console returns this message when I trigger your method.
                                    Error; #<NameError; undefined local variable or method `i' for Teste;Module>
                                    C;/Users/David/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/TNT_Teste/logic.rb;60;in `block in purge_comps_n_mats'
                                    C;/Users/David/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/TNT_Teste/logic.rb;56;in `each'
                                    C;/Users/David/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/TNT_Teste/logic.rb;56;in `purge_comps_n_mats'
                                    C;/Users/David/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/TNT_Teste/logic.rb;75;in `purge_comps'
                                    C;/Users/David/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/TNT_Teste/logic.rb;85;in `block in singleton class'
                                    SketchUp;1;in `call'
                                    Thank you**
                                      driven
                                      edited my example...
                                      line 55 i is now item...
                                        driven
                                        another way is to Hash the materials and set values for each...
                                          def purge_comps_n_mats(*args)
                                          model  = Sketchup.active_model
                                          defs   = model.definitions
                                          sel    = model.selection
                                          view   = model.active_view
                                          ents   = model.active_entities
                                          mats   = model.materials
                                          # add a hasj for materials and entities
                                          mats_h = Hash[mats.zip([1] * mats.size)]
                                          # this means you don't have to get Regexp right yourself
                                          names = Regexp.union(args)
                                          # this is similar to defs.to_a.dup.flatten
                                          list = defs.find_all { |d| d }
                                          # we will still only use one operation as v17 will error
                                          model.start_operation('mats')
                                          list.each do |defn|
                                            defn.instances.each do |i|
                                               # optional 'showtime' for testing
                                        	sel.add(i)
                                        	view.refresh
                                        	sleep 0.2
                                              dents = defn.entities
                                              if defn.name =~ names
                                                # get rid of the comps checking their materials
                                                 mats_h[defn.material] = 3 unless defn.material.nil?
                                                 mats_h[i.material] = 3 unless i.material.nil?
                                                 dents.to_a.each do |item|
                                                  mats_h[item.material] = 3 if item.respond_to? ;material
                                                  mats_h[item.back_material] = 3 if item.respond_to? ;back_material
                                        	# delete the instance
                                        	ents.erase_entities(i)
                                              else
                                                mats_h[defn.material] = 2 unless defn.material.nil?
                                                mats_h[i.material] = 2 unless i.material.nil?
                                                  mats_h[item.material] = 2 if item.respond_to? ;material
                                                  mats_h[item.back_material] = 2 if item.respond_to? ;back_material
                                        		sel.add(item)
                                        		view.refresh
                                        		sleep 0.2
                                           mats_h.each { |k, v| mats.remove(k) unless k.nil? || v != 3 }
                                          model.commit_operation #
                                        purge_comps_n_mats('CUBE', 'TOTO', 'LOLA')
                                        • TNTDAVIDT
                                          TNTDAVID
                                          **Thank you driven, your solution works well but encounters the same problem as that of TIG enhanced by Dan.
                                          The materials applied to the "subcomponents" are not seen by the 2 methods.
                                          To be more precise, here is an example in image:
                                          http://i.imgur.com/JSGr1lZ.gif
                                          The goal is that the texture "CUBE" is not deleted because it is used by "Nested component".
                                          Perhaps the solution would be to ask both methods to explore all the subcomponents in SketchUp and collect the materials so as not to delete them?
                                          How to write this in ruby?
                                          I could find a solution by modifying the components of Click-Cuisine 2, but the ideal would be to solve the problem with the code.
                                          If you want to try, here is the SKP file of the example:
                                          CUBE.skp
                                          Thank you**
                                            driven
                                            you must have changed something because it does work for me...
                                            did you read the code?
                                            it collects all nested materials from 'everything' before removing any materials...
                                            click image to see gif:it_wors.gif
                                            attach your test code...
