    Kill dynamic components?
    14 Posts 9 Posters 4.9k Views 9 Watching
    • AnssiA
      Anssi
      How about exploding and immediately creating a new component?
      Another way is to insert the DC in a new model, save it and import that. The DC attributes won't be usable until you explode the component once. Exploiting a common error with DCs.
      Anssi
        Marron
        @jim said:
        I have a plugin that can "strip DC attributes", optionally delete sub-components which are hidden, and reset the scale mask. I wrote it for a business that uses DC's internally but wanted to protect their IP and reduce file size before making their models public. I have been meaning to get it posted.
        I'm very interested, could you send it to me in some way? πŸ˜ƒ
          Marron
          @tig said:
          This one-liner copy+paste+<enter> in the Ruby Console will stop a selected DC from being dynamic
          Sketchup.active_model.selection[0].definition.attribute_dictionaries.delete('dynamic_attributes')
          use wisely... 😲
          Hm, yes it worked. But I want to keep the groups in the component. Now I get the same problem as when exploding the component as many times as possible and then making a new component.
          Thanks anyway πŸ˜ƒ
          • Chris FullmerC
            You asked to "kill dynamic components" - thats what his one line script does.
            So what do you REALLY want to do?
              Marron
              In my first post I wrote: "I want to keep the groups of the object that the dynamic component exists of, but clear all settings."
              I just want the component attributes to be cleared. But I want to keep the groups in the component.
                just stops the selected DC from being a DC!
                If you have nested DC's within a DC you'll need to run the tool recursively like this
                def dck(c);c.definition.attribute_dictionaries.delete('dynamic_attributes');c.entities.each{|e|dck(e)if e.class==Sketchup;;ComponentInstance};end;dck(Sketchup.active_model.selection[0])if e.class==Sketchup;;ComponentInstance
                where the method 'dck' is the 'dc_killer' applied to a selected component AND all of its nested DCs down to any depth... use with care
                  skavan
                  Hi, I know this was a while ago - but any chance I could snag the plugin you reference? Thanks.
                  s.
                    skavan
                    I tried pasting this into the ruby editor - but it didn't work 😞
                    "Error: #<NameError: undefined local variable or method `e' for main:Object>"
                    I'm in SU15. The single line top-level version did work....but I'm really trying to zap the tree.
                    s.
                    • halroachH
                      halroach
                      s.
                      I'm getting the same error. Ideas?
                      FlexTools - Super Quick Windows, Doors, Slats...
                      • sdmitchS
                        sdmitch
                        s.
                        Try
                        def dck(c);c.definition.attribute_dictionaries.delete('dynamic_attributes');c.definition.entities.each{|e|dck(e)if e.class==Sketchup;;ComponentInstance};end;dck(Sketchup.active_model.selection[0])
                        after selecting the dynamic component.
                        http://sdmitch.blogspot.com/
                        • O
                          Oly80
                          I'm not sure what other aspects of sketchup may be lost?...But saving as sketchup version 6 or below removes dynamic attributes, retaining the component and sub components.
