    Kill dynamic components?
    14 Posts 9 Posters 4.4k Views 9 Watching
      Marron
      @jim said:
      I have a plugin that can "strip DC attributes", optionally delete sub-components which are hidden, and reset the scale mask. I wrote it for a business that uses DC's internally but wanted to protect their IP and reduce file size before making their models public. I have been meaning to get it posted.
      I'm very interested, could you send it to me in some way? πŸ˜ƒ
        Marron
        @tig said:
        This one-liner copy+paste+<enter> in the Ruby Console will stop a selected DC from being dynamic
        Sketchup.active_model.selection[0].definition.attribute_dictionaries.delete('dynamic_attributes')
        use wisely... 😲
        Hm, yes it worked. But I want to keep the groups in the component. Now I get the same problem as when exploding the component as many times as possible and then making a new component.
        Thanks anyway πŸ˜ƒ
        • Chris FullmerC Offline
          You asked to "kill dynamic components" - thats what his one line script does.
          So what do you REALLY want to do?
            Marron
            In my first post I wrote: "I want to keep the groups of the object that the dynamic component exists of, but clear all settings."
            I just want the component attributes to be cleared. But I want to keep the groups in the component.
              just stops the selected DC from being a DC!
              If you have nested DC's within a DC you'll need to run the tool recursively like this
              def dck(c);c.definition.attribute_dictionaries.delete('dynamic_attributes');c.entities.each{|e|dck(e)if e.class==Sketchup;;ComponentInstance};end;dck(Sketchup.active_model.selection[0])if e.class==Sketchup;;ComponentInstance
              where the method 'dck' is the 'dc_killer' applied to a selected component AND all of its nested DCs down to any depth... use with care
                skavan
                Hi, I know this was a while ago - but any chance I could snag the plugin you reference? Thanks.
                s.
                  skavan
                  I tried pasting this into the ruby editor - but it didn't work 😞
                  "Error: #<NameError: undefined local variable or method `e' for main:Object>"
                  I'm in SU15. The single line top-level version did work....but I'm really trying to zap the tree.
                  s.
                  • halroachH Offline
                    halroach
                    s.
                    I'm getting the same error. Ideas?
                    FlexTools - Super Quick Windows, Doors, Slats...
                    • sdmitchS Offline
                      sdmitch
                      s.
                      Try
                      def dck(c);c.definition.attribute_dictionaries.delete('dynamic_attributes');c.definition.entities.each{|e|dck(e)if e.class==Sketchup;;ComponentInstance};end;dck(Sketchup.active_model.selection[0])
                      after selecting the dynamic component.
                      http://sdmitch.blogspot.com/
                      • O Offline
                        Oly80
                        I'm not sure what other aspects of sketchup may be lost?...But saving as sketchup version 6 or below removes dynamic attributes, retaining the component and sub components.
