    [Plugin] 3 point Window
    37 Posts 15 Posters 9.6k Views 15 Watching
    • PixeroP Offline
      Pixero
      Remembering settings, it's is on my to do list. πŸ‘
        db11
        Perfect! Will look forward to upcoming releases.
        • PixeroP Offline
          Pixero
          v1.0.2
          Added session memory of settings.
            db11
            @pixero said:
            v1.0.2
            Perfect. Makes a great tool even better. Thanks!
            • FrederikF Offline
              Frederik
              This is a nice little gem... πŸ‘
              I've found a bug, though...
              When making windows in a wall following the X or Y axis (0 degree), it works great...
              However, if you have a wall in i.e. a 45 degree angle, the glass planes become offset...
              And even if you continue to do it on a 0 degree wall, the offset is all of a sudden twice as big as on the 45 degree wall...
              I've attached an image showing what I mean as well as the 'skippy' used for this...
              3-point-window-bug.skp
              Cheers
              Kim Frederik
              • PixeroP Offline
                Pixero
                I just tried your scene but couldn't replicate the error.
                What version are you using? The current version is 1.0.4.
                • FrederikF Offline
                  Frederik
                  That's odd... 😐
                  I do use ver. 1.0.4 together with SU 2015 Pro on a Win 7 64bit 'puter...
                  And now I can't replicate it either... 😳 πŸ˜’
                  Cheers
                  Kim Frederik
                    dtrarch
                    Hi all
                    The bug depends on the way you draw the three points.
                    Left top>Right top>Right bott will build the window properly. β˜€
                    dtr
                      Yes order of creation is very important for this plugin! πŸ€“
                      • Free Visualizer! 😎 (French site πŸ˜‰
                      • PixeroP Offline
                        Pixero
                        I've updated 3pt Window to v.2.0.
                        Fixed some bugs and added some features like Fixed or openable window.
                        (They are not really openable but have the look of such windows).
                        You can now draw windows on sloped and flat surfaces as well.
                        It also have three different frame colors to choose from; white, gray and black.
                        Note that this version only works with SketchUp 2016 or newer.
                        3 point Window | SketchUcation
                        (sketchucation.com)
                        • medeekM Offline
                          medeek
                          I've installed it into SketchUp 2017 but I'm getting this error:
                          Error Loading File 3click_Windows.rb
                          Error: #<LoadError: cannot load such file -- 3click_Windows/3click_Windows_main.rb>
                          C:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require' C:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require'
                          C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/3click_Windows.rb:4:in `<top (required)>'
                          Anybody else get a similar error? I hope my installation of SketchUp isn't corrupt.
                          Nathaniel P. Wilkerson PE
                          Medeek Engineering Inc
                          design.medeek.com
                          • PixeroP Offline
                            Pixero
                            Sorry about that. My fault. I'm fixing it now and it should be up again shortly...
                            I'll post here when it's working.
                            • PixeroP Offline
                              Pixero
                              Now I have uploaded it again and it SHOULD be working.
                              I had mixed up the loading script with an older version. 😳
                              Hopefully everything will be ok now.
                              • ntxdaveN Offline
                                ntxdave
                                I have not used the plugin for a while. Does or could it automatically cut a whole for the window?
                                If I remember correctly the last time I used it I had to cut a whole for the window separately.
                                Noe, how about a 3 point door tool πŸ˜„
                                Press F1...thank me later
                                • ntxdaveN Offline
                                  ntxdave
                                  @pixero said:
                                  Hi. It doesn't cut holes. Sdmitch have a script that cuts holes easily. Cant remember the name now but look through his site for it.
                                  Edit. Hole in the wall, I think it was called.
                                  Yes, there are others as well. I was just suggesting it would be neat if one plugin would "do it all". πŸ˜„
                                  • PixeroP Offline
                                    Pixero
                                      kamallamsahle
                                      Nice Thx u
                                      • PixeroP Offline
                                        Pixero
                                        Small update.
                                        Added Vector icons to support HD screens.
                                        • Bob JamesB Offline
                                          Bob James
                                          Really useful. Are horizontal sliding windows on the list? πŸ’­
                                          • PixeroP Offline
                                            Pixero
                                            Thanks. I have no plans for new features right now and sliding windows would probably be low on the list as they are not common here in Sweden.
                                            I wanted it to be a simple plugin and the moment you start adding stuff it takes time and more work. There are other solutions for complex windows.
                                            But I won’t say never...
                                            • 2 / 2
