    [Plugin] FloorGenerator ( Updated 6-Apr-2017)
    331 Posts 109 Posters 390.0k Views 109 Watching
    • sdmitchS Offline
      sdmitch
      Once again SU2017 is acting in a different way than previous versions. Maybe there is a solution but I doubt it.
      http://sdmitch.blogspot.com/
        So have 2015, 2016, 2017 is a good thing! πŸ˜‰
        (and that divide by 3 number of plugins (if distributed) for a more speed launch) πŸ€“
          rogalxxx
          so, no cure for this bug? any chance It will be patched?
          Any other plugin that can generate nice tiles?
            Protrude by Jim + Lattice Maker by TIG + FredoScale by Fredo?
            • enigmaticE Offline
              enigmatic
              @rogalxxx said:
              I'm having problems with the plugin in SU 2017. Su 2015 seems to be working fine.
              Using even stock settings I get a lot of random tiles missing.
              I have that same problem.Is there a solution?
              Murat
              • jujuJ Offline
                juju
                You could always do a work-around by saving the SKP in 2016 version, open SU2016, do what you want there with the plugin, save and open in 2017 again. I know, far from ideal.
                Who has any experience with Oob Layouts? It also reports only compatible up to 2015, but I have often had where extensions say that and work fine in the later (supposedly incompatible) SU version. Anybody willing to trial it?
                • sdmitchS Offline
                  sdmitch
                  I have tested FloorGenerator in SU2017 and had no problem with missing tiles.
                  Could you post your model so I could test it myself?
                    rogalxxx
                    here, Floor generator on stock settings, two identical planes-second one with tiles applied.
                    looks like geometry has some random lines and faces, even though I have set no random parameter.
                    tile test.skp
                    • Mousa_SAM Offline
                      Mousa_SA
                      I confirm, this issue is happening with me too,although there are no other plugins are active with it.
                      • sdmitchS Offline
                        sdmitch
                        I retested FloorGenerator in SU2017 using your model and, in 16 tests, 5 appeared to be normal, 1 had a single tile missing and the other 10 had several missing in random locations.
                        My initial test seemed ok because I stupidly used the Random Colors option.
                        I will do what I can to fix this problem.
                        [highlight=#ff0000:153r5xxr]GOOD NEWS!!!! Once again it seems that the problem is the same old group explode redefining the ID of the selected face. Updated version now available in Plugin Store and my blog.[/highlight:153r5xxr]
                        • sdmitchS Offline
                          sdmitch
                          [highlight=#ff0000:sj7zyo1x]GOOD NEWS!!!! Once again it seems that the problem is the same old group explode redefining the ID of the selected face. Updated version now available in Plugin Store and my blog.[/highlight:sj7zyo1x]
                            rogalxxx
                            sdmitch you are awesome! Thank you. Glad I could contribute! πŸ˜„
                              Infinite walk to the perfection! 😎
                                enigmatic
                                Sam, you rescue me from a big trouble. Very thanks.
                                  rogalxxx
                                  why is there no option for an origin point where you click? Why center or left lower corner only? I mean this would be useful πŸ˜„
                                  • sdmitchS Offline
                                    sdmitch
                                    Because I assumed that the center or a corner were the most logical points of origin. FYI, the closest corner to the point you pick is used. Not just the lower left corner.
                                      markpyvi
                                      Can I please have a link for SU7. Latest one doesn't seem to work in SU7.
                                      Cheers,
                                      Mark
                                      • sdmitchS Offline
                                        sdmitch
                                        Cheers,
                                        Mark
                                        Sorry I can't. There is only one version.
                                          seems working perfectly in 2017! β˜€
                                          • sdmitchS Offline
                                            sdmitch
                                            [attachment=0:ocy8vhzy]<!-- ia0 -->sdm_floor.jpg<!-- ia0 -->[/attachment:ocy8vhzy]
                                            I think he has version 7 not 2017.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 12 / 17
