Delete a list of components by their definitions.
24 Posts 5 Posters 3.9k Views 5 Watching
    TNTDAVID
    **Hello, ☀
    I want to delete a list of components with their definitions and then purge their textures.
    Description of the step-by-step method:
    1 - All components that are named ['BOXE', 'CUBE'] in their definitions are deleted and purged without affecting the unused components.
    2 - All textures used by the components in the list must be purged without affecting the other materials.
    Note
    The goal is to find an alternative to purge_unused.
    The method must remove the components even if they are used in SketchUp and nested within groups.
    Any help in writing this method will be of great help to me.
    Thank you
    David**
    [b:8wt9py2i]* Nouveau !!![/b:8wt9py2i] Découvrez notre nouveau Plugin [url=http://www.composant-dynamique.com/:8wt9py2i][color=#40FF00:8wt9py2i]C[/color:8wt9py2i][color=#77FF00:8wt9py2i]l[/color:8wt9py2i][color=#ADFF00:8wt9py2i]i[/color:8wt9py2i][color=#E4FF00:8wt9py2i]c[/color:8wt9py2i][color=#FFDB09:8wt9py2i]k[/color:8wt9py2i][color=#FF921B:8wt9py2i]-[/color:8wt9py2i][color=#FF492E:8wt9py2i]C[/color:8wt9py2i][color=#FF0040:8wt9py2i]u[/color:8wt9py2i][color=#ED2577:8wt9py2i]i[/color:8wt9py2i][color=#DA49AD:8wt9py2i]s[/color:8wt9py2i][color=#C86EE4:8wt9py2i]i[/color:8wt9py2i][color=#AD77FF:8wt9py2i]n[/color:8wt9py2i][color=#8965FF:8wt9py2i]e[/color:8wt9py2i] [color=#4040FF:8wt9py2i]2[/color:8wt9py2i][/url:8wt9py2i], pour créer vos cuisines 3D !
      Construct a 'match' regexp to suit - e.g. match=/BOX/
      It's been explained before how to limit that to matches starting with BOX etc /^BOX/ and trap for upper/lowercase characters...
      Assemble an array of definitions, using that 'match' filter [untested!].
      model=Sketchup.active_model
      # collect matching definitions
      defstogo=model.definitions.find_all{|d| d.name =~ match }
      # collect materials.
      matstogo=[]
      defstogo.each{|d|
        # first used by instances
        d.instances.each{|i|
          matstogo << i.material unless matstogo.include?(i.material)
        # now used by its entities
        d.entities.each{|e|
          matstogo << e.material unless matstogo.include?(e.material)
          ( matstogo << e.back_material unless matstogo.include?(e.material) ) if e.is_a?(Sketchup;;Face)
      matstogo.compact!
      matstogo.uniq!
      # now check if materials used elsewhere
      defsNOTtogo=model.definitions.find_all{|d| ! d.name =~ match }
      matsNOYtogo=[]
      defsNOTtogo.each{|d|
          matsNOTtogo << i.material unless matsNOTtogo.include?(i.material)
        d.entities.each{|e|
          matsNOTtogo << e.material unless matsNOTtogo.include?(e.material)
          ( matsNOTtogo << e.back_material unless matsNOTtogo.include?(e.material) ) if e.is_a?(Sketchup;;Face)
      matsNOTtogo.compact!
      matsNOTtogo.uniq!
      # now reduce matstogo as necessary...
      matstogo.clone.each{|e|
        matstogo.delete(e) if matsNOTtogo.include?(e)
      # start and operation ro ensure Garbage Collection works...
      model.start_operation('Purger', true)
      # now delete the selected entities
      defstogo.each{|d| d.entities.clear! }
      # now delete the unneeded materials
      matstogo.each{|m| model.materials.remove(m) }
      # commit
      model.commit_operation
      This will work in versions >= 8...
        TNTDAVID
        **Hello TIG,
        Thank you for your very complete and precise example.
        I made a simple test on a component with the definition "BOX" which has a texture called "RED".
        The ruby dialog box returns "True", but does not delete the cube or the texture.
        http://i.imgur.com/ukvVTXi.gif
        Here is the code I copied and pasted into the dialog box:
          match = ['BOX']
          matstogo=['RED']
          defstogo.each{|d|
          d.entities.each{|e|
          matstogo.compact!
          matstogo.uniq!
          defsnottogo=model.definitions.find_all{|d| ! d.name =~ /#{match}/ }
          matsnottogo=['RED']
          defsnottogo.each{|d|
          matsnottogo << i.material unless matsnottogo.include?(i.material)
          d.entities.each{|e|
          matsnottogo << e.material unless matsnottogo.include?(e.material)
        ( matsnottogo << e.back_material unless matsnottogo.include?(e.material) ) if e.is_a?(Sketchup;;Face)
          matsnottogo.compact!
          matsnottogo.uniq!
          matstogo.delete(e) if matsnottogo.include?(e)
        Or is my mistake?
        Thank you in advance for your help.
        David**
          When I wrote match=/BOX/
          That is a regular expression.
          You wrote match=['BOX']
          That's an array containing a string...
          They are not the same thing !!
          So you need to try with a better set of variables !
          When I set a variable like matstogo=[] it's making an empty array to which we add elements...
          What made you think you need to diverge from my guidance ??
            TNTDAVID
            **I used a array to "match" because there will be several different definitions to delete.
            As in your code you use:
            defstogo.each {| d |
            It seemed to me that "each" was used to browse a array.
            Your code works perfectly for a single definition, what if we have "CUBE", "TOTO" and "LOLA" to delete?
            For matstogo I did not know that it was possible to collect materials of a definition without naming them. I'm still surprised by the Ruby.
            Thank you for your help.
            David**
              TNTDAVID
              **Hello Dan Rathbun and thank you for your help.
              @dan rathbun said:
              Then either you wrap what TIG showed you into a method, and call it 3 times from a loop:
              How to write the loop?
              I have done several tests and I still get this error message:
              Error; # <SyntaxError; <main>; syntax error, unexpected '|'
              For cname in ['CUBE', 'TOTO', 'LOLA'] do | cname |
              Then I tried your method by adding:
              Cnames = ['CUBE', 'TOTO', 'LOLA']
              The ruby console returns:
              purge_comps
              But nothing changes in SketchUp. 😲
              I have to move on from something obvious that I can not understand.
              Thank you in advance for your help.**
                sdmitch
                You are trying to define the variable "cname" twice in the same statement. delete the do | cname |
                As usual Dan is right. You just need to wrap TIG's code with
                ["cube","toto","lola"].each{|name|
                  match = /#{name}/i
                http://sdmitch.blogspot.com/
                  Dan Rathbun
                  MY BAD! I had a bad example (above.) [ Commented out that " do | cname |" part ]
                  >   match = /#{name}/i
                  That will actually create a separate undo operation for each entity (and it's materials) and will be much slower.
                  I gave you a complete working method at the bottom of that previous post !!!!!!
                  https://forums.sketchup.com/t/ruby-learning-resources-wikilists/22861
                  Get the old "Pick Axe" book and read it.
                  I'm not here much anymore.
                    Dan Rathbun
                    TIG is showing you how to purge ONEdefinition and it's materials.
                    @tntdavid said:
                    Your code works perfectly for a single definition, ...
                    No it does not. because you made 3 edits that make it NOT work properly.
                    CORRECTION: Actually I found 4 errors that made it not delete all the components or materials.
                    The second use of the Regexp was ! d.name =~ /#{name}/ (the regexp var is match.)
                    matsNOTtogo=[] was defined as matsNOYtogo=[], resulting in NameError
                    The comparison of back_material was conditional upon inclusion of front material in two statements.
                    @tntdavid said:
                    ... what if we have "CUBE", "TOTO" and "LOLA" to delete?
                    First, learn how and why TIG's code works for ONE definition, then learn how to modify it for multiple definitions.
                    for cname in ['CUBE','TOTO','LOLA'] # WHOOPS this not needed --> do |cname|
                      purge_comp(cname)
                    ... or you build a multi-match regular expression ( Regexp 😞
                    cnames = ['CUBE','TOTO','LOLA'] match = /#{cnames.join('|')}/
                    Test file (SU2016):
                    CubeLolaToto.skp
                    "Color B04" and "Color J08" are unused.
                    "Color K03", "Color M06" are used by primitive faces.
                    "Material 2" is the leader color.
                    So here is a method with extra quirks:
                    • Returns false if array of cnames is empty.
                    • Short circuits and returns 0 if no definitions are found to delete.
                    • Reports both to console and message box number of definitions and materials purged.
                    • Returns number of definitions deleted.
                    # To test;
                    # purge_comps('CUBE','TOTO','LOLA')
                    # ... or;
                    # del = ['CUBE','TOTO','LOLA']
                    # purge_comps(del)
                    def purge_comps(*cnames)
                      return false if cnames.empty?
                      cnames.flatten!
                      return 0 if defstogo.empty?
                      matstogo=[]
                      defstogo.each{|d|
                        d.entities.each{|e|
                          ( matstogo << e.back_material unless matstogo.include?(e.back_material) ) if e.is_a?(Sketchup;;Face)
                      matstogo.compact!
                      matstogo.uniq!
                      matsNOTtogo=[]
                        d.entities.each{|e|
                          ( matsNOTtogo << e.back_material unless matsNOTtogo.include?(e.back_material) ) if e.is_a?(Sketchup;;Face)
                      matsNOTtogo.uniq!
                      defsgone = defstogo.size
                      matsgone = matstogo.size
                      # start and operation to ensure Garbage Collection works...
                      # clear the arrays of references to deleted objects;
                      matstogo.clear
                      defstogo.clear
                      # commit
                      msg = "#{defsgone} definitions purged\n#{matsgone} materials purged"
                      puts msg
                      UI.messagebox(msg,MB_OK)
                      return defsgone
                    If you absolutely must, you can call GC.start to ensure Ruby garbage collection runs.
                      TNTDAVID
                      CODE: SELECT ALL
                        match = /#{name}/i
                      Great thanks sdmitch,
                      You allowed me to understand what Dan Rathbun was explaining to me.
                      @dan rathbun said:
                      https://forums.sketchup.com/t/ruby-lear ... ists/22861
                      Thanks for the Dan link, I will follow your advice.
                      Here is the TIG method, which works for several definitions:
                      http://i.imgur.com/UwLix09.gif
                        match = /#{name}/i
                        matstogo=[]
                        defstogo.each{|d|
                        d.entities.each{|e|
                        matstogo.compact!
                        matstogo.uniq!
                        matsnottogo=[]
                        d.entities.each{|e|
                        matsnottogo.uniq!
                      With your help I reach my goals and I discover more and more the Ruby. 😉
                      Thank you all for your help.
                        Dan Rathbun
                        Your implementation still has a few errors.
                        David, I say again, that I gave you the code for a complete corrected method above.
                        It defines a method name purge_comps(*cnames)
                          TNTDAVID
                          **Sorry Dan, but I can not seem to make your method work.
                          In your method, how to integrate "CUBE", "TOTO" and "LOLA"?
                          David**
                            TNTDAVID
                            **Sorry Dan, I had not paid attention to your instructions in the code:
                            @dan rathbun said:
                            To test:
                            ... or:
                            purge_comps(del)
                            Your method works very well and offers new benefits. 👍
                            I noticed a small problem:
                            How to avoid deleting the texture of 'CUBE', if it is used elsewhere in SketchUp?
                            Thanks in advance for your help.**
                              Dan Rathbun
                              It is TIG's method with a few extra "bells and whistles".
                              I'll look at it today a bit and see if there is an issue.
                              EDIT: Okay, YES I see the issue. The method does not check the model level entities collection for used materials (on primitive entity objects.)
                                Dan Rathbun
                                # To test;
                                # ... or;
                                # purge_comps(del)
                                # ver; 2.0
                                  cnames.flatten!
                                  matstogo=[]
                                  defstogo.each{|d|
                                    d.entities.each{|e|
                                  matstogo.compact!
                                  matstogo.uniq!
                                  matsNOTtogo=[]
                                    d.entities.each{|e|
                                  # now used by model entities
                                  model.entities.each{|e|
                                  matsNOTtogo.uniq!
                                  matstogo.clear
                                  defstogo.clear
                                  # commit
                                  puts msg
                                  return defsgone
                                  TNTDAVID
                                  **Thanks for your reactivity Dan.
                                  Your solution works in the most by cases, but not all the time.
                                  The texture applied to TOTO should not be removed because it is used by the 4 Rectangle to Left:
                                  http://i.imgur.com/ywPqHyg.gif
                                  This mistake this product on my Click-Cuisine 2 furniture, and therefore makes the method unusable.
                                  Here's the SKP file:
                                  CubeLolaToto2.skp
                                  If you test your code on other examples the problem will not exist! 😮
                                  For this reason the problem is strange and requires an investigation.
                                  David**
                                    Dan Rathbun
                                    I agree. Sounds like a good learning experience for you.
                                    I'll let you do the investigation, and fix it.
                                    I've given you enough help for now.
                                    Your turn to do some of the work. 😉
                                      TNTDAVID
                                      **Hello,
                                      You are right Dan, for the moment I still have not found a solution.
                                      I'm stubborn and I'd end up finding it!
                                      Thanks for your example Dirven ☀
                                      I have tested your code and the components are all removed from the SketchUp scene but nothing is purged.
                                      Is this normal?
                                      Edite:
                                      The Ruby console returns this message when I trigger your method.
                                      Error; #<NameError; undefined local variable or method `i' for Teste;Module>
                                      C;/Users/David/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/TNT_Teste/logic.rb;60;in `block in purge_comps_n_mats'
                                      C;/Users/David/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/TNT_Teste/logic.rb;56;in `each'
                                      C;/Users/David/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/TNT_Teste/logic.rb;56;in `purge_comps_n_mats'
                                      C;/Users/David/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/TNT_Teste/logic.rb;75;in `purge_comps'
                                      C;/Users/David/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/TNT_Teste/logic.rb;85;in `block in singleton class'
                                      SketchUp;1;in `call'
                                      Thank you**
                                        driven
                                        edited my example...
                                        line 55 i is now item...
                                          driven
                                          another way is to Hash the materials and set values for each...
                                            def purge_comps_n_mats(*args)
                                            model  = Sketchup.active_model
                                            defs   = model.definitions
                                            sel    = model.selection
                                            view   = model.active_view
                                            ents   = model.active_entities
                                            mats   = model.materials
                                            # add a hasj for materials and entities
                                            mats_h = Hash[mats.zip([1] * mats.size)]
                                            # this means you don't have to get Regexp right yourself
                                            names = Regexp.union(args)
                                            # this is similar to defs.to_a.dup.flatten
                                            list = defs.find_all { |d| d }
                                            # we will still only use one operation as v17 will error
                                            model.start_operation('mats')
                                            list.each do |defn|
                                              defn.instances.each do |i|
                                                 # optional 'showtime' for testing
                                          	sel.add(i)
                                          	view.refresh
                                          	sleep 0.2
                                                dents = defn.entities
                                                if defn.name =~ names
                                                  # get rid of the comps checking their materials
                                                   mats_h[defn.material] = 3 unless defn.material.nil?
                                                   mats_h[i.material] = 3 unless i.material.nil?
                                                   dents.to_a.each do |item|
                                                    mats_h[item.material] = 3 if item.respond_to? ;material
                                                    mats_h[item.back_material] = 3 if item.respond_to? ;back_material
                                          	# delete the instance
                                          	ents.erase_entities(i)
                                                else
                                                  mats_h[defn.material] = 2 unless defn.material.nil?
                                                  mats_h[i.material] = 2 unless i.material.nil?
                                                    mats_h[item.material] = 2 if item.respond_to? ;material
                                                    mats_h[item.back_material] = 2 if item.respond_to? ;back_material
                                          		sel.add(item)
                                          		view.refresh
                                          		sleep 0.2
                                             mats_h.each { |k, v| mats.remove(k) unless k.nil? || v != 3 }
                                            model.commit_operation #
                                          purge_comps_n_mats('CUBE', 'TOTO', 'LOLA')
                                          1 / 2
