    Foundation Plugin
    451 Posts 15 Posters 614.6k Views 15 Watching
    • medeekM
      medeek
      The slab on grade concrete is working great, that was easy. Now I just need to work on the rebar in the perimeter footing and the anchor bolts as well as the optional garage curb.
      http://design.medeek.com/resources/images/foundation_su34_800.jpg
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        Any shape is possible even a circular shape by selecting points along an arc. Now I really need to get the wall plugin going with the same polygon tool that is smart enough to handle typical 90 deg. corners and non-orthogonal corners.
        https://3dwarehouse.sketchup.com/warehouse/getpubliccontent?contentId=13d5d936-05c8-4f81-998e-8f1e132360be
        Curved walls and roofs though are still a bit of stretch, but I can see we need to eventually go that direction as well to make everything complete.
        View model here:
        3D Warehouse
        (3dwarehouse.sketchup.com)
        design.medeek.com
        • N
          nujak66
          Looking great Nathaniel! You are doing such great work with all of your plugins.
          • medeekM
            medeek
            The polygon tool for the slab-on-grade foundations is nearing completion. I've got the concrete, perimeter rebar, internal footings and even anchor bolts all working.
            http://design.medeek.com/resources/images/foundation_su35_800.jpg
            The only item still pending is the slab reinforcement (mesh/bar). I've been contemplating devising my own boolean subtraction tool.
            I've even managed to create a fillet tool based on TIG's 2D tools that properly applies the correct bend radius to the perimeter rebar.
            design.medeek.com
            • jujuJ
              juju
              Please make it so the reinforcing and anchor bolts need to be toggled on/off separately.
              • medeekM
                medeek
                This is already the case. Anchor bolts, perimeter rebar and slab rebar/mesh are all independent of each other.
                The garage curb is also working well.
                I still need to do further testing with the metric templates.
                design.medeek.com
                • medeekM
                  medeek
                  I think I've got the slab reinforcement working now. I haven't tested it enough to determine if its really robust enough to release another update but I'll keep testing.
                  http://design.medeek.com/resources/images/foundation_su36_800.jpg
                  I owe Sdmitch big time for this one. I've integrated his rebar trim function into the plugin to create a new module that trims the slab rebar or mesh. I am still trying to figure out exactly how the magic is done but most of it is over my head.
                  View model here:
                  3D Warehouse
                  A mesh reinforced slab though can get quite heavy with the polygon count so it may only have limited usefulness.
                  design.medeek.com
                  • medeekM
                    medeek
                    I've tested it some more this morning and so far I have been unable to break it, πŸ˜„.
                    In the next couple of days I will update the slab feature on par with the slab on grade feature so that polygon shaped foundations are 100%.
                    Then I will turn my attention to the stemwall foundation and fully implement the polygon layout tool in that as well. I now have all the widgets in my toolbelt to make this happen.
                    Once I get those updates done I will release the updated version.
                    At that point I may raise the price to $15.00, since I will now have added more functionality.
                    The ability to trim rebar is a much bigger prize than just rebar. This will now allow me to do the same thing for floor joists (polygon layout) in the truss plugin.
                    design.medeek.com
                    • pbacotP
                      Wonderful work! For my current uses, which is not a full house modeling, the foundation tool is probably the best because I do like to model at least the basics of a foundation for my exterior house models, and often find this is often the most helpful part to study in 3d.
                      • medeekM
                        medeek
                        I haven't fully compiled a TODO List for this plugin yet but there are still a number of items that need to be addressed.
                        • A hole cutting tool that removes the concrete and the rebar and any anchor bolts in the way.
                        • Square and Rectangular Footings for point loads
                        • Strip Footings
                        • A line tool for the stemwall module
                        • Retaining Walls with Engineering
                        • Ability to step foundation walls
                        • Webdialog input for SOG and Stemwall so that interior footings can be configured with ease.
                        Let me know if there is anything you would like to add to this list.
                        design.medeek.com
                        • medeekM
                          medeek
                          Version 1.1.0 - 04.14.2017
                          • Added polygon outline tool for slab-on-grade and slab.
                          • Enabled perimeter rebar, anchor bolts, and slab reinforcement for (polygon) slab-on-grade foundations.
                          • Enabled slab reinforcement for (polygon) slabs.
                          design.medeek.com
                          • facerF
                            facer
                            Medeek,
                            Thank you for the Foundation Plugin update "Easter Egg", enjoy your Easter break πŸ˜„
                            • medeekM
                              medeek
                              Using the rectangular floor primitives I was able to manually create the floor on the previous foundation in about 30 minutes:
                              http://design.medeek.com/resources/images/foundation_su39_800.jpg
                              If I create the polygon floor tool I will be able to accomplish the same thing in under 10 seconds. The polygon floor tool in the truss plugin is next...
                              design.medeek.com
                              • medeekM
                                medeek
                                Polygon stemwall foundation with post and beam interior supports.
                                Note that the smaller segments of the interior footing assemblies were created by copying the larger assembly and then trimming it to size with the Trim tool in the truss plugin.
                                design.medeek.com
                                • medeekM
                                  medeek
                                  Version 1.1.1 - 04.23.2017
                                  • Added polygon outline tool for stemwall foundation.
                                  • Enabled perimeter rebar, anchor bolts, vents, and internal footings for (polygon) stemwall foundations.
                                  http://design.medeek.com/resources/images/foundation_su37_800.jpg
                                  http://design.medeek.com/resources/images/foundation_su38_800.jpg
                                  View model here:
                                  3D Warehouse
                                  The next improvement would be a web_dialog input so that more than one internal footing can be specified at a time.
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    I just realized that there may be a few items I missed in the last update with respect to the polygon stemwall tool and metric templates. I will do some more bug testing tonight to verify that all of the issues are addressed. I usually do all of my own work in standard US imperial units so sometimes in my rush to get a release out I forget to check all of the options and possible permutations using a metric template. I apologize for any inconvenience this may have caused. If you do notice an error please feel free to post here or notify me directly. Please give as much specifics as possible, that always helps.
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      The trim tool in the Truss Plugin comes in quite handy when dealing with more complex foundation geometry:
                                      https://3dwarehouse.sketchup.com/warehouse/getpubliccontent?contentId=a2e9a8ec-3df7-44e3-a89e-7011cdd79d3b
                                      For this foundation I used the stemwall (rectangle and polygon) function and the slab (polygon) function. I had to trim the garage stemwall and also manually create the smaller interior post/beam assemblies. I also adjusted the position of some of anchor bolts once I cut the doors into the garage stemwall.
                                      View model here:
                                      3D Warehouse
                                      Throwing a roof onto this foundation is fairly straightforward:
                                      https://3dwarehouse.sketchup.com/warehouse/getpubliccontent?contentId=0893714a-0a63-41f4-acc8-6efc2a837efc
                                      View model here:
                                      3D Warehouse
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        Recently I've received a number of requests for concrete columns to be added to the foundation plugin:
                                        https://courses.cit.cornell.edu/arch264/calculators/example7.5/01.jpg
                                        I'm still trying to figure out how to best add a concrete column module, I think it could gain some serious traction. This would cater more to the industrial rather than the residential side.
                                        I'll use ASDIP Concrete Software as a guide in establishing the various options to include:
                                        https://media.licdn.com/mpr/mpr/shrinknp_800_800/AAEAAQAAAAAAAAgkAAAAJDM0YTFiNDVkLTc2MjMtNDFkMy1hZjQ2LTAwOGE2NjU1NWRlYQ.png
                                        design.medeek.com
                                        • jujuJ
                                          juju
                                          This is a very interesting development. However, here is something to think about...
                                          You need to consider if you want to expose yourself (or the persons using the extension) to possible legal action. Soil and load conditions differ from place to place and instance to instance. This would require the input a structural engineer to certify the correct steel choice and configuration. This would then mean that the steel reinforcing in the extension is really reduced to "for illustrative purposes only".
                                          Which begs the question, just how much effort is thus justified with steel reinforcing options? Do you have a section for regular (non structural engineer) users with a "for illustrative purposes" type of output and a separate section (with all the "bells and whistles") you can only access with the completion / agreement of an indemnity?
                                          • facerF
                                            facer
                                            It looks like the "engineer" in medeek has taken over!
                                            I agree with "juju's" thread of thinking.
                                            The depth of detail suggested may be useful in medeek's engineering practice but have less value
                                            for I guess the majority of users and prospective users.
                                            My suggestion would be these proposed changes are at the edge of "the bell curve".
                                            It may be more prudent to stay within the "bulk" of users and prospective users requirements.
                                            Food for thought! πŸ˜„
                                            • 22
                                            • 23
                                            • 6 / 23
