    [Plugin] FloorGenerator ( Updated 6-Apr-2017)
    331 Posts 109 Posters 461.3k Views 109 Watching
    • sdmitchS
      sdmitch
      @rogalxxx said:
      I'm having problems with the plugin in SU 2017. Su 2015 seems to be working fine.
      Using even stock settings I get a lot of random tiles missing.
      I have tested FloorGenerator in SU2017 and had no problem with missing tiles.
      Could you post your model so I could test it myself?
      http://sdmitch.blogspot.com/
        rogalxxx
        here, Floor generator on stock settings, two identical planes-second one with tiles applied.
        looks like geometry has some random lines and faces, even though I have set no random parameter.
        tile test.skp
        • Mousa_SAM
          Mousa_SA
          I confirm, this issue is happening with me too,although there are no other plugins are active with it.
          • sdmitchS
            sdmitch
            I retested FloorGenerator in SU2017 using your model and, in 16 tests, 5 appeared to be normal, 1 had a single tile missing and the other 10 had several missing in random locations.
            My initial test seemed ok because I stupidly used the Random Colors option.
            I will do what I can to fix this problem.
            [highlight=#ff0000:153r5xxr]GOOD NEWS!!!! Once again it seems that the problem is the same old group explode redefining the ID of the selected face. Updated version now available in Plugin Store and my blog.[/highlight:153r5xxr]
            • sdmitchS
              sdmitch
              [highlight=#ff0000:sj7zyo1x]GOOD NEWS!!!! Once again it seems that the problem is the same old group explode redefining the ID of the selected face. Updated version now available in Plugin Store and my blog.[/highlight:sj7zyo1x]
                rogalxxx
                sdmitch you are awesome! Thank you. Glad I could contribute! ๐Ÿ˜„
                  Infinite walk to the perfection! ๐Ÿ˜Ž
                  • enigmaticE
                    enigmatic
                    Sam, you rescue me from a big trouble. Very thanks.
                      rogalxxx
                      why is there no option for an origin point where you click? Why center or left lower corner only? I mean this would be useful ๐Ÿ˜„
                      • sdmitchS
                        sdmitch
                        Because I assumed that the center or a corner were the most logical points of origin. FYI, the closest corner to the point you pick is used. Not just the lower left corner.
                          markpyvi
                          Can I please have a link for SU7. Latest one doesn't seem to work in SU7.
                          Cheers,
                          Mark
                          • sdmitchS
                            sdmitch
                            Cheers,
                            Mark
                            Sorry I can't. There is only one version.
                              seems working perfectly in 2017! โ˜€
                              • sdmitchS
                                sdmitch
                                [attachment=0:ocy8vhzy]<!-- ia0 -->sdm_floor.jpg<!-- ia0 -->[/attachment:ocy8vhzy]
                                I think he has version 7 not 2017.
                                  markpyvi
                                  @sdmitch said:
                                  Cheers,
                                  Mark
                                  Ok, no worries, will use 2017 for this step. Cheers.
                                    marche3d
                                    Hello could you tell me how to install it please...!!!!
                                      Most Plugins and Extensions' RBZs can be downloaded from the SketchUcation PluginStore:
                                      https://sketchucation.com/pluginstore?pln=SDM_FloorGenerator
                                      Have a browse and be amazed...
                                      Use the native Extension Manager to install them.
                                      Alternatively download and install the SketchUcation ExtensionStoreยณ, then you can browse and auto-install extensions directly from with SketchUp itself - sidestepping the download part altogether...
                                      • C
                                        c3dx
                                        Just can't make it work, the command window never show up
                                        I reayly like to make it run.....
                                        There is what i get when i try to run it
                                        SystemStackError: stack level too deep
                                        I do have Sketchup 2017 Version 17.21.2555 64 bit
                                        On windows 10 professionnel version 1703(15063.332)(French Version)
                                        I have Thearender for sketchup plugins install
                                        Graphic card: GTX 1060
                                        CPU: AMD FX-6300
                                        8 gig off ram
                                        i have this message in the console
                                        i also have this line appears many many time before the error
                                        read_default failed
                                        Error: #<SystemStackError: stack level too deep>
                                        C:/Users/c3dx/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/SDM_FloorGenerator.rb:162:in initialize' C:/Users/c3dx/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/SDM_FloorGenerator.rb:162:in initialize'
                                        C:/Users/c3dx/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/SDM_FloorGenerator.rb:162:in method_missing' C:/Users/c3dx/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/SDM_FloorGenerator.rb:162:in update_wd'
                                        C:/Users/c3dx/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/SDM_FloorGenerator.rb:174:in rescue in update_wd' C:/Users/c3dx/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/SDM_FloorGenerator.rb:160:in update_wd'
                                        C:/Users/c3dx/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/SDM_FloorGenerator.rb:170:in rescue in update_wd' C:/Users/c3dx/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/SDM_FloorGenerator.rb:160:in update_wd'
                                          Works fine for me with new Window 10 "creative" (French) not Pro but Familly! ๐Ÿ˜„
                                          Have you some accents on the paths Folders ?
                                          Have you install it from the "Red Ruby" Menu from Sketchup ?
                                            @c3dx
                                            These read_/write_default errors [and many more] might be because you have not initially installed SketchUp correctly.
                                            Thereby stopping you/SketchUp accessing the Registry properly.
                                            Here is how to install SketchUp properly...
                                            Find the SketchUp installer's exe file - probably in your Downloads folder.
                                            Select its icon, right-click, context-menu, "Run as administrator"...
                                            This will ensure it's correctly installed, and that you and the app now have proper permissions set up.
                                            If you already have SketchUp installed you probably do not need to uninstall/reinstall it - firstly try this...
                                            Close SketchUp.
                                            Use "Run as administrator" on the installer's exe file, as explained above...
                                            When prompted choose "Repair"...
                                            This should fix issues.
                                            Report back...
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 13 / 17
