    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 630.2k Views 155 Watching
    • shukritobiS Offline
      shukritobi
      Hey Fredo,
      great tool! I've been using this plugin since 2 years ago. However, I've encountered a bug when trying to use JointPushPull.
      I was trying to extrude this plane:
      Date: 02-Feb-17 16:36:14
      An error occurred in Joint Push Pull
      Error in generation of the geometry
      undefined method `smooth?' for nil:NilClass
      JointPushPullGeometry.rb: 1107 -- block in geometry_coplanar_edges_overhang
      JointPushPullGeometry.rb: 1105 -- each
      JointPushPullGeometry.rb: 1105 -- each_with_index
      JointPushPullGeometry.rb: 1105 -- geometry_coplanar_edges_overhang
      JointPushPullGeometry.rb: 354 -- block in geometry_robot_erase_coplanar_edges
      JointPushPullGeometry.rb: 352 -- each
      JointPushPullGeometry.rb: 352 -- geometry_robot_erase_coplanar_edges
      JointPushPullGeometry.rb: 214 -- robot_call_action
      JointPushPullGeometry.rb: 177 -- geometry_robot_exec
      JointPushPullGeometry.rb: 160 -- geometry_robot
      JointPushPullGeometry.rb: 75 -- block in geometry_execute
      Lib6Operation.rb: 332 -- call
      Lib6Operation.rb: 332 -- step_geometry
      Lib6Operation.rb: 374 -- start_execution
      JointPushPullGeometry.rb: 75 -- geometry_execute
      JointPushPullTool.rb: 892 -- go_preview_or_geom
      JointPushPullTool.rb: 931 -- modify_execute
      JointPushPullTool.rb: 944 -- modify_offset
      JointPushPullTool.rb: 2081 -- action_from_VCB
      JointPushPullTool.rb: 2058 -- onUserText
      Here's the file: jpp error.skp
      I've encountered quite a number of errors, but today I decided want to learn more what's going on.
      • fredo6F Offline
        @shukritobi
        Can you attach the model which has the bugs.
        The one you attached does not provoke errors, and is different from what you show on the picture.
        • fredo6F Offline
          NEW RELEASE: JointPushPull Interactive v3.6a - 02 Feb 17
          JointPushPull Interactive 3.6a is certified for SU2017 and includes a few bug fixing in the generation of geometry.
          See main post of this thread for Download of JointPushPull.
            Rafal76
            I've just download the JointPushPull and LibFredo 6 but I don"t see the JointPushPull anywhere. I have Mac and I'm working with Sketchup 2017. Can somebody help me with that?
              Have you installed the files from the RBZs ?
              Have you restarted SketchUp ?
              Have you looked in the Extensions Manager to see that they are both enabled ?
              Have you look in the Toolbars etc... ?
                Maxym
                Hey guys! I've installed the push/pull plugin, but the toolbar shows only J,V,N modifiers, and I can't find a configiration menu at all to add more tools, like X R and F..
                I'm running Sketchup 2017, installed the lates version of the plugin and library, please advise!
                • E Offline
                  enbois
                  BonjourFredo6,
                  J'utilise actuellement SketchUp 8 free sous windows 10, depuis quelques temps déja et je suis trÚs intéressé par trois de vos plugins que j'ai découverts par un tuto:
                  "Gratuit : Dessiner sa maison avec SketchUp de Denis Bolomier, tuto #49372"
                  J'ai essayé de télécharger les plugins "tools on surface", "joint push pull interactive"
                  et le libfredo6 5.9b au format rbz.
                  Je n'ai pas réussi à le faire car je n'ai pas trouvé l'endroit du téléchargement de ces plugins. L'anglais n'est pas ma langue habituelle, et le langage informatique non plus. Aussi si vous pouviez me donner le ou les liens pour télécharger, je vous en serais reconnaissant.
                  Bon et tant qu'à faire j'ai un deuxiÚme problÚme: toujours dans le tutà cité au dessus, il est conseillé de télécharger "1001 bit tools". Ca c'est fait, il est installé, j'ai la barre des boutons mais quand je clique dessus il ne se passe rien. Je précise que j'ai bien coché la case "1001 bit tools" coché dans affichage/barre d'outils et qu'il apparait dans les "plugins" de mon SketchUp. Avez vous la solution pour remédier à ce problÚme? d'avance merci.
                  mon adresse mail: jeanclaude29mob@gmail.com
                    kiimiiss01
                    Hi, I mostly use the vector push pull option, but i always have to set an interactivily custom direction so i can get the desire extrude.
                    So guys, is there a way i can bind a key (shortcut) to the interacctivily custom direction option.
                    The Idea is to work faster something like press V (open vector pushpull) then shift+v (set interactivily custom direction).
                    https://image.ibb.co/fvxf6F/qw.png
                      snakeeyes
                      Thank you so much for this plugin, makes life easier
                        A curious bug 😄
                        If the "hole" is a component = bug
                        If the "hole" is not a component, that works!
                        hole_comp.skp
                        • I Offline
                          ifdesign
                          Thanks a lot for plugin 😄)
                          • E Offline
                            Eragon5454
                            dehßet thnx
                              LE1202
                              thx for sharing
                                LE1202
                                where can I download ??
                                  First post of this thread for any info about download! 😉
                                    rv1974
                                    Fredo, firstly thank you for non-stopping support of your tools!
                                    1. FPP: Is it possible to enable snapping on 'chamfer zero' (gif #1)
                                      2.What causes this (gif #2) misbehavior of Follow PushPull?
                                    2. There were long happy times when user (via mouse movement) was setting the JPP's direction. Now its +- in VCB that ultimately rules (which is VERY counter-intuitive)
                                      Could you get back to the old style please?
                                      theVonZipper
                                      It's a fantastic plugin. Can it be made to inherit the layers it's push/pulling from like the classic version?
                                      The VonZipper
                                        pel_MEN
                                        Date: 13-Oct-17 23:26:00
                                        An error occurred in Round Push Pull
                                        undefined method `reverse=' for nil:NilClass
                                        jointpushpullgeometry.rbe: 1473 -- geometry_rounding_mesh
                                        jointpushpullgeometry.rbe: 1277 -- block in geometry_create_roundings
                                        jointpushpullgeometry.rbe: 1276 -- each
                                        jointpushpullgeometry.rbe: 1276 -- geometry_create_roundings
                                        jointpushpullgeometry.rbe: 262 -- geometry_robot_prepare_mesh
                                        jointpushpullgeometry.rbe: 206 -- robot_call_action
                                        jointpushpullgeometry.rbe: 177 -- geometry_robot_exec
                                        jointpushpullgeometry.rbe: 160 -- geometry_robot
                                        jointpushpullgeometry.rbe: 75 -- block in geometry_execute
                                        lib6operation.rbe: 332 -- call
                                        lib6operation.rbe: 332 -- step_geometry
                                        lib6operation.rbe: 374 -- start_execution
                                        jointpushpullgeometry.rbe: 75 -- geometry_execute
                                        jointpushpulltool.rbe: 892 -- go_preview_or_geom
                                        jointpushpulltool.rbe: 698 -- dragging_stop
                                        jointpushpulltool.rbe: 1320 -- onLButtonUp
                                        I Wish it`s will help you
                                        • fredo6F Offline
                                          @pel_MEN
                                          Thanks. I fixed it and will republish in JPP4
                                          • fredo6F Offline
                                            NEW RELEASE: JointPushPull Interactive v4.1a - 23 Oct 17
                                            JointPushPull Interactive 4.1a is a refresh of the previous version, with evolution in 2 main areas:
                                            • Face selection process is now more natural, in the spirit of what is used for the native Sketchup Push Pull.
                                            • The button palettes have been redesigned, with 2 levels of functionality
                                            JointPushPull 4.1a requires LibFredo6 7.8 or above
                                            For those who are familiar with JointPushPull, the main changes are reviewed in the video below
                                            See plugin home page of JointPushPull for Download of JointPushPull.
                                            Main Post of the JointPushPull thread on this forum
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 30
                                            • 31
                                            • 14 / 31
