    [Plugin] 3 point Window
    37 Posts 15 Posters 12.4k Views 15 Watching
    • PixeroP
      Pixero
      I just tried your scene but couldn't replicate the error.
      What version are you using? The current version is 1.0.4.
      • FrederikF
        Frederik
        That's odd... 😐
        I do use ver. 1.0.4 together with SU 2015 Pro on a Win 7 64bit 'puter...
        And now I can't replicate it either... 😳 πŸ˜’
        Cheers
        Kim Frederik
          dtrarch
          Hi all
          The bug depends on the way you draw the three points.
          Left top>Right top>Right bott will build the window properly. β˜€
          dtr
            Yes order of creation is very important for this plugin! πŸ€“
            • Free Visualizer! 😎 (French site πŸ˜‰
            • PixeroP
              Pixero
              I've updated 3pt Window to v.2.0.
              Fixed some bugs and added some features like Fixed or openable window.
              (They are not really openable but have the look of such windows).
              You can now draw windows on sloped and flat surfaces as well.
              It also have three different frame colors to choose from; white, gray and black.
              Note that this version only works with SketchUp 2016 or newer.
              3 point Window | SketchUcation
              (sketchucation.com)
              • medeekM
                medeek
                I've installed it into SketchUp 2017 but I'm getting this error:
                Error Loading File 3click_Windows.rb
                Error: #<LoadError: cannot load such file -- 3click_Windows/3click_Windows_main.rb>
                C:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require' C:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require'
                C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/3click_Windows.rb:4:in `<top (required)>'
                Anybody else get a similar error? I hope my installation of SketchUp isn't corrupt.
                Nathaniel P. Wilkerson PE
                Medeek Engineering Inc
                design.medeek.com
                • PixeroP
                  Pixero
                  Sorry about that. My fault. I'm fixing it now and it should be up again shortly...
                  I'll post here when it's working.
                  • PixeroP
                    Pixero
                    Now I have uploaded it again and it SHOULD be working.
                    I had mixed up the loading script with an older version. 😳
                    Hopefully everything will be ok now.
                    • ntxdaveN
                      ntxdave
                      I have not used the plugin for a while. Does or could it automatically cut a whole for the window?
                      If I remember correctly the last time I used it I had to cut a whole for the window separately.
                      Noe, how about a 3 point door tool πŸ˜„
                      Press F1...thank me later
                      • ntxdaveN
                        ntxdave
                        @pixero said:
                        Hi. It doesn't cut holes. Sdmitch have a script that cuts holes easily. Cant remember the name now but look through his site for it.
                        Edit. Hole in the wall, I think it was called.
                        Yes, there are others as well. I was just suggesting it would be neat if one plugin would "do it all". πŸ˜„
                        • PixeroP
                          Pixero
                          • K
                            kamallamsahle
                            Nice Thx u
                            • PixeroP
                              Pixero
                              Small update.
                              Added Vector icons to support HD screens.
                              • Bob JamesB
                                Bob James
                                Really useful. Are horizontal sliding windows on the list? πŸ’­
                                • PixeroP
                                  Pixero
                                  Thanks. I have no plans for new features right now and sliding windows would probably be low on the list as they are not common here in Sweden.
                                  I wanted it to be a simple plugin and the moment you start adding stuff it takes time and more work. There are other solutions for complex windows.
                                  But I won’t say never...
                                  • Bob JamesB
                                    Bob James
                                    That's too bad since here in central California their use is nearly 100%
                                    • 2 / 2
