    [Plugin] FloorGenerator ( Updated 6-Apr-2017)
    331 Posts 109 Posters 347.1k Views 109 Watching
    • sdmitchS Offline
      sdmitch
      @sdmitch said:
      @rogalxxx said:
      here, Floor generator on stock settings, two identical planes-second one with tiles applied.
      looks like geometry has some random lines and faces, even though I have set no random parameter.
      I retested FloorGenerator in SU2017 using your model and, in 16 tests, 5 appeared to be normal, 1 had a single tile missing and the other 10 had several missing in random locations.
      My initial test seemed ok because I stupidly used the Random Colors option.
      I will do what I can to fix this problem.
      [highlight=#ff0000:sj7zyo1x]GOOD NEWS!!!! Once again it seems that the problem is the same old group explode redefining the ID of the selected face. Updated version now available in Plugin Store and my blog.[/highlight:sj7zyo1x]
      http://sdmitch.blogspot.com/
        rogalxxx
        sdmitch you are awesome! Thank you. Glad I could contribute! πŸ˜„
          Infinite walk to the perfection! 😎
          • enigmaticE Offline
            enigmatic
            Sam, you rescue me from a big trouble. Very thanks.
              rogalxxx
              why is there no option for an origin point where you click? Why center or left lower corner only? I mean this would be useful πŸ˜„
              • sdmitchS Offline
                sdmitch
                Because I assumed that the center or a corner were the most logical points of origin. FYI, the closest corner to the point you pick is used. Not just the lower left corner.
                  markpyvi
                  Can I please have a link for SU7. Latest one doesn't seem to work in SU7.
                  Cheers,
                  Mark
                  • sdmitchS Offline
                    sdmitch
                    Cheers,
                    Mark
                    Sorry I can't. There is only one version.
                      seems working perfectly in 2017! β˜€
                      • sdmitchS Offline
                        sdmitch
                        [attachment=0:ocy8vhzy]<!-- ia0 -->sdm_floor.jpg<!-- ia0 -->[/attachment:ocy8vhzy]
                        I think he has version 7 not 2017.
                          markpyvi
                          @sdmitch said:
                          Cheers,
                          Mark
                          Ok, no worries, will use 2017 for this step. Cheers.
                            marche3d
                            Hello could you tell me how to install it please...!!!!
                              Most Plugins and Extensions' RBZs can be downloaded from the SketchUcation PluginStore:
                              https://sketchucation.com/pluginstore?pln=SDM_FloorGenerator
                              Have a browse and be amazed...
                              Use the native Extension Manager to install them.
                              Alternatively download and install the SketchUcation ExtensionStoreΒ³, then you can browse and auto-install extensions directly from with SketchUp itself - sidestepping the download part altogether...
                                c3dx
                                Just can't make it work, the command window never show up
                                I reayly like to make it run.....
                                There is what i get when i try to run it
                                SystemStackError: stack level too deep
                                I do have Sketchup 2017 Version 17.21.2555 64 bit
                                On windows 10 professionnel version 1703(15063.332)(French Version)
                                I have Thearender for sketchup plugins install
                                Graphic card: GTX 1060
                                CPU: AMD FX-6300
                                8 gig off ram
                                i have this message in the console
                                i also have this line appears many many time before the error
                                read_default failed
                                Error: #<SystemStackError: stack level too deep>
                                C:/Users/c3dx/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/SDM_FloorGenerator.rb:162:in initialize' C:/Users/c3dx/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/SDM_FloorGenerator.rb:162:in initialize'
                                C:/Users/c3dx/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/SDM_FloorGenerator.rb:162:in method_missing' C:/Users/c3dx/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/SDM_FloorGenerator.rb:162:in update_wd'
                                C:/Users/c3dx/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/SDM_FloorGenerator.rb:174:in rescue in update_wd' C:/Users/c3dx/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/SDM_FloorGenerator.rb:160:in update_wd'
                                C:/Users/c3dx/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/SDM_FloorGenerator.rb:170:in rescue in update_wd' C:/Users/c3dx/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/SDM_FloorGenerator.rb:160:in update_wd'
                                  Works fine for me with new Window 10 "creative" (French) not Pro but Familly! πŸ˜„
                                  Have you some accents on the paths Folders ?
                                  Have you install it from the "Red Ruby" Menu from Sketchup ?
                                    @c3dx
                                    These read_/write_default errors [and many more] might be because you have not initially installed SketchUp correctly.
                                    Thereby stopping you/SketchUp accessing the Registry properly.
                                    Here is how to install SketchUp properly...
                                    Find the SketchUp installer's exe file - probably in your Downloads folder.
                                    Select its icon, right-click, context-menu, "Run as administrator"...
                                    This will ensure it's correctly installed, and that you and the app now have proper permissions set up.
                                    If you already have SketchUp installed you probably do not need to uninstall/reinstall it - firstly try this...
                                    Close SketchUp.
                                    Use "Run as administrator" on the installer's exe file, as explained above...
                                    When prompted choose "Repair"...
                                    This should fix issues.
                                    Report back...
                                      c3dx
                                      @tig said:
                                      @c3dx
                                      Close SketchUp.
                                      Report back...
                                      Thanks Tig
                                      But i just reinstall it with the repair option as administrator but i still have the same result...
                                      i will try to uninstall everything and try it again....
                                      i don't know if it can have something to do with it , i had system mechanic running on it before, may be it did change some rule somewhere about the ability to read the registry....
                                        c3dx
                                        [attachment=0:2yws8aqg]<!-- ia0 -->red ruby.jpg<!-- ia0 -->[/attachment:2yws8aqg]
                                        [attachment=1:2yws8aqg]<!-- ia1 -->floor01.jpg<!-- ia1 -->[/attachment:2yws8aqg]
                                        Yes i did install it with the Red Ruby Menu from sketchup, i have a lap top and its not working there to, same result.... i really dont know why, this plugin can really help me....if i can make it work
                                        I dont have any accent in my path....
                                          Your earlier post suggested that you have messed around with the Registry settings.
                                          SketchUp, and some of its plugins need to write and read values from the Registry - so they are remembered across sessions...
                                          If that ability has been limited you will get problems !
                                          What did you do 😲
                                          • sdmitchS Offline
                                            sdmitch
                                            Previous versions of SDM_FloorGenerator had a problem with reading defaults from the registry when new pattern options had been added but I believe I finally fixed that problem in the May2017 release. Make sure you have the latest version.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 13 / 17
