    Double-Cut - Cut through double-sided walls
    extensions
    44 Posts 19 Posters 25.4k Views 19 Watching
      A VisuHole + Components! 😎
        Minute 0.27 - 0.38 is yet "double cut" ?
        • PixeroP
          Pixero
          Wow. Looks great. Another must have plugin.
          • jujuJ
            juju
            Will this work on cavity walls (multi layered walls) and complete the returns / reveals?
            • W
              Whaat
              Sorry, it just works inside the 'active' wall group. If the wall is multi-layered and each layer is a separate group, it won't work for that.
              • andybotA
                andybot
                Ahhh, sigh of relief! This is something I've been imaging should be possible for about as long as I've been using sketchup. Great work, can't wait to try it!
                • Bob JamesB
                  Bob James
                  Instant buy for yet another "must have" tool. Many thanks. 👍 👍
                  • PixeroP
                    Pixero
                    A question.
                    If I use this plugin in a model and someone that doesn't have this opens the model and moves a window. What happens?
                      rv1974
                      I'll buy X10 if it works on curved surface.
                      P.S. Any plans for PB refreshing?
                      • W
                        Whaat
                        @pixero said:
                        A question.
                        The window will move but the hole created from Double-Cut will not move unless you 'unlock' it with the Right-click context menu and move it manually with the SU move tool.
                        • W
                          Whaat
                          Sorry, the tool is not designed for curved surfaces. Basically, the tool extends the existing functionality of SketchUp's cutting components. Since SketchUp's cutting components don't work on curved surfaces, DC won't work either.
                          • brettsichellodesignB
                            brettsichellodesign
                            I'm having some trouble with this plugin. Please see attached video. My door component doesn't seem to want to cut through the wall.
                            • W
                              Whaat
                              The axis of your door needs to be set correctly. You also need to make sure your component has a closed loop of edges on the same plane as the x-y plane of your component. Check out this tutorial on creating cutting components.
                              SketchUp: Creating Cutting Components
                              As my first How To post, here is a method of creating a component that cuts through a surface. Here are a few things to keep in mind Although you can activate the cutting feature on an existing component, it can become…
                              SketchUp Community (forums.sketchup.com)
                              • utilerU
                                utiler
                                Cool plugin, Dale!! Something that has been on the request list for soooo.... long!!
                                Just thought I'd make everyone aware that are using Skalp that it won't cut around openings as the standard SU section cut tool does. Not sure why; I'll ask the question of the Skalp team and see what they say.
                                Just Curious...
                                • srxS
                                  srx
                                  This is because the wall is not a solid. Faces on the side belongs to window group I guess.
                                  www.saurus.rs
                                  • utilerU
                                    utiler
                                    Whether its a solid or not surely the skalp tool should be able to work similar to the SU native tool??
                                    Just Curious...
                                    • srxS
                                      srx
                                      SU native tool doesn't make faces inside the wall.
                                      www.saurus.rs
                                      • JQLJ
                                        JQL
                                        The problem is related with hole cutting components.
                                        They are not creating new geometry as they are not actually cutting away the face, they're just displaying it differently... actually they are hiding it. But the face is still there.
                                        Sectioncut face doesn't usually draw the face on the section but draws the edges of the faces that have been cut by hole cutting components.
                                        This requires some manual cleaning on Section cut face side, which is usually not that hard to do. For folks using skalp, it might ruin the workflow... I don't use it.
                                        www.casca.pt
                                        Visit us on facebook!
                                        • facerF
                                          facer
                                          Whaat,
                                          Could you please post your instruction gif files at 1/2 the speed.
                                          This will make it easier to follow each step.
                                          Regards,
                                          Ray
                                          • minimalexM
                                            minimalex
                                            @jql said:
                                            ...it might ruin the workflow... I don't use it.
                                            Oh no! I was so excited that double cut was going to save me huge amounts of time, and now I have to pick whether I am more invested in double-cut or Skalp. Super bummed about this.
                                            Anyone think this has a chance of changing ever?
                                            • 1 / 3
