    Boolean solid vs surface?
    13 Posts 6 Posters 2.2k Views 6 Watching
    • chippwaltersC Offline
      chippwalters
      Does anyone know if there's a tool which can trim the BLUE cube with the RED surface?
      It would be great if it created 2 boolean solids from the BLUE cube.
      https://altuit.cloud/web/3Dnew/TrimQ.jpg
      Currently working with Cross-Reality technologies
        More classic and in place! ๐Ÿ˜„
        Surface is a Group
        Select the Cube / Intersect with Model
        Mask Surface
        Keep only a lateral face of Cube
        Push Pull one Part / Group
        Double click on the second part / Group
        Seems you have your 2 "solids" in place! ๐Ÿ˜„
        PS I have not Bootlools2 maybe it can make that automatically ?
          Cool a new little summer challenge! ๐Ÿ˜„
          the edge cube over the Red surface
          • Ctrl of the measure done from the side's cube
            Group the result
            Double-Click + CTRL the other side's cube
            Group the result
            et voilร ! ๐Ÿ’š
          You have your 2 solid parts of the cube! โ˜€
          Sure not at the same place but...
          Maybe this process can be refined!
          Cool little headache ๐Ÿ˜„
            chippwalters
            Surface is a Group
            Mask Surface
            [attachment=0:1za2qz90]<!-- ia0 -->GIF_lateral.gif<!-- ia0 -->[/attachment:1za2qz90]
            Thanks Frenchy,
            The cube and curved surface are only props-- I expect real world examples to be more complex. So, the extrude example won't work. I did however eventually use the intersect command combined with double-clicks + grouping to separate things. Then copy+paste to create the second interior surface.
            Still would be nice to be able to do this.
            PS Booltools 2 can't do it.
              https://www.fluidinteractive.com/products/sketchup-extensions/bool/
              Try this yet?
                chippwalters
                Try this yet?
                I looked at it before but I don't think it works with surfaces. I wonder if it's Boolean tools are as good as Booltools 2?
                • jujuJ Offline
                  juju
                  Have you tried:
                  Eneroth Slicer
                  s4u Slice
                    su4 Slice slices by a plane! ๐Ÿ˜‰
                      ktkoh
                      I tried the original bootools on your sample and it left the top cube with some lines to clean up. I still use it on SK2015 however I cant run 17 on my portable so I don't know if it runs on that version.
                        chippwalters
                        Yeah, I tried su4 Slice and it works great, but only with a line. Nothing compound.
                        Perhaps you've heard of Blender's boxcutter:
                        That would be one sweet SU plugin!
                          kaas
                          ๐Ÿ˜ฎ wow-that would be sweet indeed!
                            Visuhole makes some of these functions! ๐Ÿ˜‰
                              chippwalters
                              Yes, I forgot you shared that previously. Great find. Wish it allowed for scaling of the templates.
