    Double-Cut - Cut through double-sided walls
    extensions
    44 Posts 19 Posters 22.9k Views 19 Watching
      Minute 0.27 - 0.38 is yet "double cut" ?
      • PixeroP Offline
        Pixero
        Wow. Looks great. Another must have plugin.
        • jujuJ Offline
          juju
          Will this work on cavity walls (multi layered walls) and complete the returns / reveals?
          • W Offline
            Whaat
            Sorry, it just works inside the 'active' wall group. If the wall is multi-layered and each layer is a separate group, it won't work for that.
            • andybotA Offline
              andybot
              Ahhh, sigh of relief! This is something I've been imaging should be possible for about as long as I've been using sketchup. Great work, can't wait to try it!
              • Bob JamesB Offline
                Bob James
                Instant buy for yet another "must have" tool. Many thanks. 👍 👍
                • PixeroP Offline
                  Pixero
                  A question.
                  If I use this plugin in a model and someone that doesn't have this opens the model and moves a window. What happens?
                    rv1974
                    I'll buy X10 if it works on curved surface.
                    P.S. Any plans for PB refreshing?
                    • W Offline
                      Whaat
                      @pixero said:
                      A question.
                      The window will move but the hole created from Double-Cut will not move unless you 'unlock' it with the Right-click context menu and move it manually with the SU move tool.
                      • W Offline
                        Whaat
                        Sorry, the tool is not designed for curved surfaces. Basically, the tool extends the existing functionality of SketchUp's cutting components. Since SketchUp's cutting components don't work on curved surfaces, DC won't work either.
                        • brettsichellodesignB Offline
                          brettsichellodesign
                          I'm having some trouble with this plugin. Please see attached video. My door component doesn't seem to want to cut through the wall.
                          • W Offline
                            Whaat
                            The axis of your door needs to be set correctly. You also need to make sure your component has a closed loop of edges on the same plane as the x-y plane of your component. Check out this tutorial on creating cutting components.
                            SketchUp: Creating Cutting Components
                            As my first How To post, here is a method of creating a component that cuts through a surface. Here are a few things to keep in mind Although you can activate the cutting feature on an existing component, it can become…
                            SketchUp Community (forums.sketchup.com)
                            • utilerU Offline
                              utiler
                              Cool plugin, Dale!! Something that has been on the request list for soooo.... long!!
                              Just thought I'd make everyone aware that are using Skalp that it won't cut around openings as the standard SU section cut tool does. Not sure why; I'll ask the question of the Skalp team and see what they say.
                              Just Curious...
                              • srxS Offline
                                srx
                                This is because the wall is not a solid. Faces on the side belongs to window group I guess.
                                www.saurus.rs
                                • utilerU Offline
                                  utiler
                                  Whether its a solid or not surely the skalp tool should be able to work similar to the SU native tool??
                                  Just Curious...
                                  • srxS Offline
                                    srx
                                    SU native tool doesn't make faces inside the wall.
                                    www.saurus.rs
                                    • JQLJ Offline
                                      JQL
                                      The problem is related with hole cutting components.
                                      They are not creating new geometry as they are not actually cutting away the face, they're just displaying it differently... actually they are hiding it. But the face is still there.
                                      Sectioncut face doesn't usually draw the face on the section but draws the edges of the faces that have been cut by hole cutting components.
                                      This requires some manual cleaning on Section cut face side, which is usually not that hard to do. For folks using skalp, it might ruin the workflow... I don't use it.
                                      www.casca.pt
                                      Visit us on facebook!
                                      • facerF Offline
                                        facer
                                        Whaat,
                                        Could you please post your instruction gif files at 1/2 the speed.
                                        This will make it easier to follow each step.
                                        Regards,
                                        Ray
                                        • minimalexM Offline
                                          minimalex
                                          @jql said:
                                          ...it might ruin the workflow... I don't use it.
                                          Oh no! I was so excited that double cut was going to save me huge amounts of time, and now I have to pick whether I am more invested in double-cut or Skalp. Super bummed about this.
                                          Anyone think this has a chance of changing ever?
                                          • JQLJ Offline
                                            JQL
                                            I see two ways:
                                            • Either Trimble exposes something in their API for section plugins to aknowledge the openning as true geometry and not a hidden face.
                                            • Or Skalp finds a workaround for that. Skalp is, itself a plugin built on incredibly well thought workarounds so they might find a way if you ask them.
                                            The good news is that there are other plugins that suffered from this issue in the past and solved it.
                                            The first one I noticed was Fredotools Report on Area. If you would report on a wall with 2x2m it would report 4m2. If you'd glue a holecutting component to it, it would still report the 4m2 even if the window should have subtracted it's area from the 4m2. Fredo solved it at the time when I reported. I don't know how he did it, of course.
                                            Blendup was exporting faces with holecutting components without holes. After reporting the "bug" the fix was to explode the components, export the model, undo the explosion. It works very fast and everything looks as it was before.
                                            Probably there are many more examples that I'm not aware of.
                                            I don't use skalp, but if you report that to the developers probably they will take a look.
                                            www.casca.pt
                                            • 1 / 3
