    Delete a list of components by their definitions.
    24 Posts 5 Posters 6.7k Views 5 Watching
    • TNTDAVIDT
      TNTDAVID
      **Sorry Dan, I had not paid attention to your instructions in the code:
      @dan rathbun said:
      To test:
      purge_comps('CUBE','TOTO','LOLA')
      ... or:
      del = ['CUBE','TOTO','LOLA']
      purge_comps(del)
      Your method works very well and offers new benefits. 👍
      I noticed a small problem:
      How to avoid deleting the texture of 'CUBE', if it is used elsewhere in SketchUp?
      Thanks in advance for your help.**
      [b:8wt9py2i]* Nouveau !!![/b:8wt9py2i] Découvrez notre nouveau Plugin [url=http://www.composant-dynamique.com/:8wt9py2i][color=#40FF00:8wt9py2i]C[/color:8wt9py2i][color=#77FF00:8wt9py2i]l[/color:8wt9py2i][color=#ADFF00:8wt9py2i]i[/color:8wt9py2i][color=#E4FF00:8wt9py2i]c[/color:8wt9py2i][color=#FFDB09:8wt9py2i]k[/color:8wt9py2i][color=#FF921B:8wt9py2i]-[/color:8wt9py2i][color=#FF492E:8wt9py2i]C[/color:8wt9py2i][color=#FF0040:8wt9py2i]u[/color:8wt9py2i][color=#ED2577:8wt9py2i]i[/color:8wt9py2i][color=#DA49AD:8wt9py2i]s[/color:8wt9py2i][color=#C86EE4:8wt9py2i]i[/color:8wt9py2i][color=#AD77FF:8wt9py2i]n[/color:8wt9py2i][color=#8965FF:8wt9py2i]e[/color:8wt9py2i] [color=#4040FF:8wt9py2i]2[/color:8wt9py2i][/url:8wt9py2i], pour créer vos cuisines 3D !
      • Dan RathbunD
        Dan Rathbun
        It is TIG's method with a few extra "bells and whistles".
        I'll look at it today a bit and see if there is an issue.
        EDIT: Okay, YES I see the issue. The method does not check the model level entities collection for used materials (on primitive entity objects.)
        I'm not here much anymore.
        • Dan RathbunD
          Dan Rathbun
          # To test;
          # purge_comps('CUBE','TOTO','LOLA')
          # ... or;
          # del = ['CUBE','TOTO','LOLA']
          # purge_comps(del)
          # ver; 2.0
          def purge_comps(*cnames)
            return false if cnames.empty?
            cnames.flatten!
            match = /#{cnames.join('|')}/
            model=Sketchup.active_model
            # collect matching definitions
            defstogo=model.definitions.find_all{|d| d.name =~ match }
            return 0 if defstogo.empty?
            # collect materials.
            matstogo=[]
            defstogo.each{|d|
              # first used by instances
              d.instances.each{|i|
                matstogo << i.material unless matstogo.include?(i.material)
              # now used by its entities
              d.entities.each{|e|
                matstogo << e.material unless matstogo.include?(e.material)
                ( matstogo << e.back_material unless matstogo.include?(e.back_material) ) if e.is_a?(Sketchup;;Face)
            matstogo.compact!
            matstogo.uniq!
            # now check if materials used elsewhere
            defsNOTtogo=model.definitions.find_all{|d| ! d.name =~ match }
            matsNOTtogo=[]
            defsNOTtogo.each{|d|
                matsNOTtogo << i.material unless matsNOTtogo.include?(i.material)
              d.entities.each{|e|
                matsNOTtogo << e.material unless matsNOTtogo.include?(e.material)
                ( matsNOTtogo << e.back_material unless matsNOTtogo.include?(e.back_material) ) if e.is_a?(Sketchup;;Face)
            # now used by model entities
            model.entities.each{|e|
            matsNOTtogo.compact!
            matsNOTtogo.uniq!
            # now reduce matstogo as necessary...
            matstogo.clone.each{|e|
              matstogo.delete(e) if matsNOTtogo.include?(e)
            defsgone = defstogo.size
            matsgone = matstogo.size
            # start and operation to ensure Garbage Collection works...
            model.start_operation('Purger', true)
            # now delete the selected entities
            defstogo.each{|d| d.entities.clear! }
            # now delete the unneeded materials
            matstogo.each{|m| model.materials.remove(m) }
            # clear the arrays of references to deleted objects;
            matstogo.clear
            defstogo.clear
            # commit
            model.commit_operation
            msg = "#{defsgone} definitions purged\n#{matsgone} materials purged"
            puts msg
            UI.messagebox(msg,MB_OK)
            return defsgone
          • TNTDAVIDT
            TNTDAVID
            **Thanks for your reactivity Dan.
            Your solution works in the most by cases, but not all the time.
            The texture applied to TOTO should not be removed because it is used by the 4 Rectangle to Left:
            http://i.imgur.com/ywPqHyg.gif
            This mistake this product on my Click-Cuisine 2 furniture, and therefore makes the method unusable.
            Here's the SKP file:
            CubeLolaToto2.skp
            If you test your code on other examples the problem will not exist! 😮
            For this reason the problem is strange and requires an investigation.
            Thank you in advance for your help.
            David**
            • Dan RathbunD
              Dan Rathbun
              I agree. Sounds like a good learning experience for you.
              I'll let you do the investigation, and fix it.
              I've given you enough help for now.
              Your turn to do some of the work. 😉
              • TNTDAVIDT
                TNTDAVID
                **Hello,
                You are right Dan, for the moment I still have not found a solution.
                I'm stubborn and I'd end up finding it!
                Thanks for your example Dirven ☀
                I have tested your code and the components are all removed from the SketchUp scene but nothing is purged.
                Is this normal?
                Edite:
                The Ruby console returns this message when I trigger your method.
                Error; #<NameError; undefined local variable or method `i' for Teste;Module>
                C;/Users/David/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/TNT_Teste/logic.rb;60;in `block in purge_comps_n_mats'
                C;/Users/David/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/TNT_Teste/logic.rb;56;in `each'
                C;/Users/David/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/TNT_Teste/logic.rb;56;in `purge_comps_n_mats'
                C;/Users/David/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/TNT_Teste/logic.rb;75;in `purge_comps'
                C;/Users/David/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/TNT_Teste/logic.rb;85;in `block in singleton class'
                SketchUp;1;in `call'
                Thank you**
                  driven
                  edited my example...
                  line 55 i is now item...
                    driven
                    another way is to Hash the materials and set values for each...
                      def purge_comps_n_mats(*args)
                      model  = Sketchup.active_model
                      defs   = model.definitions
                      sel    = model.selection
                      view   = model.active_view
                      ents   = model.active_entities
                      mats   = model.materials
                      # add a hasj for materials and entities
                      mats_h = Hash[mats.zip([1] * mats.size)]
                      # this means you don't have to get Regexp right yourself
                      names = Regexp.union(args)
                      # this is similar to defs.to_a.dup.flatten
                      list = defs.find_all { |d| d }
                      # we will still only use one operation as v17 will error
                      model.start_operation('mats')
                      list.each do |defn|
                        defn.instances.each do |i|
                           # optional 'showtime' for testing
                    	sel.add(i)
                    	view.refresh
                    	sleep 0.2
                          dents = defn.entities
                          if defn.name =~ names
                            # get rid of the comps checking their materials
                             mats_h[defn.material] = 3 unless defn.material.nil?
                             mats_h[i.material] = 3 unless i.material.nil?
                             dents.to_a.each do |item|
                              mats_h[item.material] = 3 if item.respond_to? ;material
                              mats_h[item.back_material] = 3 if item.respond_to? ;back_material
                    	# delete the instance
                    	ents.erase_entities(i)
                          else
                            mats_h[defn.material] = 2 unless defn.material.nil?
                            mats_h[i.material] = 2 unless i.material.nil?
                              mats_h[item.material] = 2 if item.respond_to? ;material
                              mats_h[item.back_material] = 2 if item.respond_to? ;back_material
                    		sel.add(item)
                    		view.refresh
                    		sleep 0.2
                       mats_h.each { |k, v| mats.remove(k) unless k.nil? || v != 3 }
                      model.commit_operation #
                    purge_comps_n_mats('CUBE', 'TOTO', 'LOLA')
                    • TNTDAVIDT
                      TNTDAVID
                      **Thank you driven, your solution works well but encounters the same problem as that of TIG enhanced by Dan.
                      The materials applied to the "subcomponents" are not seen by the 2 methods.
                      To be more precise, here is an example in image:
                      http://i.imgur.com/JSGr1lZ.gif
                      The goal is that the texture "CUBE" is not deleted because it is used by "Nested component".
                      Perhaps the solution would be to ask both methods to explore all the subcomponents in SketchUp and collect the materials so as not to delete them?
                      How to write this in ruby?
                      I could find a solution by modifying the components of Click-Cuisine 2, but the ideal would be to solve the problem with the code.
                      If you want to try, here is the SKP file of the example:
                      CUBE.skp
                      Thank you**
                        driven
                        you must have changed something because it does work for me...
                        did you read the code?
                        it collects all nested materials from 'everything' before removing any materials...
                        click image to see gif:it_wors.gif
                        attach your test code...
                        • TNTDAVIDT
                          TNTDAVID
                          **Yes I read your code driven and am surprised that it does not work for me.
                          You are right in my last SKP example, your method works.
                          Make a test with this example:
                          CubeLolaToto2.skp
                          You will see that the texture of "TOTO" will be deleted.**
                          • TNTDAVIDT
                            TNTDAVID
                            **I can not understand why the texture applied to "TOTO" is purged.
                            If I go through "purge_unused" the texture "TOTO" is not deleted.
                            So I'll get around the problem with another method.
                            To delete a list of materials, I can write this:
                            mat_names = ['TOTO','LOLA','CUBE']
                            materials = Sketchup.active_model.materials
                            mat_names.each{|mnj| materials.remove(mnj)}
                            Can we do the same with "purge_unused", so that the unused materials of the list are deleted?
                            Thank you for your help.**
                            • 2 / 2
