    Delete a list of components by their definitions.
    24 Posts 5 Posters 6.7k Views 5 Watching
    • Dan RathbunD
      Dan Rathbun
      @tntdavid said:
      @tig said:
      What made you think you need to diverge from my guidance ?
      I used a array to "match" because there will be several different definitions to delete.
      TIG is showing you how to purge ONEdefinition and it's materials.
      @tntdavid said:
      Your code works perfectly for a single definition, ...
      No it does not. because you made 3 edits that make it NOT work properly.
      CORRECTION: Actually I found 4 errors that made it not delete all the components or materials.
      The second use of the Regexp was ! d.name =~ /#{name}/ (the regexp var is match.)
      matsNOTtogo=[] was defined as matsNOYtogo=[], resulting in NameError
      The comparison of back_material was conditional upon inclusion of front material in two statements.
      @tntdavid said:
      ... what if we have "CUBE", "TOTO" and "LOLA" to delete?
      First, learn how and why TIG's code works for ONE definition, then learn how to modify it for multiple definitions.
      Then either you wrap what TIG showed you into a method, and call it 3 times from a loop:
      for cname in ['CUBE','TOTO','LOLA'] # WHOOPS this not needed --> do |cname|
        purge_comp(cname)
      ... or you build a multi-match regular expression ( Regexp😞
      cnames = ['CUBE','TOTO','LOLA'] match = /#{cnames.join('|')}/
      Test file (SU2016):
      CubeLolaToto.skp
      "Color B04" and "Color J08" are unused.
      "Color K03", "Color M06" are used by primitive faces.
      "Material 2" is the leader color.
      So here is a method with extra quirks:
      • Returns false if array of cnames is empty.
      • Short circuits and returns 0 if no definitions are found to delete.
      • Reports both to console and message box number of definitions and materials purged.
      • Returns number of definitions deleted.
      # To test;
      # purge_comps('CUBE','TOTO','LOLA')
      # ... or;
      # del = ['CUBE','TOTO','LOLA']
      # purge_comps(del)
      def purge_comps(*cnames)
        return false if cnames.empty?
        cnames.flatten!
        model=Sketchup.active_model
        # collect matching definitions
        defstogo=model.definitions.find_all{|d| d.name =~ match }
        return 0 if defstogo.empty?
        # collect materials.
        matstogo=[]
        defstogo.each{|d|
          # first used by instances
          d.instances.each{|i|
            matstogo << i.material unless matstogo.include?(i.material)
          # now used by its entities
          d.entities.each{|e|
            matstogo << e.material unless matstogo.include?(e.material)
            ( matstogo << e.back_material unless matstogo.include?(e.back_material) ) if e.is_a?(Sketchup;;Face)
        matstogo.compact!
        matstogo.uniq!
        # now check if materials used elsewhere
        defsNOTtogo=model.definitions.find_all{|d| ! d.name =~ match }
        matsNOTtogo=[]
        defsNOTtogo.each{|d|
            matsNOTtogo << i.material unless matsNOTtogo.include?(i.material)
          d.entities.each{|e|
            matsNOTtogo << e.material unless matsNOTtogo.include?(e.material)
            ( matsNOTtogo << e.back_material unless matsNOTtogo.include?(e.back_material) ) if e.is_a?(Sketchup;;Face)
        matsNOTtogo.compact!
        matsNOTtogo.uniq!
        # now reduce matstogo as necessary...
        matstogo.clone.each{|e|
          matstogo.delete(e) if matsNOTtogo.include?(e)
        defsgone = defstogo.size
        matsgone = matstogo.size
        # start and operation to ensure Garbage Collection works...
        model.start_operation('Purger', true)
        # now delete the selected entities
        defstogo.each{|d| d.entities.clear! }
        # now delete the unneeded materials
        matstogo.each{|m| model.materials.remove(m) }
        # clear the arrays of references to deleted objects;
        matstogo.clear
        defstogo.clear
        # commit
        model.commit_operation
        msg = "#{defsgone} definitions purged\n#{matsgone} materials purged"
        puts msg
        UI.messagebox(msg,MB_OK)
        return defsgone
      If you absolutely must, you can call GC.start to ensure Ruby garbage collection runs.
      I'm not here much anymore.
      • TNTDAVIDT
        TNTDAVID
        @sdmitch said:
        You just need to wrap TIG's code with
        CODE: SELECT ALL
        ["cube","toto","lola"].each{|name|
          match = /#{name}/i
        Great thanks sdmitch,
        You allowed me to understand what Dan Rathbun was explaining to me.
        @dan rathbun said:
        https://forums.sketchup.com/t/ruby-lear ... ists/22861
        Get the old "Pick Axe" book and read it.
        Thanks for the Dan link, I will follow your advice.
        Here is the TIG method, which works for several definitions:
        http://i.imgur.com/UwLix09.gif
          match = /#{name}/i
          matstogo=[]
          defstogo.each{|d|
          d.entities.each{|e|
        ( matstogo << e.back_material unless matstogo.include?(e.material) ) if e.is_a?(Sketchup;;Face)
          matstogo.compact!
          matstogo.uniq!
          defsnottogo=model.definitions.find_all{|d| ! d.name =~ /#{match}/ }
          matsnottogo=[]
          defsnottogo.each{|d|
          matsnottogo << i.material unless matsnottogo.include?(i.material)
          d.entities.each{|e|
          matsnottogo << e.material unless matsnottogo.include?(e.material)
        ( matsnottogo << e.back_material unless matsnottogo.include?(e.material) ) if e.is_a?(Sketchup;;Face)
          matsnottogo.compact!
          matsnottogo.uniq!
          matstogo.delete(e) if matsnottogo.include?(e)
        With your help I reach my goals and I discover more and more the Ruby. 😉
        Thank you all for your help.
        [b:8wt9py2i]* Nouveau !!![/b:8wt9py2i] Découvrez notre nouveau Plugin [url=http://www.composant-dynamique.com/:8wt9py2i][color=#40FF00:8wt9py2i]C[/color:8wt9py2i][color=#77FF00:8wt9py2i]l[/color:8wt9py2i][color=#ADFF00:8wt9py2i]i[/color:8wt9py2i][color=#E4FF00:8wt9py2i]c[/color:8wt9py2i][color=#FFDB09:8wt9py2i]k[/color:8wt9py2i][color=#FF921B:8wt9py2i]-[/color:8wt9py2i][color=#FF492E:8wt9py2i]C[/color:8wt9py2i][color=#FF0040:8wt9py2i]u[/color:8wt9py2i][color=#ED2577:8wt9py2i]i[/color:8wt9py2i][color=#DA49AD:8wt9py2i]s[/color:8wt9py2i][color=#C86EE4:8wt9py2i]i[/color:8wt9py2i][color=#AD77FF:8wt9py2i]n[/color:8wt9py2i][color=#8965FF:8wt9py2i]e[/color:8wt9py2i] [color=#4040FF:8wt9py2i]2[/color:8wt9py2i][/url:8wt9py2i], pour créer vos cuisines 3D !
        • Dan RathbunD
          Dan Rathbun
          Your implementation still has a few errors.
          David, I say again, that I gave you the code for a complete corrected method above.
          It defines a method name purge_comps(*cnames)
          • TNTDAVIDT
            TNTDAVID
            **Sorry Dan, but I can not seem to make your method work.
            In your method, how to integrate "CUBE", "TOTO" and "LOLA"?
            Thank you in advance for your help.
            David**
            • TNTDAVIDT
              TNTDAVID
              **Sorry Dan, I had not paid attention to your instructions in the code:
              @dan rathbun said:
              To test:
              ... or:
              purge_comps(del)
              Your method works very well and offers new benefits. 👍
              I noticed a small problem:
              How to avoid deleting the texture of 'CUBE', if it is used elsewhere in SketchUp?
              Thanks in advance for your help.**
              • Dan RathbunD
                Dan Rathbun
                It is TIG's method with a few extra "bells and whistles".
                I'll look at it today a bit and see if there is an issue.
                EDIT: Okay, YES I see the issue. The method does not check the model level entities collection for used materials (on primitive entity objects.)
                • Dan RathbunD
                  Dan Rathbun
                  # To test;
                  # ... or;
                  # purge_comps(del)
                  # ver; 2.0
                    cnames.flatten!
                    matstogo=[]
                    defstogo.each{|d|
                      d.entities.each{|e|
                    matstogo.compact!
                    matstogo.uniq!
                    matsNOTtogo=[]
                      d.entities.each{|e|
                    # now used by model entities
                    model.entities.each{|e|
                    matsNOTtogo.uniq!
                    matstogo.clear
                    defstogo.clear
                    # commit
                    puts msg
                    return defsgone
                  • TNTDAVIDT
                    TNTDAVID
                    **Thanks for your reactivity Dan.
                    Your solution works in the most by cases, but not all the time.
                    The texture applied to TOTO should not be removed because it is used by the 4 Rectangle to Left:
                    http://i.imgur.com/ywPqHyg.gif
                    This mistake this product on my Click-Cuisine 2 furniture, and therefore makes the method unusable.
                    Here's the SKP file:
                    CubeLolaToto2.skp
                    If you test your code on other examples the problem will not exist! 😼
                    For this reason the problem is strange and requires an investigation.
                    David**
                    • Dan RathbunD
                      Dan Rathbun
                      I agree. Sounds like a good learning experience for you.
                      I'll let you do the investigation, and fix it.
                      I've given you enough help for now.
                      Your turn to do some of the work. 😉
                      • TNTDAVIDT
                        TNTDAVID
                        **Hello,
                        You are right Dan, for the moment I still have not found a solution.
                        I'm stubborn and I'd end up finding it!
                        Thanks for your example Dirven ☀
                        I have tested your code and the components are all removed from the SketchUp scene but nothing is purged.
                        Is this normal?
                        Edite:
                        The Ruby console returns this message when I trigger your method.
                        Error; #<NameError; undefined local variable or method `i' for Teste;Module>
                        C;/Users/David/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/TNT_Teste/logic.rb;60;in `block in purge_comps_n_mats'
                        C;/Users/David/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/TNT_Teste/logic.rb;56;in `each'
                        C;/Users/David/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/TNT_Teste/logic.rb;56;in `purge_comps_n_mats'
                        C;/Users/David/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/TNT_Teste/logic.rb;75;in `purge_comps'
                        C;/Users/David/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/TNT_Teste/logic.rb;85;in `block in singleton class'
                        SketchUp;1;in `call'
                        Thank you**
                          driven
                          edited my example...
                          line 55 i is now item...
                            driven
                            another way is to Hash the materials and set values for each...
                              def purge_comps_n_mats(*args)
                              model  = Sketchup.active_model
                              defs   = model.definitions
                              sel    = model.selection
                              view   = model.active_view
                              ents   = model.active_entities
                              mats   = model.materials
                              # add a hasj for materials and entities
                              mats_h = Hash[mats.zip([1] * mats.size)]
                              # this means you don't have to get Regexp right yourself
                              names = Regexp.union(args)
                              # this is similar to defs.to_a.dup.flatten
                              list = defs.find_all { |d| d }
                              # we will still only use one operation as v17 will error
                              model.start_operation('mats')
                              list.each do |defn|
                                defn.instances.each do |i|
                                   # optional 'showtime' for testing
                            	sel.add(i)
                            	view.refresh
                            	sleep 0.2
                                  dents = defn.entities
                                  if defn.name =~ names
                                    # get rid of the comps checking their materials
                                     mats_h[defn.material] = 3 unless defn.material.nil?
                                     mats_h[i.material] = 3 unless i.material.nil?
                                     dents.to_a.each do |item|
                                      mats_h[item.material] = 3 if item.respond_to? ;material
                                      mats_h[item.back_material] = 3 if item.respond_to? ;back_material
                            	# delete the instance
                            	ents.erase_entities(i)
                                  else
                                    mats_h[defn.material] = 2 unless defn.material.nil?
                                    mats_h[i.material] = 2 unless i.material.nil?
                                      mats_h[item.material] = 2 if item.respond_to? ;material
                                      mats_h[item.back_material] = 2 if item.respond_to? ;back_material
                            		sel.add(item)
                            		view.refresh
                            		sleep 0.2
                               mats_h.each { |k, v| mats.remove(k) unless k.nil? || v != 3 }
                              model.commit_operation #
                            purge_comps_n_mats('CUBE', 'TOTO', 'LOLA')
                            • TNTDAVIDT
                              TNTDAVID
                              **Thank you driven, your solution works well but encounters the same problem as that of TIG enhanced by Dan.
                              The materials applied to the "subcomponents" are not seen by the 2 methods.
                              To be more precise, here is an example in image:
                              http://i.imgur.com/JSGr1lZ.gif
                              The goal is that the texture "CUBE" is not deleted because it is used by "Nested component".
                              Perhaps the solution would be to ask both methods to explore all the subcomponents in SketchUp and collect the materials so as not to delete them?
                              How to write this in ruby?
                              I could find a solution by modifying the components of Click-Cuisine 2, but the ideal would be to solve the problem with the code.
                              If you want to try, here is the SKP file of the example:
                              CUBE.skp
                              Thank you**
                                driven
                                you must have changed something because it does work for me...
                                did you read the code?
                                it collects all nested materials from 'everything' before removing any materials...
                                click image to see gif:it_wors.gif
                                attach your test code...
                                • TNTDAVIDT
                                  TNTDAVID
                                  **Yes I read your code driven and am surprised that it does not work for me.
                                  You are right in my last SKP example, your method works.
                                  Make a test with this example:
                                  CubeLolaToto2.skp
                                  You will see that the texture of "TOTO" will be deleted.**
                                  • TNTDAVIDT
                                    TNTDAVID
                                    **I can not understand why the texture applied to "TOTO" is purged.
                                    If I go through "purge_unused" the texture "TOTO" is not deleted.
                                    So I'll get around the problem with another method.
                                    To delete a list of materials, I can write this:
                                    mat_names = ['TOTO','LOLA','CUBE']
                                    materials = Sketchup.active_model.materials
                                    mat_names.each{|mnj| materials.remove(mnj)}
                                    Can we do the same with "purge_unused", so that the unused materials of the list are deleted?
                                    Thank you for your help.**
